Results 1 to 3 of 3
  1. #1
    Broken In prvprv's Avatar
    Jul 2008
    Hyderabad
    Default Upgrade to low end gaming pc
    currently I have C2D E7200, Gigabyte GA G31M S2L with 2GB DDR2 RAM (2*1gb). (see my signature)
    The inbuilt graphics chip is just ok for playing games like maxpayne 1,2 in Low settings.
    I have an idea of upgrading the mobo to ASUS - Motherboards- ASUS P5G41T-M LX
    This board has GMA X4500 graphics chip.
    So if I bought this Board with 4GB DDR3 RAM and install my old E7200 processor, Will it make any difference in gaming performance? like playing maxpayne 3 in low or medium settings?
    1) Old config + new GPU Nvidia Geforce GT520M 2GB for 3k
    2) new Asus Mobo + 4GB ddr3 for 3.6 k
    Which one is better option? 1 or 2 ?
    C2D E7200, Gigabyte GA G31M S2L, 2*1 GB Transcend RAM @ 800MHz, 1TB Seagate 7200.12 + 500GB Seagate 7200.12 SATA + 80GB Seagate Barracuda , LG DVD RW @ 22x, BenQ G2220 HD
  2. #2
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    Default Re: Upgrade to low end gaming pc
    Nothing will make a Difference. GT 520 is best suitable for HTPCs . Fill this.
    Asking for new PC help? ANSWER THESE QUESTIONS FIRST
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  3. #3
    Jul 2008
    Hyderabad
    Want to get this mobo for my current config
    1. What is the purpose of the computer?
    Ans: Download machine, video conversion, Java programming using eclipse, Running Virtual Machines, Occassional gaming. (low settings is enough)
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans: 4k
    3. Planning to overclock?
    Ans: Yes
    4. Which Operating System are you planning to use?
    Ans: Windows 7 64bit
    5. How much hard drive space is needed?
    Ans: Already have 2 HDDs. (see my signature)
    6. Do you want to buy a monitor?
    Ans: No
    Ans: I want to get a) New graphics card or b)
    8. When are you planning to buy the system?
    Ans: this month
    Ans: assembler
    Ans: Hyderabad, Local only.
    Ans: I Want to upgrade only.
    a) Current Onboard gpu GMA 3100 is not enough to play new games even in low settings.
    b) As it supports DDR2 only, installing a 4GB ddr2 costs 2.5k Where as I Can get 4GB of ddr3 for half of that price.
    c) the asus mobo ASUS - Motherboards- ASUS P5G41T-M LX has X4500 onboard GPU. how much better is this than GMA 3100 gpu?
    3) None of the above.
  1. Gaming PC Upgrade
    By jackal_79 in forum PC Components / Configurations
    Last Post: 09-08-2011, 08:16 AM
  2. PC upgrade for 25k .... (Gaming and Movies PC)
    By vinyasmusic in forum PC Components / Configurations
    Last Post: 01-06-2011, 01:11 PM
  3. need gaming upgrade sugestions
    By chahal63 in forum Hardware Q&A
    Last Post: 03-08-2010, 06:57 PM
  4. gaming upgrade
    By sumigizlov in forum Hardware Q&A
    Last Post: 12-02-2008, 06:53 PM
  5. upgrade to new gaming rig
    By sujeet2555 in forum Hardware Q&A
    Last Post: 08-11-2005, 09:05 PM
