Results 1 to 9 of 9
  1. #1
    Dec 2008
    Default Buying Advice - PC - 4 - Autocad - 3Dmax
    Hi,
    Ans: Autodesk Building Suite- 2012. & 3Dmax
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans: Rs.65000 can extend upto 75000
    3. Planning to overclock?
    Ans:No
    4. Which Operating System are you planning to use?
    Ans:Windows 7 -- (64 bit required???)
    5. How much hard drive space is needed?
    Ans:1TB
    Ans:Yes - 19" or above
    Ans:want to buy full pc,-- cpu, monitor, KB, mouse.
    8. When are you planning to buy the system?
    Ans:within a month
    Ans:yes i have built pc before. will buy as spare parts...
    Ans:Thiruvananthapuram, Kerala, will be buying locally.
    Ans: a guy from intercad suggested to buy nvidia geforce gtx 560 ti graphics card... so will go with it...
    Last edited by ajith025; 13-07-2012 at 09:03 PM. Reason: budget changed.. not opening another thread...
    For Reliable & Cheap Linux Web Hosting Visit Softronicz.com
  2. #2
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Default Re: Buying Advice - PC - 4 - Autocad - 3Dmax
    Actually budget is little tight, if it can be stretched to 35K then a balanced config i possible.
    Here is my suggestion:
    AMD Phenom II X4 960T B.E. @ 6.9K
    Gigabyte GA-78LMT-S2P (Rev 3.1) @ 2.6K
    Corsair Value Series 4GB X 1 1333 MHz DDR3 @ 1.2K
    Sapphire HD 6670 1 GB GDDR5 @ 5.4K
    WD Caviar Blue 500 GB SATA II HDD @ 4.1K
    Normal Cabinet without SMPS @ 0.8K
    Corsair CX 430 V2 @ 2.2K
    Acer 205H 20" LCD Display (1600X900) @ 5.1K
    Amkette Keyboard & Mouse Combo @ 0.4K
    Zebronics 600VA UPS @ 1.5K
    Total: 30.2K. I think this is the best I can do at this budget
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  3. #3
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    +1 to the Above Config . Also Numeric 600 VA Ups is available for 1.3K.
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  4. #4
    Dec 2008
    Thank you - Cilus, and Sainatarajan
    i will check if it is possible to extend the budget, or else will go with this config...
    thank you
  5. #5
    Dec 2008
    Hi,
    another requirement for same purpose, therefore not starting a new thread.
    editing requirements....
    Budget can be upto 65000. can be updated upto 75000
  6. #6
    Apr 2012
    IF the Cost of GTX 560 Ti is near to 13.5K to 15K , get AMD RADEON HD 7850 2 GB GDDR5 @ 15.5K .
  7. #7
    vkl
    vkl is offline
    Super Moderator
    Apr 2012
    Processor:AMD FX 8150 @ 12k;
    Motherboard:Gigabyte GA-970A-UD3 @6.6k
    RAM:Gskill RipjawsX 4GBx2 @3.2k
    HDD:WD Cavair Blue 1TB @5.2k
    SSD: Corsair Force Series 3 120 @7.5k
    Optical drive: Asus DRW-24B3ST @1.1k
    Cabinet:NZXT Source 210 elite:2.5k
    Graphic card:Gigabyte AMD GV-R7850OC-2GD@16.5k
    PSU:Seasonic S12-II-520 @3.9k
    Monitor: Dell U2312H @15.3k
    Mouse&KB:Logitech MK200 @0.7k
    Total=74.5k
    Dell U2312H is an ips monitor,has better viewing angles and colour reproduction than TN panel monitors.
    HD7850 has much better compute capabilities than gtx560ti.
    SSD would make the system more responsive and faster.
    Update the firmware of the SSD if you get it.
  8. #8
    Dec 2008
    thank u VKL.
  9. #9
    Nov 2011
    NCR
    better get samsung series 830 ssd since it is best in terms of both performance and reliability.
    Samsung SSD | Samsung SSD Drive | Samsung SSD Price | Samsung SSD Review
    Is God willing to prevent evil, but not able? Then he is not omnipotent.
    Is he able, but not willing? Then he is malevolent.
    Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
  1. Buying Advice of buying a Fridge in 17K ?
    By Sainatarajan in forum Consumer electronics and everything else
    Last Post: 27-05-2012, 09:36 PM
  2. Buying a new pc, need advice
    By mumblehere in forum PC Components / Configurations
    Last Post: 26-09-2010, 02:18 AM
  3. Maya & 3dMax
    By sahil_sood2004 in forum QnA (read only)
    Last Post: 31-05-2009, 08:29 PM
  4. PSP Buying Advice
    By chunkychan in forum Gamerz
    Last Post: 14-08-2008, 09:36 AM
  5. PROBLEM WITH 3DMAX 7..HELP!!!!!!
    By suhas_sm in forum QnA (read only)
    Last Post: 11-11-2004, 08:23 AM
