Results 1 to 30 of 48
15-06-2012, 08:37 PM #1Almost fully unconfused
- Join Date
- Jun 2012
- Location
- On the thing called internet
- Posts
- 32
What changes do I need to my rig?
I am planning to assemble a computer with the following configuration.
Please suggest changes if any. The configuration costs around my budget and I don't want to increase my budget.
15-06-2012, 11:00 PM #2Apprentice
- Join Date
- Jun 2012
- Posts
- 97
Re: What changes do I need to my rig?
Asking for new PC help? ANSWER THESE QUESTIONS FIRST
Fill this up first
16-06-2012, 10:17 AM #3
@OP : If this a gaming RiG its higly unbalanced. Do as suggested by digit1191 so that we can help.
AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
16-06-2012, 02:46 PM #4
why do u need a 800w psu for that rig?
and if you really are what your name suggests please fill it up Asking for new PC help? ANSWER THESE QUESTIONS FIRST
16-06-2012, 03:17 PM #5Apprentice
- Join Date
- Jun 2012
- Posts
- 97
16-06-2012, 11:27 PM #6Broken In
- Join Date
- Feb 2012
- Posts
- 98
its confusing are u making home theater ? if yes then 20 inch monitor is not full HD go with 22inches monitor benq full hd for 7500k
you selected 800watt psu when your system can run very smoothly on 450watt psu as there is no overclocking processor or heavy bulky graphic card crosair 450 whiich will cost you 2.5k max
you added 30 gb ssd are you going to use it caching ? if its not for caching mode and you want to use it for boot drive
30 gb is less at least go for 60 GB for boot drive
instead of ddr3 2 gb please go for 1 gb ddr5 in your price range as cutting down on psu
motherboard is good but i will suggest h77 or if cheap then h67 also in your option
no suggesion on lan cool case LOL she is beautie
17-06-2012, 11:20 AM #7Almost fully unconfused
- Join Date
- Jun 2012
- Location
- Posts
- 32
Ans: Programming, Kernel level debugging, Gaming(Assassin's Creed, NFS etc.), Video/Photo Editing (Photoshop, AfterEffects), Torrenting
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans: around 55k
3. Planning to overclock?
Ans: If possible within budget
4. Which Operating System are you planning to use?
Ans: Linux Mint 12 / Ubuntu 12.04 LTS / Win7 Ultimate (Multiboot)
5. How much hard drive space is needed?
Ans: 1-2 TB
Ans: Yes, 20-22 inch. Highest resolution possible in budget. 16:9 aspect ratio (i.e. widescreen)
Ans: None
8. When are you planning to buy the system?
Ans: Within next month
Ans: No, this is my first time but i will be assembling it myself
Ans: Kanakpura Road, Bangalore. Would prefer buying from online stores.
Ans: I don't mind a complete change of my rig. I just put together whatever I thought might be good and arrived at this rig. I'm a n00b, so my rig practically would be unbalanced as RiGOD mentioned but with your (ThinkDIGIT community's) help, I think I can get a good rig. Thanks all in advance.
17-06-2012, 02:20 PM #8Super Moderator
- Join Date
- Apr 2012
- Posts
- 798
Intel i5 2500k based rig
If you opt for intel based config then can look for alternate motherboards like
ASRock Z77 Extreme4 Motherboard for around 10k which will take your budget to around 60k.Last edited by vkl; 17-06-2012 at 06:41 PM.
17-06-2012, 03:28 PM #9Apprentice
- Join Date
- Jun 2012
- Posts
- 97
nice build vkl. OP wants atleast 1 TB HDD. Other than that awesome recommendation. and is biostar a trusty brand ?
17-06-2012, 03:39 PM #10
Another Vote for vkl config from me.
Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
17-06-2012, 03:58 PM #11Almost fully unconfused
- Join Date
- Jun 2012
- Location
- Posts
- 32
@vkl
Thanks but,
I need atleast 1TB HDD (preferably 2TB). Also, the rig kinda overshoots my budget. I want to go in for Intel only. Nothing against AMD but I feel i'm better off with Intel.
Also, I'm not sure i require the 'k' version 'coz I wasn't planning to overclock anyways... I was just thinking that there might be a small chance I might want to overclock... Now, I'm pretty sure the chance is infinitesimal...
As for the case, I really like the lancool case I'd chosen and would prefer that or something that looks similar... Even Cooler Master Elite 310 Cabinet looks nice... so something similar to that too is fine...
The monitor doesn't have a HDMI port... Can you suggest one that does but is good sturdy build too...
I'd prefer to have an SSD if possible so that I can work with temporary files there when I'm editing videos etc...
Thanks again...
17-06-2012, 03:59 PM #12
If your serious about Photoshop and After Effects then go for this config. FX 8150 will be beneficial for mulit-threaded apps.
And it will be very handy to add after market CPU cooler. Like - Thermalright Cogage TRUE Spirit@1.7k or CM Hyper 212 EVO@2.1k.
If your budget is fixed at 55k then you can opt HD 7770 @ 10k range. These new HD 7XXX series can be useful in photo/video editing apps.Last edited by pcforumguy; 17-06-2012 at 04:06 PM.
18-06-2012, 02:20 AM #13Super Moderator
- Join Date
- Apr 2012
- Posts
- 798
^^Yeah right, for overclocking an after market cooler like CM hyper 212 evo is recommended.
@confusedBuyer
As you wont overclock consider this
You can cut the budget further by going for corsair cx500v2 psu at 3.4k
If you want ssd then consider the below config
CPU Intel i5 2400@10.8k
Intel DH67CL Motherboard @5.5k
2x Corsair 4 GB RAM (CMV4GX3M1A1333C9)@2.5k
GPU GIGABYTE HD 7770@8.5k
HDD WD Caviar Blue 1TB@5.2k
Optical Drive Asus DRW-24B3ST@1.1k
Case COOLER MASTER ELITE 311 PLUS@2.7k
PSU Corsair CX430V@@2.3k
Corsair Force Series 3 120 GB SSD@7.7k
Monitor Dell ST2220L@8.3k
Total 54600
Dell ST2220L has HDMI port as per your requirement.
The GCN based cards are perfect for photo/video editing and gaming.Last edited by vkl; 18-06-2012 at 02:29 AM.
18-06-2012, 07:08 AM #14
OP can go for HD 6850 . It Performs more than the HD 7770 .
18-06-2012, 10:12 AM #15Broken In
- Join Date
- Feb 2012
- Posts
- 98
i agree with Sainatarajan
HD 6850 will be better choice
as non overclock build cx 430v psu can handle 6850 easily
18-06-2012, 12:39 PM #16Super Moderator
- Join Date
- Apr 2012
- Posts
- 798
^^Op can go for HD6850 if he likes.6850 would be better for gaming.
HD7770 would be better in photo and video editing that's why suggested it.
HD7770 is significantly faster in video encoding.
Also 7770 supports VCE which would be supported by amd drivers in upcoming drivers.
02-07-2012, 07:41 PM #17Almost fully unconfused
- Join Date
- Jun 2012
- Location
- Posts
- 32
Thanks all!
VKL recommended a nice rig but I have some questions...
On flipkart, each component is costlier than the specified cost... I'd like to know where these costs are from...
I'm getting them for the foll price... ( i'm planning to buy from flipkart... Please recommend any other good site if there is, for different components )
CPU Intel i5 2400 @11.8k
Motherboard Intel DH67CL @5.6k <- on flipkart, i saw a review saying "Motherboard was recalled". how about ASUS P8B75-V @ 6.2k
RAM 2x Corsair 4 GB (CMV4GX3M1A1333C9) @2.7k <- how about 2x Corsair XMS3 DDR3 4 GB (CMX4GX3M1A1600C9) @ 3.1k or G.Skill RipjawsX DDR3 8 GB (2 x 4 GB) PC RAM (F3-12800CL9D-8GBXL) @ 3.6k
GPU GIGABYTE HD 7770 @not on flipkart <- how about Asus NVIDIA GeForce GT 520 2 GB DDR3 @ 3.6k (out of stock currently though so i don't mind changing)
HDD WD Caviar Blue 1TB @5.3k <- is 2 TB not possible at about same price? i'd prefer as much space as possible ( speed should not be terribly slow either )
Optical Drive Asus DRW-24B3ST @1.1k
Case COOLER MASTER ELITE 311 PLUS @3.4k <- how about Lancool PC-K57 @ 3.8k
PSU Corsair CX430V @2.5k <- Is 430W enough? I thought the GPU itself requires 450W
SSD Corsair Force Series 3 120 GB SSD @7.7k
Monitor Dell ST2220L @9.1k
Thanks in advance!
PS: I'm replying pretty late coz i wasn't free for the past 2 weeks...
05-07-2012, 07:40 PM #18Almost fully unconfused
- Join Date
- Jun 2012
- Location
- Posts
- 32
BUMP!!!
05-07-2012, 08:35 PM #19Broken In
- Join Date
- Jun 2012
- Posts
- 119
06-07-2012, 02:27 PM #20
Hey op you still thinking about GT 520 ??
MSI R7770-2PMD1GD5/OC @9.1k
Gigabyte Radeon HD 7770 Graphic card @ 9k
i suggest you to go for MSI version its' dual fan one...
06-07-2012, 07:16 PM #21Almost fully unconfused
- Join Date
- Jun 2012
- Location
- Posts
- 32
@WILDLEGHORN, I haven't really bought things from sites other than flipkart so, i'd like to know if TheITWares.com is a reputable site and whether it would deliver in Bangalore.
@Chaitanya, The MSI one is better only for the dual fan, or is there any other difference. Also, won't 450W be reqd for the GPU itself? So, don't I need a PSU with more than 450W
I'm still unsure about most of the components so if you people can have a look at my other post and reply. Thanx.
Currently decided config :-
Motherboard ASUS P8B75-V @ 6.2k
RAM 2x Corsair XMS3 DDR3 4 GB (CMX4GX3M1A1600C9) @ 3.1k or G.Skill RipjawsX DDR3 8 GB (2 x 4 GB) PC RAM (F3-12800CL9D-8GBXL) @ 3.6k
GPU MSI R7770-2PMD1GD5/OC @9.1k or Gigabyte Radeon HD 7770 Graphic card @ 9k
HDD WD Caviar Green 2 TB HDD Internal Hard Drive (WD20EARX) @ 6.7k
Case Lancool PC-K57 @ 3.8k
Also, can someone recommend a decent keyboard and mouse (combo or separate).
06-07-2012, 07:24 PM #22
Why do you want to go with a Business Class Motherboard ? Also Why did you choose a 1600 Mhz Ram?
06-07-2012, 09:54 PM #23
08-07-2012, 05:58 PM #24Almost fully unconfused
- Join Date
- Jun 2012
- Location
- Posts
- 32
@Sainatarajan, Is there a difference in business class and other motherboards? If so, can you please elaborate? Also, won't a 1600 make it faster? Or does it just increase cost without significant speed improvement?
@Chaitanya, Thanks for the PSU info. I have a doubt about the GPU though. Doesn't overclocking a component reduce its lifetime? I require my PC to stay working pretty long.
Motherboard ASUS P8B75-V @ 6.2k <- Is this motherboard good? Sainatarajan said its a business class. Is that good or bad?
RAM 2x Corsair XMS3 DDR3 4 GB (CMX4GX3M1A1600C9) @ 3.1k or G.Skill RipjawsX DDR3 8 GB (2 x 4 GB) PC RAM (F3-12800CL9D-8GBXL) @ 3.6k <- Need recommendation on this
GPU MSI R7770-2PMD1GD5/OC @9.1k or Gigabyte Radeon HD 7770 Graphic card @ 9k (most probably Gigabyte one)
Also, can someone recommend a decent keyboard and mouse (combo or separate). Would Razer Abyssus & Cyclosa bundle be good?
08-07-2012, 06:09 PM #25Alpha Geek
- Join Date
- Apr 2012
- Location
- Delhi
- Posts
- 874
08-07-2012, 06:22 PM #26Almost fully unconfused
- Join Date
- Jun 2012
- Location
- Posts
- 32
@iittopper, As I mentioned earlier, On flipkart, someone has said that intel DH67CL was recalled due to faulty sata ports. So, I'm kinda woried on buying that. I just want to know whether this person's claim is true or it is just a stupid remark.
Also, for my budget for keyboard+mouse would be around 2k or 3k.
I know Razer is good but I've read negative reviews about the cyclosa bundle. So again, are these reviews baseless or do they have some backing?
Thanks
How about Logitech Gaming Combo G100 Keyboard
(For PC) @ 1.6k
08-07-2012, 07:34 PM #27
It was reacalled by intel due to some SATA Problems . Later Intel Released the B3 Revision Which fixed the Problems . I too own the DH67CL B3 . It is the best Motherboard for I5 2400. Look @ my signature.
08-07-2012, 09:54 PM #28Almost fully unconfused
- Join Date
- Jun 2012
- Location
- Posts
- 32
@Sainatarajan, OK then.. but is the thing on flipkart @ Intel DH67CL Motherboard | Motherboard | Flipkart.com the B3 Revision... It is not clear there...
Also, which Logitech Combo do you have? And would you recommend it?
08-07-2012, 10:14 PM #29
Yes the flipkart one is B3 revision.
08-07-2012, 10:30 PM #30Alpha Geek
- Join Date
- Apr 2012
- Location
- Delhi
- Posts
- 874
For mouse- buy logitech g300/400 - great for gaming
LinkBack URL
About LinkBacks
