Results 1 to 12 of 12
  1. #1
    Jun 2012
    Default 50k Future Proof Gaming/HD Movie Build
    Ans: Mainly Gaming: DIRT 3, Deus Ex: Human Revolution, NFS: The Run, Crysis II, Call of Duty: MW3, BF3, Metro 2033, FIFA12, FSX and to watch HD Movies.
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans: 50k max initially. Can invest more in the long-term
    3. Planning to overclock?
    Ans: Yes. Mobo should be able support 5ghz + overclocks. Intial overclock will be upto 4.5ghz and then 5 ghz and above after processor upgrade which will be after 2-3 years on the same mobo
    4. Which Operating System are you planning to use?
    Ans: Win XP Pro/Win7 ultimate / Win8
    5. How much hard drive space is needed?
    Ans: None (Already have 2 HDDs – 500GB + 320 GB)
    Ans: Already have a Benq 19” wide screen lcd. 1440x900. Will upgrade to 23” 3D LED Monitor or non 3D 27” LED Monitor with 1080p resolution next year.
    Ans: 500GB + 320 GB SATA HDDs, 19” Benq Monitor, LG DVD Writer & Intex 600VA UPS
    8. When are you planning to buy the system?
    Ans: Next Month. But can wait for a few more months if required.
    Ans: Will be done by assembler.
    Ans: Coimbatore. Open to buying online.
    Ans: I want to build a future proof system with a good foundation because I will build my next system only after 4-5 years. I will add a 2nd GPU within 18 months and do a processor upgrade in 24-36 months. I want the mobo to have at least 2 PCI 3.0 slots so that I can SLI / Crossfire X it later. I want Physx so the GPU should be nVidia or I have heard of combining an ATI and nVidia gpus where the ATI gpu is the master gpu and the nVidia card is used for Physx, whichever combination is better. I liked the NZXT Gamma cabinet because it has provision for upto 4 additional fans. I want liquid cooling for the processor. The system should be efficient when it comes to power consumption.
    Mainly the mobo should be top-notch so that I can have a simple system now and in the long-term I can build a monster rig on it.
  2. #2
    Jun 2012
    Lucknow, Uttar Pradesh
    Default Re: 50k Future Proof Gaming/HD Movie Build
    Check this 1 out.
    1.Processor: Intel Core i5 2500k: 12.5k
    2.Motherboard: Gigabyte Z77 G1 Sniper M3: 11k
    3.RAM: 4GB: 1k
    4.GPU: Gigabyte HD 7850 2GD5/OC: 15k
    5.Cabinet: NZXT Gamma: 2k
    6.CPU cooler: Antec Kuhler Flow: 3k
    7.DVD writer: 0.9k
    8.PSU: Corsair GS 600: 4.5k
  3. #3
    knocking on heavens door sumonpathak's Avatar
    Jul 2011
    Skeleton city
    ^^sniper 3 source?
    2500K|3570K|FX-8150|FX-8350|965BE|E7500
    MVF|P8Z77-V Deluxe|P8Z68 Deluxe|CHV|880GM-USB3|M4A785T-M|G31M-ES2L
    HD7850|GTX660Ti|HD6870|HD6670|HD5450|9400GT
    HyperX Blu|HyperX Predator|RipjawsX|Value Select|CGM2X2|
  4. #4
    Jun 2012
    Quote Originally Posted by Utkarsh Sharma View Post
    Check this 1 out.
    3.RAM: 4GB: 1k
    7.DVD writer: 0.9k
    I would prefer a liquid cpu cooler and a nVidia card since I require pHysx.
    P.S.: I want to look at only Z77 mobos like the one you mentioned. What do you think of 'ASROCK Z77 pro4 mobo"?
  5. #5
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    I5 2500K @ 12.5K
    ASUS P8Z77 M PRO @ 12K
    GSKILL RipJAWSx 4 GB x 2 @ 3K
    Seasonic S12 620W @ 4.5K
    CM ELITE 430 @ 3K
    HIS HD 7850 @ 15K
    LOGITECH MK200 @ 0.6K
    Creative 2.1 Speaker @ 1K
    Total @ 51.5K
    You need More PSU when you SLI or XFIRE .
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  6. #6
    SoLa BeLLaToR... RiGOD's Avatar
    Feb 2012
    Migrator
    If you're seriously thinking of a CF setup here is my suggestion.
    AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
  7. #7
    Jul 2011
    Skeleton city
    50K for a multi gpu config is too constricted..is it possible to increase the budget? the we may have more suggestions.
    Quote Originally Posted by RiGOD View Post
    nice config although i don't think the dream of 5Ghz oc can be achieved on it..TBH even in SB its wayy too much for continued use...
  8. #8
    Feb 2012
    Migrator
    ^^Yeah I know buddy. But as you said, OP's budget is too tight, and the main purpose is gaming, so gave preference to PSU & GPU rather than CPU & motherboard. But in gaming, I really don't think such heavy OC'ing will show a real world difference.
  9. #9
    Jul 2011
    Skeleton city
    basically at 1920*1080 processor makes no difference....
    i had a config in mind but it may push up the budget to 60K
    my take
    vb 3.8.7 sucks
    or the table tag needs working.
  10. #10
    Jul 2011
    Skeleton city
    ^^err...hyperX blu is not available in India?
    so is PCS+,Thermaltake,H2
  11. #11
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Here is my suggestion:
    AMD FX 8150 @ 12K
    Gigabyte GA-970A-UD3 @ 6.6K
    Corsair A70 Cooler @ 3.4K
    G-skill RipjawX 1600 MHz 4GB X 1 @ 1.56K
    Gigabyte HD 7870 OC 22K
    NZXT Source 210 Elite @ 2.4K
    Seasonic SS750JS 750W 80+ PSU @ 5.4K
    Logitech G400 Gaming Mouse @ 1.4K
    Logitech K100 PS2 Keyboard @ 0.34K
    Reasons:
    1. CPU: At 1080P gaming, GPU matters more and FX -8150 is more than enough for gaming. Also OP wants higher overclocking potential and we all know about the OC potential of of FX 8100 series. Sumon has overclocked it to 4 GHz with the stock cooler and with a good Air Cooler 4.8 GHz plus is very much possible.
    2. CPU Cooler: I've checked several reviews of the Corsair A70 Direct HEat Pipe based Air Cooler and it performs neck to neck with the higher end Noctua Coolers.
    3. Graphics card: Upgraded the Graphics card with HD 7870 OC. It performs better than a GTX 580 (it is a factory overclocked Model) and consumes less than half the power. For gaming it is the best higher-mid range GPU.
    4. PSU: Suggested 750W PSU as it is more than enough and overkill, considering even the higher overclock. In fact the S12 II 620W is good enough.
    5. Gaming Mouse: I think a Gaming Mouse is very much required for Gaming, more than the Keybaord. Logitech G400 is a marvelous product, replacing another gr8 product, MX518.
    6. Motherboard: Gigabyte 970A-UD3 offers 8+2 Phase VRM which means it is better suited for higher overclocking.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  12. #12
    Jun 2012
    I think the best thing to do is wait for some more time and save up little more cash to build a better system!
  1. Building a Gaming + Multimedia Rig -- Future Proof
    By Ironman in forum PC Components / Configurations
    Last Post: 21-07-2012, 07:25 PM
  2. Future proof PC under 25k
    By ilikecool1 in forum PC Components / Configurations
    Last Post: 15-07-2012, 06:06 PM
  3. Gaming Laptop- Future Proof
    By oromis in forum Laptops and Netbooks
    Last Post: 22-11-2011, 04:42 PM
  4. Gaming rig future proof not much on prcing
    By macho84 in forum PC Components / Configurations
    Last Post: 08-07-2011, 08:50 PM
  5. Replies: 1
    Last Post: 07-01-2009, 10:34 PM
