Results 1 to 14 of 14
Thread: Planing to upgrade P4 to AMD
26-05-2012, 12:08 PM #1Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 5
Ans: Games - MW3, COD Black Ops, GTA 4, NFS Carbon
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans: 9000/- Cannot be extended.
3. Planning to overclock?
Ans: Dont know much about this, any help will be appreciated. Thanks
4. Which Operating System are you planning to use?
Ans:Windows7/XP
5. How much hard drive space is needed?
Ans:Not required have old hard drives, 40gb and 32gb.
Ans:Already have a 17" CRT 1280*1024 pixels
Ans: Keyboard, mouse, cd drive, speakers.
8. When are you planning to buy the system?
Ans: About some time next month
Ans: No, Will be done by assembler.
Ans: Punjab will purchase locally.
Ans: Wish to upgrade to amd as I have heard that in my budget it will provide the best gaming experience. Also please mention that what all I have to purchase to upgrade my system. Thanks in advance.
26-05-2012, 04:36 PM #2
Re: Planing to upgrade P4 to AMD
In 9000/- AMD config isn't possible.
Intel config might be done with G620. I'm not sure about that.
Also your old 32GB, 40GB HDDs are IDE HDD and most of the motherboards, presently don't have IDE connector.
So, you need SATA HDD.Last edited by d6bmg; 26-05-2012 at 11:51 PM. Reason: typo edited
26-05-2012, 05:18 PM #3Gamer
- Join Date
- Jul 2011
- Location
- Bhubaneswar
- Posts
- 602
Increase your budget to 20k atleast. We can suggest something for you then. 9k just won't cut it.
Gaming Rig:
26-05-2012, 08:28 PM #4
At 9K any decent config is not possible. I'm trying hard to give you a decent config for your budget at the lowest possible price.
Intel Pentium G620 2 3.3k
MSI H61M-P21 (B3) @ 2.8k/Gigabyte GA-H61M-D2H @ 3.2K
CORSAIR 1333 Hz 4GB X 1 DDR3 @ 1.1K
Zotac GT 520 1 GB DDR3 @ 2.77K
InteX/Frontec Cabinet with 450W SMPS @ 1K
Total ~ 11K. Now the problem is with HDD. None of your existing PATA or IDE HDDs will work with the new motherboards as they drop the IDE port in the motherboard. You can try some PCI Addon cards which will provide you IDE socket but for that you need a motherboard with PCI slot. Then your choice should be the Gigabyte board as it is having two PCI slots.
In that case, get the Gigabyte board and This PCI to SATA/IDE addon card.AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
27-05-2012, 12:18 AM #5
About that PCI to SATA/IDE addon card, I should add that those cards may or may not work with your old IDE drive. Chance of working is good, but will totally depend on your luck.
27-05-2012, 02:18 AM #6
^^ These cards will work for sure, don't confuse it with the cheap SATA to IDE converters which does come with very cheap converter chip. On the other hand, these Adapter cards do have a controller chip for the conversion. In fact, they are not converters, they just use the PCI bandwidth to run the attached components.
27-05-2012, 11:48 AM #7
Oh! Sorry. You are right. I've confused your suggested PCI to IDE converter with IDE to SATA converter.
27-05-2012, 05:13 PM #8Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 5
I have bought this 320 gb hard disk( Newegg.com - SAMSUNG Spinpoint F1 HD322HJ 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive ) about 2 years back. And I think it is sata checked this model number through device manager.
Sorry bro I donot have that much budget, maximum I can extend it to 11k not more than that
Thanks for your reply but as I have mentioned I think that I am using 320 gb sata disk I have provided the link above for the model number. Please check that and can I play the above mentioned games if I upgrade to above mentioned config?
. I am completely novice in case of knowledge about motherboard, processor etc.
27-05-2012, 05:20 PM #9Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 5
28-05-2012, 08:14 PM #10Gamer
- Join Date
- Jul 2011
- Location
- Bhubaneswar
- Posts
- 602
You can play any game at low settings with that graphics card. Games released before 2007 will run @ high settings though.
03-06-2012, 08:29 PM #11Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 5
07-11-2012, 03:16 PM #12Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 5
Ok an update have increased my budget to 15000 so can anybody now suggest all the accessories and cost of them to build a decent enough gaming pc.
Thanks
07-11-2012, 03:35 PM #13
With the added money, add a good Graphics card like MSi HD 6670 1GB GDDR5 version @ 5.4K. Also, currenly G630 and G645, small upgrades over the old G620 in clock speed, are available at almost same price. Grab if G645 is available, otherwise G630.
09-11-2012, 01:58 AM #14
Go with the config recommended by Cilus-it will be good enough for your requirements.
“We are all in the gutter, but some of us are looking at the stars.” - Oscar Wilde
Help regarding career planing
By Niilesh in forum EducationReplies: 8Last Post: 19-03-2012, 07:51 PM -
Planing to Start a Game Center-Reg
By mobileman in forum GamerzReplies: 5Last Post: 23-11-2010, 04:39 PM -
Planing to buy a new desktop...need suggestion
By Abhishek Dwivedi in forum Hardware Q&AReplies: 4Last Post: 15-10-2007, 07:54 PM -
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!!
By karthik316_1999 in forum Internet & WWWReplies: 11Last Post: 18-07-2006, 08:10 PM -
graphic card upgrade(PCI) or motherboard upgrade?
By thetopcyborg in forum Graphic cardsReplies: 5Last Post: 13-01-2006, 02:32 PM
LinkBack URL
About LinkBacks
