Results 1 to 21 of 21
  1. #1
    DemiGod xD Mehul Chauhan's Avatar
    May 2012
    Mumbai, Maharashtra
    Smile 35k - 40k Gaming PC suggestion
    Ans:Cod series,Battlefield series,Gta4 & 5,crysis series, and some video & photo editing.
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans:35k.....(40k maximum)
    3. Planning to overclock?
    Ans:yes...but later on.
    4. Which Operating System are you planning to use?
    Ans:win7 64
    5. How much hard drive space is needed?
    Ans:500gb or 1tb
    Ans:22inch
    Ans:ups,keyboad & mouse,speakers.
    8. When are you planning to buy the system?
    Ans:june 1st week
    Ans:yes
    Ans:Mumbai....i'll buy from lamington
    Ans: suggest me both AMD and Intel i5 rigs. if i go with the intel based rig then i'll buy the graphic card later.
    Anyone?
  2. #2
    SoLa BeLLaToR... RiGOD's Avatar
    Feb 2012
    Migrator
    Default Re: 35k - 40k Gaming PC suggestion
    AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
  3. #3
    May 2012
    Mumbai, Maharashtra
    Post Re: 35k - 40k Gaming PC suggestion
    Suggest an i5 rig without graphic card?
  4. #4
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    The above config is the best in your price range . But IF you increase your budget by 4K you can get Intel I5 2400 + DH67CL B3
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  5. #5
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Exactly. Without graphics card none of the games are playable with HD 2000 IGP of i5 2400.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  6. #6
    May 2012
    Mumbai, Maharashtra
    Can i5 2500k price decrease when IB is available in the market?
  7. #7
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    @OP: go with the config given by RiGOD. Price of 6850 & RAM should belower that the suggested price.
  8. #8
    May 2012
    Mumbai, Maharashtra
    If suppose i Oc an i5 2500k and have a 10-15k graphic card....will Corsair gs600 or Seasonic 520 handle it?
    Quote Originally Posted by d6bmg View Post
    Is i5 2500k possible at 40k budget without gfx card....I'll buy the card later. Please suggest one.
  9. #9
    Apr 2012
    I5 2500K + Asrock Z77 Extreme 4 + CM Hyper 212+ = 25K
  10. #10
    May 2012
    Mumbai, Maharashtra
    Quote Originally Posted by Sainatarajan View Post
    I5 2500K Asrock Z77 Extreme 4 CM Hyper 212 = 25K
    I'm not going to Overclock the processor so quickly my friend..... so i dont need the cooler now.
    And i'm not going for Ivy Bridge, so why go with z77 board?
    can anyone suggest me a good z68 board under 9k.
  11. #11
    defeating my fears..... the_conqueror's Avatar
    Mar 2012
    Kanpur
    Stock cooler is crap, so you might need an aftermarket cooler even without OCing.
  12. #12
    May 2012
    Mumbai, Maharashtra
    Woah i didnt knew it! Even at default clocks 2500k needs an aftermarket cooler :O
  13. #13
    Aug 2011
    Kolkata
    Intel Core I5-2500K @12.2K
    Asus P8Z68-M @9.7K
    G.Skill RipjawsX 4GB DDR3 @1.5K
    WD Caviar Blue 500 GB @4.2K
    Asus DRW-24B3ST @1.1K
    NZXT Source 210 Elite @2.4K
    Corsair GS600 @4K (suggested to accommodate good graphics card in future)
    BenQ G2222HDL @7.5K
    Total: 42.6K
    This the minimum 2500K based config without graphics card. The motherboard suggested is mid end Z68 board, which is good for only mild overclocking (i.e. ~4.2GHz)
  14. #14
    May 2012
    Mumbai, Maharashtra
    What about Asrock motherboards?
  15. #15
    Bon fo Gamin(G) 101gamzer's Avatar
    Aug 2011
    DxB
    They are not for overclocking and not so good
    Gaming RiG comin sooooon..|Acer Aspire 4730z|PSP 3004PB|PSP 3004 GT5 BLACK EDITION|Samsung Galaxy S III 16 GB|Samsung LB530|
  16. #16
    Aug 2007
    Chinchwad Pune
    Btw Don't expect any price cuts. Even if Intel somehow gets kind enough to cut price; the retailers & falling Rupee are not exactly your friends.
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  17. #17
    May 2012
    Mumbai, Maharashtra
    Currently i'm confused with which processor & motherboard i should buy...... I have shortlisted three of them.....i5 2400,amd phenom II 1095t or 960t.
    Please Suggest
  18. #18
    In The Zone dfcols71's Avatar
    Feb 2012
    just fed up people saying asrock are not good for overclocking .please dont post grandiose presumptions without solid evidence
    i 7 2600k/asrock z77 extreme 6 /sg barracuda 1000m003 1tb/corsair 120 gb force 3/asus243bst/corsair hx850/msi 7870 oc tf iii/gskiils sniper1600 2x4gb/nzxt phantom 410/asus ml238h/coolermaster 212 evo/altec lansing br1221/apc 1.1 kva/logitech mk320 combo
  19. #19
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    Quote Originally Posted by Mehul Chauhan View Post
    Please Suggest
    for gaming and overclocking 960t + gigabyte ga 970a ud3 + cm hyper 212 is good but a core i5 2400 + Intel DH67CL will give you much faster performance in games even though the cpu is not OCable.
    If you want a cheap Oc able config for Intel look for a core i5 2500k cpu - around ~12.5k now and a FoxConn/Biostar/Asrock Z75 mobo around ~5.5-6.5k.
    Quote Originally Posted by 101gamzer View Post
    you are wrong about this ... as an example I think you should read this
    ASRock Z77 Extreme4 Review - Introduction
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  20. #20
    May 2012
    Mumbai, Maharashtra
    If those z75 motherboards are good for mild ocing, then i'll be more than happy to buy i5 2500k
  21. #21
    Jul 2006
    Geek's Heaven
    they supports OCing of K series SB/IB cpu for sure but there's still no review of any z75 mobo I could find - so better would be if you can find a review of z75 mobo first or else if you managed to get your hands on a z75 mobo you can write the first review by yourself
    Who Dares Wins
    Avenging Angel !
  1. Need suggestion for gaming rig
    By nieur in forum PC Components / Configurations
    Last Post: 23-06-2011, 04:56 PM
  2. Suggestion to buy Gaming PC
    By lakshesh in forum PC Components / Configurations
    Last Post: 12-05-2011, 11:09 AM
  3. Gaming PC Within 20 - 23k suggestion
    By himanshu978 in forum PC Components / Configurations
    Last Post: 15-11-2010, 10:44 AM
  4. Suggestion for a new gaming rig?Plz.
    By clerkman1612 in forum Hardware Q&A
    Last Post: 19-10-2010, 06:40 PM
  5. GAMING PC SUGGESTION
    By heman12 in forum Gamerz
    Last Post: 07-04-2009, 08:43 PM
