Results 1 to 20 of 20
  1. #1
    Right Off the Assembly Line Raziel's Avatar
    Jul 2011
    Event Horizon
    Wink Pls suggest a better monitor
    Hi guys,
    I'm looking for a LED/LCD monitor for graphic design & a bit of gaming.
    The local computer shop had only these 2 monitors.
    20" SAMSUNG B2030 LCD @ Rs 6500
    20" SAMSUNG S20B300 LED @ Rs 6800
    I picked the LED S20B300. It's contrast is great, but I didn't like the picture quality. It shows color banding and moire pattern even after I adjusted the monitor settings. :/
    What do you think about replacing the LED with the LCD monitor B2030 ?
    Please suggest some other monitors.
    My budget is Rs 8500
  2. #2
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    Default Re: Pls suggest a better monitor
    Dell st2220l @ 8.55k
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  3. #3
    Jul 2011
    Event Horizon
    @Sainatarajan: Thank you for the nice suggestion Added to my list!
    Just waiting for few more answers from the experts here.
  4. #4
    Apr 2012
    Lg e2260v @8.6k
  5. #5
    Alpha Geek masterkd's Avatar
    Feb 2011
    Kolkata
    benq g2222hd @ 7.5k
    i5 2500K|P8Z68 V PRO|560Ti Hawk|G Skill 8GB 1600MHz|SG 500 GB|WD Passport 1TB|TX850V2|690II Advanced|BenQ G2420HD|Razer Cyclosa|Logitech G400|Razer Goliathus|APC 1.1 KVA|TP LINK WR841N WiFi Router|Windows 7 X64|XBOX 360 wireless controller
    Samsung Galaxy Note
    Steam: masterkdxp
  6. #6
    vkl
    vkl is offline
    Super Moderator
    Apr 2012
    benq G2222HDL @ 7.5k
  7. #7
    Jul 2011
    Event Horizon
    Thanks guys for the nice suggestions. I'd like to know which one of these have the best color quality.
    I'm not very familiar with BenQ monitors..Are they of good quality compared to Dell & Samsung ?
    Also a HDMI port would be great to plug in my PS3
  8. #8
    vkl
    vkl is offline
    Super Moderator
    Apr 2012
    If you need HDMI port then go for dell st2220l.
  9. #9
    Feb 2012
    benq G2222HDL is good monitor at its price but no hdmi port on it
    Dell is better ^^ also same benq monitor with hdmi port comes around 8.5k
    so you can check that out too i am sorry i forgot the model no
  10. #10
    Alpha Geek funskar's Avatar
    Sep 2011
    India
    Quote Originally Posted by maddy View Post
    It's Benq GL2250HM wid hdmi port for 8.5k
    ||i5-2500K|Ga Z68xp-Ud4|Ripwas X 8gb|Vx550|Seagate 1Tb+500Gb+250gb|Asus Xonar Dx 7.1|Logitech Z906|Xbox 360 Controller|Haf 922|Ps3|No Gpu
  11. #11
    Jul 2011
    Event Horizon
    DELL ST2220L and BENQ GL2250HM, both looks neat with HDMI.
    Confused between these two...anyway, I'll choose either one of them.
    Thanks guys for all the help
  12. #12
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    My vote will go for Dell ST2220L.
    Its better than that BenQ model IMO.
  13. #13
    Apr 2012
    DELL is the way to go
  14. #14
    Gunner Bodhisatwa's Avatar
    Apr 2012
    Berhampore,West Bengal
    Go wid d dell 1. . after sale service is betr. .
    Amd athlon x2 260 3.8 ghz ocd |4gb starlite ddr3 1333 mhz |Gigabyte GA-ma78lmt-S2p|Xfx Amd Radeon hd 6670 1gb ddr5 |WD caviar blue 500gb |LG flatron l1515s | :-D
    Samsung monte(s5620)|Frontech jil-1731 controller:razz
    sony srs-d4 :-)
  15. #15
    Aug 2011
    Kolkata
    Quote Originally Posted by Bodhisatwa View Post
    Please don't use sms longo. It is very irritating to see them in a forum.
  16. #16
    Apr 2012
    Man,i am using my mobile fr net surfin. . .dats why i have to use it. . .its very iritatin and tym cnsuming fr me 2 type d whole words. . .. .
    sony srs-d4 :-)
  17. #17
    Broken In Saumil996's Avatar
    Sep 2011
    Mumbai
    Exclamation Re: Pls suggest a better monitor
    Try using prediction once you get the hang of it and it gets a hang of you it works like magic.
    @OP
    Anyway I am too going for the DELL and would advise you to go for the same. Benq seems to be having problems in supply chain, someone in the benq supply chain seems to be putting a lower end product in a high end box and two of the forum members have already been affected by it.
  18. #18
    Apr 2012
    Wil give it a try. .
    sony srs-d4 :-)
  19. #19
    Apr 2012
    I am also browsing through my mobile only.
  20. #20
    Jul 2011
    Event Horizon
    Thanks guys,
    I ordered the Dell & waiting for it..& btw, from my experience, if you are a designer then avoid the SAMSUNG S20B300 LED...It's only gud for watching movies..the colors are very harsh..& too much sharp..Witcher 2 and Assassin's Creed graphics looks worse in it..
    The B2030 LCD is far better, but doesn't have a huge contrast like the LED
  1. Suggest a LED Monitor for ~6-8K
    By 008Rohit in forum TVs / Monitors
    Last Post: 16-01-2012, 09:18 AM
  2. Suggest: Monitor & GPU
    By saz in forum PC Components / Configurations
    Last Post: 11-04-2011, 07:02 PM
  3. Suggest A LCD monitor
    By prasannab13 in forum Hardware Q&A
    Last Post: 24-06-2010, 07:46 PM
  4. Suggest me a 19” LCD Monitor
    By abhimi in forum Hardware Q&A
    Last Post: 21-11-2008, 09:33 PM
  5. Suggest a LCD Monitor..
    By raptorz in forum Hardware Q&A
    Last Post: 24-07-2008, 08:19 PM
