Results 1 to 6 of 6
Thread: PC buying advice!!!
15-05-2012, 10:15 PM #1Apprentice
- Join Date
- Mar 2012
- Location
- Bangalore
- Posts
- 62
PC buying advice!!!
*1. What is the purpose of the computer? What all applications and games are you going to run? (Stupid answers like 'gaming' or 'office work' will not work. Be exact. Which games? Which applications? Avoid the word 'et cetera.')*
Ans: Programming, engineering needs, and some gaming like assassin creed, aoe3
*2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.*
Ans: about 35 K
*3. Planning to overclock?*
Ans: Not very soon
*4. Which Operating System are you planning to use?*
Ans: windows 64 bit
*5. How much hard drive space is needed?*
Ans: 1TV
*6. Do you want to buy a monitor? If yes, please mention which screen size and resolution do you want. If you already have a monitor and want to reuse it, again mention the size and resolution of monitor you have.*
Ans: ya 21 inch
*7. Which components you DON'T want to buy or which components you already have and plan on reusing?*
Ans: it's a new PC
*8. When are you planning to buy the system?*
Ans: within a week
*9. Have you ever built a desktop before or will this be done by an assembler?*
Ans: yes I can do that
*10. Where do you live? Are you buying locally? Are you open to buying stuff from online shops if you don't get locally?*
Ans: locally
*11. Anything else which you would like to say?*
Ans: this is my second thread regarding this
My previous config was
Gigabyte Ma78lmt s2p
Amd phenom II x4 955 BE
Seagate barracuda 1TV
G skill 4GB RAM
Gigabyte HD7750 1 GB GDDR5
Benq G2222HDL
Lg DVD rw 24X
Corsair CX430 B2b
Zebronics Bijli cabinet
Amkette classic duo
Altec Lansing bxr 1221
Zebronics 600VA
I want a change in the current motherboard...
And latest pricing...Samsung galaxy fit | Creed's Revolution 3.1
Biostar A880GZ | Amd phenom II X4 960T | Seagate 1 TB
G-skill 4GB | Corsair VS450 | Benq G2222 HDL
15-05-2012, 11:11 PM #2
Re: PC buying advice!!!
You already have a thread right? BTW from where are you planning to get the 955BE?
AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
15-05-2012, 11:16 PM #3Apprentice
- Join Date
- Mar 2012
- Location
- Bangalore
- Posts
- 62
15-05-2012, 11:54 PM #4
I don't think 955BE will be easy to get. Its kind of vanishing from the market..
BTW what do you want from your motherboard ?Spoiler:
15-05-2012, 11:58 PM #5
@OP: about the choice for processor, get 960T. Its still easily available.
16-05-2012, 12:32 AM #6
aftablonely786, from now on please don't create duplicate thread for same purpose. Closing this one; continue on the other one.
AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
Buying Advice of buying a Fridge in 17K ?
By Sainatarajan in forum Consumer electronics and everything elseReplies: 0Last Post: 27-05-2012, 09:36 PM -
Buying advice
By n64freak in forum Laptops and NetbooksReplies: 1Last Post: 27-05-2012, 08:33 PM -
PC buying Advice 45k
By dinu630 in forum PC Components / ConfigurationsReplies: 13Last Post: 18-04-2012, 11:25 AM -
Buying Advice
By The Conqueror in forum PC Components / ConfigurationsReplies: 32Last Post: 25-04-2011, 10:21 PM -
Buying advice for cpu in 8k
By soumya.b in forum PC Components / ConfigurationsReplies: 8Last Post: 13-04-2011, 08:01 AM
LinkBack URL
About LinkBacks
