Results 1 to 15 of 15
14-05-2012, 05:07 AM #1Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 20
PC rig under 60K sans HDD,Speakers,UPS
Ans:WoW(Cata and later MoP), Skyrim, Diablo 3, dragon age series, AC series.
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans:60k (not beyond 61K...though I am spending my own money, I don't want to invoke the ire of my parents)
3. Planning to overclock?
Ans:if needed
4. Which Operating System are you planning to use?
Ans:windows 8
5. How much hard drive space is needed?
Ans:None
Ans:Need one 22"-24" - 1080p will be my fixed resolution, does DVI give better graphics than VGA?
I am considering Benq 21.5" - can get it for 7.4K
Ans:-HDD, UPS, Speakers & Optical Drive.
8. When are you planning to buy the system?
Ans:ASAP
Ans:No - Should I give it a try?
Ans:Hyderabad, willing to buy locally and online too.
Ans: Processor -i5 2500K is my choice - 12K - 12.5K(Don't know the lowest price locally).
MoBo - Z68 or Z77? Will Z77 be future proof (2-3 yrs or is it hoping for a lot?)
I don't need a MoBo with a lot of features - but I might use a wireless desktop card for internet along with the GPU
GPU - Really need help in choosing this one - 7850 Sapphire w/o OC or 7850 Gigabyte OC or 7870 (a guy said he can get me 7870 for 19K)
Open to Nvidia choices too but I don't want a power hungry beast
Is it better to buy a factory OCed GPU and then OC again if needed?
Is the cooling on Sapphire 7870 sufficient to OC a lot if needed?
If not, I could buy a GPU cooler if available, sometime later (and outside this budget)
7850 Sapphire @ 13.8K (same guy as above)
7850 OC Gigabyte @ 15.2K (guess where?
Regardless of my budget limit, I don't want to spend more than 19K for a GPU.
RAM - 2 * 4GB gskill or corsair vengeance (not particular) - 3.2K
Cabinet - CM 430 @ 2.9K in mind
PSU - is over 500W necessary?
Noob Question - Does PSU take 500W even if the machine is idling? If not then what about GPU or CPU? Power in Hyd is very costly - getting bills over 5.6K per month in summer
14-05-2012, 01:36 PM #2
Re: PC rig under 60K sans HDD,Speakers,UPS
Here are my suggestions for you:-
Intel Based
Intel Core i5 2500K @ 12.7K
Thermalright CPU Cooler Ultra 120 Extreme Rev. C @ 3K (primeabgb.com)
Asrock Z77 Extreme 4 @ 10K
G-skill RipjawX 4GB X 2 1600 MHz @ 3.1K
Corsair Carbide 400R @ 4.8K
HD 7870 2 GB GDDR5 @ 19K(as per your channel)
Seasonic SSII12 520W 80+ Bronze @ 3.8K
Logitech G400 Gaming Mouse @ 1.4K
Logiteck K200 Keyboard @ 0.42K
BenQ G2220HDl 21.5" Full HD LED @ 7.5K
(It has DVI input which provides better quality than VGA)
Total ~ 62K.
I think you can some of the components in cheaper price from the chanel you have mentioned and the total cost will be around 61K. There are no Nvidia alternatives available in India at budget within 25K which can provide you the same performance or lower power consumption of HD 7870.AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
14-05-2012, 02:10 PM #3
@ cavalryguard
Mate there are nvidia alternatives like cilus said but none are worth buying at your budget as they are old gen now. Only top end keplers ( worth buying) are available which are out of your budget and they are no power hungry monsters but only monsters.
So 7870 is currently a perfect choice as you get gtx 580 like performance with a much smaller footprint of power.Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
14-05-2012, 02:26 PM #4Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 20
14-05-2012, 03:14 PM #5
^^ For Ram, check Primeabgb.com. For the Asrock motherboard, I am not sure about the shop; probably the shops are some Bangalore based shops. If not available, you can get the Gigabyte or Asus motherboards available within your range.
14-05-2012, 03:58 PM #6Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 20
Thanks again for the reply but if my post is not there then I won't cross my 10 post limit
BTW just found g skill 1600 @ 1526 on Flipkart. It is cheaper than the 1333 MHz one
Could you also answer my question related to power consumption and overclocking 7870 sapphire version?
14-05-2012, 04:52 PM #7
AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
14-05-2012, 06:28 PM #8
for mobos if you want asrock z77extreme 4
contact thes guys sales@mediman.co.in or check out the pricing of msi mbs or gigabyte/asus @
hardwire.inSpoiler:
14-05-2012, 11:33 PM #9Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 20
15-05-2012, 12:38 AM #10
^^ Very good deal, specially 2500K.
15-05-2012, 12:41 AM #11AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
15-05-2012, 01:13 AM #12Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 20
Should I buy Benq 22" LED @ 7.5K or LG E2360V 23" LED @9K.
Is there any good 24" LED around 10K?
Also, what are the criteria when choosing a cabinet other than looks?
Why not buy some cheap desi brand?
16-05-2012, 03:10 PM #13Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 20
ViewSonic 24" LED @ 10.5K in CTC. My current monitor is a 17" ViewSonic which I have been using for 5yrs without any problem. But I heard some say not to go with ViewSonic.
Rest are confirmed -
i5 2500K - 11.8K
Sapphire 7870 - 19K
ASRock Extreme 4 - 9K
GSkill Ripjaws 2*4GB 1600MHz - 3100
Corsair Carbide 400R - 3.9K
16-05-2012, 07:04 PM #14
Where are you getting 400R for 3.9k ? I got it for 5k.
16-05-2012, 07:38 PM #15Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 20
Speakers under 3k
By ricky641b in forum AudioReplies: 3Last Post: 27-07-2012, 12:21 PM -
New speakers
By yash240391 in forum AudioReplies: 1Last Post: 14-05-2010, 06:07 AM -
need 5.1 Speakers @10K
By sriharsha_madineni in forum AudioReplies: 9Last Post: 01-05-2010, 09:50 PM -
2.1 speakers????
By latino_ansari in forum AudioReplies: 4Last Post: 08-03-2010, 12:04 PM -
Can music system speakers used as pc speakers?
By vasulic in forum AudioReplies: 9Last Post: 30-10-2006, 10:40 PM
LinkBack URL
About LinkBacks
