Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 60 of 111
  1. #31
    Omi
    Omi is offline
    -=[-_-]=-
    Jul 2011
    Default Re: Pure gaming RIG Under 50k
    If you main concern is gaming, go with cilus config, its the best
    just replace 1090T by FX8120 (almost same price)
    7870 is a better overclocker and obviously performs better
    and every gaming machine >50K should have it.
    2500k+7850 < FX8120 +7870 in almost 99% games(xcept some games in which lead may not be very much like skyrim(which stresses CPU VERY much also starcraft and civV))
    except that you get much better FPS and also Much better MIN FPS
    OCED 7870 performs very,very close to a 7950
    has chosen to wait for the giant
  2. #32
    Human Spambot pratyush997's Avatar
    Mar 2012
    Is not your concern
    Quote Originally Posted by RiGOD View Post
    ^^That's the best combination for gaming. Get some quality PSU like SeaSonic.
    Please Suggest me any SMPS/PSU soon
    Quote Originally Posted by vickybat View Post
    @ OP
    i5 2500k + z77 + 7870 is a rock solid gaming combo. Try to fit these in your budget as a priority than anything else. Leave them as later upgrades. Even a 7850 will suffice for fullhd.
    Intel Core i5 2500k @11,700
    Radeon HD 7850 @15,000
    ASRock Z77 Extreme 4 @9,100
    4 GB RAM @1000
    SeaSonic S12 II 620W @4600
    FRONTECH JIL 1665 USB 2.0 Keyboard+ mouse @366
    Benq G2222HDL @7500
    I Will get a Local Speakers just to Low down The budget
    And Please Suggest me a Cabinet and check this config
    Quote Originally Posted by Omi View Post
    7870 is 15% faster than 7850 and 33% more expensive and Games runs smoothly on a faster quad core processor than that hexa-core or 8 core cpu with less Speed and 2500k is more powerful than FX 8150
    AnandTech - Bench - CPU
    Burst, S02, lil bit life
    [TUT]AndroVM
  3. #33
    Omi
    Omi is offline
    -=[-_-]=-
    Jul 2011
    What that bench doesn't show is what difference those numbers mean in Frames Per Second (i.e in gaming). You can ask more learned members here, there is hardly any difference in FPS. Heck I've read people running 7870CF on a 1090T!!!
    As you said that this is a pure gaming machine, FPS matters here.
    You also mentioned you are open Ocing, so if you OC 7870 you get very very near to reference 7950, and the difference is no longer 15%.
    And also you save some Bucks
    Rest is all your choice!
    Happy Gaming!
  4. #34
    Mar 2012
    Is not your concern
    Happy Gaming!
    4 GB RAM @1000
    Benq G2222HDL @7500
    Total=>47(Apporx.)
    Is it Worth Getting and buying Omnia w With rest Money
    [TUT]AndroVM
  5. #35
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    The thing is at a specific budget you can't have the same Graphics card if you're going for 2500K over AMD 1090T or FX 8120 because the in case of the later one, the CPU + Mobo around 10K cheaper, which can be inversted to get a good Graphics card. But I'm not clear about the budget, you have mentioned the budget is 65K and in last couple of posts people are suggesting you sub 50K rigs.
    If you look at the config given my be at my previous post, you'll see that I have accommodated HD 7870 at it. If you're going for 2500K then you have to be satisfied with HD 7850.
    Now 1090T + HD 7870 will provide you better performance than 2500K + HD 7850, especially in 1080P resolution. At lower resolution it might be a different story as it becomes CPU dependent on that time.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  6. #36
    Mar 2012
    Is not your concern
    Quote Originally Posted by Cilus View Post
    Initially My Budget was 50k but as to get i5 2500k i thought not to buy Samsung Omnia W and invest that amount of money in getting a Damn. Beast intel Rig
    and I need A Rig which can Able to run Games at 720p resolution, I won't be playing games @more than 900-1000p But if FPS are of games Are more than 60 at the Resolution I May Play @ 1080p and now Can you please tell me How much FPS can I get @ this resolution(720p-1000) while playing GTA 4 and Just cause 2
    [TUT]AndroVM
  7. #37
    Alpha Geek koolent's Avatar
    Oct 2010
    Rawatbhata, Kota, Rajasthan
    If you go for AMD, it will be evn good because of Hybrid CrossfireX, you can combine the power of your CPU and GPU to create super environment for games.
    If you feel like Intel, go for it but I think you should go for AMD. CrossfireX helps and gaming will not require that good CPU. GPU must be good.
    I would recommend :
    AMD GPU + AMD GPU.
    ELSE EXTENDING YOUR BUDGET AND GETTING THIS WILL BE A MONSTER:
    Intel i5 2500k + HD 7870 .
    Intel Core 2 Duo @ 2.8 GHz, Corsair CX430 v2, 3 GB DDR 2 RAM, MSI R6770 MD1GD5 (finally), MSI MS-7525 (v1.0), Compaq W185q 1366 X 768 HD LED Monitor
  8. #38
    Mar 2009
    Kolkata
    more than 60 FPS. And I am not sure where you got that 7870 is only 15% faster than 7850. 7850 performs closer to HD 6970 whereas HD 7870 is just ahead of GTX 580.
    Koolent, none of the AMD 9XX chipset have onboard Graphics an Hybid CFX between the motherboard IGP and dedicated Gfx card is only possible if the Gfx card is a really lower end like HD 5570 or HD 6450. If you plug anything over HD 6670, Hybrid CFx will not work, even with the most powerful IGP 6550D present in AMD llano processor A8-3870/K
  9. #39
    Oct 2010
    Some guy told me about this, don't want to disclose the name but will keep that in mind. Thanks Cilius.
    Now, if OP overclocks the HD 6870, he will get mor potential than HD 6850.. Isn't so ?
  10. #40
    Mar 2012
    Is not your concern
    more than 60 FPS. And I am not sure where you got that 7870 is only 15% faster than 7850. 7850 performs closer to HD 6970 whereas HD 7870 is just ahead of GTX 580./K
    Dear Friend This is the Website..
    http://techforumindia.com/index.php?topic=6592.0
    [TUT]AndroVM
  11. #41
    Oct 2010
    ^^ oohk.. Thnx ..
    Get the i5 RiG now.. ..
    and thanx a lot.. .
  12. #42
    Mar 2012
    Is not your concern
    Quote Originally Posted by koolent View Post
    ^^ oohk.. Thnx ..
    and thanx a lot.. .
    So Friend Should I go for this config:-
    Radeon HD 7870 @22,000
    4 GB RAM @1000
    SeaSonic S12 II 620W @4600<<<Why is this so Expensive
    Benq G2222HDL @7500
    Please Suggest Me Cabinet with gud ventilation
    Total =>55k
    Now Is it a Monster???
    [TUT]AndroVM
  13. #43
    Omi
    Omi is offline
    -=[-_-]=-
    Jul 2011
    YES!
    i52500k+7870 is just best!
    You just forgot to add a decent CPU cooler
    Add Coolermaster Evo 212 for 2000 so you can start overclocking!
    Don't Overclock with the Stock one
    but if there are budget constraints if any, you can go with 1090T anytime to save those bucks(will save around 5k-6k), and get your Omnia W as well
  14. #44
    Mar 2012
    Is not your concern
    YES!
    So is there any features I can get with Intel And not with AMD???? other than gaming???
    [TUT]AndroVM
  15. #45
    Omi
    Omi is offline
    -=[-_-]=-
    Jul 2011
    No, theres nothing like that.
    Cilus and I were suggesting you amd because you had a budget, If cost is not a problem, I or for that mater anyone will never recommend you an AMD CPU.
    Just because In gaming the 1090T or 2500k don't make that much of a difference
    i52500k+7870 is better than 1090T+7870, its only because you mentioned that you need gaming performance for a given amount, the small differences can be ignored.
    I am not supporting AMD, just giving a more Performance/Rupee monster.
  16. #46
    Mar 2012
    Is not your concern
    Thanks bro for config . Can you please suggest me a Cabinet
    [TUT]AndroVM
  17. #47
    Oct 2010
    Ok, that is a monster..
    How much are you willing to spend on a cabinet ??
  18. #48
    Mar 2012
    Is not your concern
    As cheap as possible but not more than 2.5k but it should be ventilated properly.
    Later I will upgrade it
    [TUT]AndroVM
  19. #49
    Oct 2010
    NZXT Source 210 Elite FTW.
    Take a look..
  20. #50
    Sep 2010
    nzxt source 210 is best option for ur budget. and u r finding seasonic s12II 620w for 4.6k expensive. why?
  21. #51
    Mar 2012
    Is not your concern
    Quote Originally Posted by vishurocks View Post
    seasonic s12II 620w is only SMPS/PSU I found so please Advice me a Cheaper one!!!!!!!!!!!!
    Take a look..
    Which is Better???
    NZXT Gamma or NZXT Beta EVO or NZXT Source 210 Elite
    [TUT]AndroVM
  22. #52
    Oct 2010
    CM 212 Beta EVO CPU Cooler you must get it - 2k
    Now for Case, you have a choice, look at pics, all three have same no. of fans.. Take a look at NZXT website and Decide..
    My recommendation goes with NZXT Source 210 Elite but still, take a look.
    Total 4.5k
    Nw you will also get 2-4 fans - 2k (120mm)
    6.5k, awesome cooling for your MONSTER..
  23. #53
    Mar 2012
    Is not your concern
    CM 212 Beta EVO is a CPU Cooler and you must get it - 2k
    Now for Case, Get NZXT Source 210 Elite, Simple and Sober. - 2.5k
    Total 4.5k
    hi BRO NZXT Gamma Looks More Ventilated and attractive too @2.8k Should I Go for it??
    and can you please suggest me any Cheap PSU/SMPS
    [TUT]AndroVM
  24. #54
    Oct 2010
    Ya, you should opt for NZXT Gamma, its a good cabinet..
    How many watts do you want ??
  25. #55
    Mar 2012
    Is not your concern
    I don't have any idea about that but I think 550W should suffice
    [TUT]AndroVM
  26. #56
    Sep 2010
    U have opted for i5 2500k+amd radeon7870 as u hav mentioned. then 600watts will be the recomendation, as it will give u headroom for little upgrades too. 550 watts will suffice too but then the price diff isn't much. and i couldn"t find any 600watts psu for less than 4.6k. seasonic s12II is a good choice
  27. #57
    Mar 2012
    Is not your concern
    Please Give me The Link of any Online store soon
    [TUT]AndroVM
  28. #58
    Oct 2010
    Ya, go for SeaSonic, they provide the best PSUs. I would recommend adding fans as a must
  29. #59
    Mar 2012
    Is not your concern
    As Cabinet Fan:-Flipkart: Cooler Master XtraFlo Cooler: Cooler
    and as Sutom Processor cooler:-Flipkart: Cooler Master Hyper 212 EVO Cooler: Cooler
    But its Price KILLS Seasoic s12II 620 W @4.6k<<<<Should I spend this much for PSU
    [TUT]AndroVM
  30. #60
    Away from Forums, Again! desiJATT's Avatar
    Jan 2012
    Jalandhar, India.
    Yes. That PSU has great reviews and is totally recommended for your system. It's not expensive. The pricing is good. Seasonic S12II 520W is for 4.4k, so you're getting the 600W one for 4.6k, great deal isn't it?
    Review : Samsung Galaxy S3 I9300
    How well will this game run on my Graphics Card
    Gaming Rig
    AMD Phenom X4 960T | Gigabyte GA970A-UD3 | Corsair XMS3 4GB | Gigabyte HD7850 OC | Caviar Blue 500GB | Seasonic S12II 520W | Dell ST2320L | Corsair 300R
  1. New Build (Pure Gaming)
    By sandeep3010 in forum PC Components / Configurations
    Last Post: 07-07-2012, 12:56 AM
  2. Pure gaming pc for 50k
    By iittopper in forum PC Components / Configurations
    Last Post: 13-05-2012, 05:58 PM
  3. pure gaming pc 45k from scratch
    By rajhans in forum PC Components / Configurations
    Last Post: 02-05-2012, 07:26 PM
  4. Pure Gaming Rig.. Nothing Else..
    By dinesh_ddt in forum Hardware Q&A
    Last Post: 28-02-2009, 02:32 PM
