Results 1 to 13 of 13
  1. #1
    Right Off the Assembly Line rajeev bedi's Avatar
    Feb 2007
    lucknow u.p.
    Default External Hard disk showing as raw volume
    Hello,
    I need help..
    I have a WD Passport external hard disk 500gb which was working normally earlier, recently it has started showing as raw Volume 0bytes.
    This is showing normally in media player and Archos Tablet.
    I tried changing volume name and path as described in your one of the post,but in vain.
    Volume is shown in disk manage and device manager
    Thanks and regards in advance
  2. #2
    Nov 2011
    NCR
    Default Re: External Hard disk showing as raw volume
    if it is working correctly with other devices then problem might be with your pc usb port not providing enough power.check on a laptop/other pc & if it works correctly then try back side usb ports on your pc.
    Is God willing to prevent evil, but not able? Then he is not omnipotent.
    Is he able, but not willing? Then he is malevolent.
    Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
  3. #3
    Feb 2007
    lucknow u.p.
    I ma using backside usb only.I tried using 3 different computer, it show the drive letter and 0 bytes raw in properties.
    Device manager shows the device.scanning with antivirus takes no time.
    Virus...?
  4. #4
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    If it is showing Raw then somehow it has been reset to factory setting, might be some vibration or over electricity. The final option is to format it from device manager.
    AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
  5. #5
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Send it for RMA.
    You will lose the data though.
  6. #6
    Feb 2007
    lucknow u.p.
    Why is it working normally with media player and android tablet.
    What is RMA.
  7. #7
    Aug 2011
    Kolkata
    Quote Originally Posted by rajeev bedi View Post
    What is RMA.
    RMA = Return Merchandise Authorization.
  8. #8
    Nov 2011
    NCR
    have you tried accessing it using linux system(live linux bootable cd/pendrive)?you can also try scanning using a data recovery software like recuva.also just to be sure try it on a laptop.
  9. #9
    Aug 2007
    Chinchwad Pune
    Its working with Tablet and not with PC...hmm then I don't think think its a hardware fault.
    Try accessing in Linux if yes then back data up and format it again through Windows.
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  10. #10
    Feb 2007
    lucknow u.p.
    Thanks Guys, you certainly rock.Recovered the data using bootable Linux (Isolinux).
    This forum certainly has the best helping people on this planet.
  11. #11
    Aug 2011
    Kolkata
    And what happened with the drive? Did you RMA it?
  12. #12
    Feb 2007
    lucknow u.p.
    I,ll do do it today.
  13. #13
    Eager to learn. power_8383's Avatar
    Jun 2006
    Nanded
    My WD Essential portable hard disk had gone dead when it was automatically converted to a RAW volume.
    Some things Man was never meant to know.
    For everything else, there's Google.
  1. External hard drive is not showing up in the disk management
    By thecreativeboy in forum Hardware Q&A
    Last Post: 03-08-2012, 06:52 PM
  2. Portable hard disk not showing in my computer
    By ashishkhetriwal in forum Hardware Q&A
    Last Post: 24-07-2008, 04:08 PM
  3. External Hard Disk
    By amrinder.singh in forum Hardware Q&A
    Last Post: 26-05-2008, 09:10 PM
  4. External hard drive not showing a partition
    By mrbgupta in forum Hardware Q&A
    Last Post: 13-03-2008, 06:20 PM
  5. External hard disk
    By blueshift in forum QnA (read only)
    Last Post: 06-09-2007, 07:07 PM
