Results 1 to 16 of 16
  1. #1
    THE CHOSEN ONE Blue Ripazah's Avatar
    May 2011
    New Delhi
    Default INTEL RIG less than 30k
    Ans:HOME PC WITH A BIT OF GAMING
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans: NOT A PENNY MORE THAN 30TRY TO KEEP IT AS LOW AS POSSIBLE
    3. Planning to overclock?
    Ans:NO
    4. Which Operating System are you planning to use?
    Ans: WINDOWS 7
    5. How much hard drive space is needed?
    Ans: 320 GB WILL DO BUT I THINK 500GB WILL BE A BETTER OPTION
    Ans: YES (19-22 ") WHATEVER FITS THE BUDGET
    8. When are you planning to buy the system?
    Ans: TOMOROOW
    Ans: ASSEMBLER
    Ans: DELHI WILL BUY FROM NEHRU PLACE ( PLEASE SUGGEST SOME GOOD SHOPS)
    ans; TRIED BANGING MY HEAD AGAINST THE WALL BY CONVINCING FOR AMD BUT STILL MY UNCLE IS STUCK ON INTEL .....SO STRICTLY INTEL RIG
    Intel i3 540|| Gigabyte H55M D2H || 2x2gb corsair value Ram|| :doublethumb: Saphire Hd 6670 :doublethumb:||:mrgreen: Samsung B2230 :mrgreen: || 500 GB Seagate || 80 Gb Seagate|| IBall 7299||Gsm Insipre 500 watt :banghead:||Creative A 300 with philips speakers ||Sony dvd rw|| Samsung Galaxy Ace 8-)||
  2. #2
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Default Re: INTEL RIG less than 30k
    Intel Pentium G620 @ 3.2K
    Gigabyte GA-H61M-D2H @ 3.2K
    Corsair Value Select 4GBX1 1333 MHz DDR3 @ 1.1K
    WD Blue 500 GB HDD @ 4.2K
    Corsair CX 430 V2 @ 2.3K
    Normal Cabinet from Intex/Frontech @ 0.7K
    Amakette Classic Duo Keyboard & Mouse @ 0.4K
    LG 22X DVD Writer SATA @ 0.85K
    Acer V193HQ 18.5" Display @ 4.8K (from One Page Price List)
    Zebronics 600VA UPS @ 1.2K
    MSI HD 6670 1 GB GDDR5 @ 5.2K
    Total: 27.15K
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  3. #3
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    Intel Core I3 2100 + DH61WW @ 9.5K
    CORSAIR value Select 4 GB @ 1K
    ASUS DVD ROM @ 1K
    DELL 20" DVI LED Monitor @ 5K
    SEAGATE 500 GB HDD @ 4K
    Key + Mouse + Speaker 2.1 = 2K.
    CORSAIR CX430 V2 = 2.2K
    CM Elite 310 = 1. 8K
    HIS HD 6770 @ 6.5K
    NUMERIC 600 VA UPS @ 1.5K
    TOTAL @ 30.5K
    You have not Mentioned Which Component you do not want or plan to reuse.
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  4. #4
    May 2011
    New Delhi
    Quote Originally Posted by Sainatarajan View Post
    ASUS DVD ROM @ 1K
    HIS HD 6770 @ 6.5K
    TOTAL @ 30.5K
    I am building a new rig
  5. #5
    May 2011
    New Delhi
    Quote Originally Posted by Cilus View Post
    Total: 27.15K
    Will corsair vs 450 be equivalent to cx430 bcoz cx430 will be hard to find as
    We are not open.for online purchase
  6. #6
    Apr 2012
    Go wid the config I have given. Great Performance.
  7. #7
    Mar 2009
    Kolkata
    ASUS DVD ROM @ 1K
    HIS HD 6770 @ 6.5K
    TOTAL @ 30.5K
    Sainatarajan, OP has clearly mentioned that his budget is no more than 30K. So why suggest him a rig which is almost 5K over his budget? Just writing
    TOTAL @ 30.5K
    doesn't make it a 30K rig, recalculate it, it's coming around 34.5K.
    Blue Ripazah, if you can extend your budget then the above config is the best but you've mentioned that you can't spend not a penny more than 30K. If that is the case then go with my suggestion. If you're unable to find CX 430 V2 locally then you can try Online shops like Theitwares, smcinternational.in etc. Otherwise you can get VS 450 which is enough for my suggested rig.
    I can suggest you one change in my rig: Get a Core i3 2100 @ 6K. The total will be (27.15 - 3.2 + 6)K = 29.95K ~ 30K
  8. #8
    May 2011
    New Delhi
    Sainatarajan, OP has clearly mentioned that his budget is no more than 30K. So why suggest him a rig which is almost 5K over his budget? Just writing doesn't make it a 30K rig, recalculate it, it's coming around 34.5K.
    thnx i think your config is the best alternative will be going for i3 2100
  9. #9
    Apr 2012
    Sorry everybody . I miscalculated. At 30K , its very Difficult.
  10. #10
    Firecracker to the moon theserpent's Avatar
    Nov 2011
    Mangalore
    @blueripazah why dont you reuse some items like YOUR 500gb HDD?
    A girl is someone who eyes an Iphone,wants a S3,Read's all good about Xperia and LG but at last ask's her Noob friend how is micromax and buys it
    Gadgets/Gaming RIG
    HD 7750||Nexus 10 :) || Canon Sx150 || Ipod touch 4g|| Sound magic es18
  11. #11
    Apr 2012
    You could get a generic case for Rs 600 and a normal 2.0 Speaker for Rs 300. So - 2.2k - Rs 300 discount - 1.3K for gfx card.
    total 30.7K
    HD 6670 will be ur card.
  12. #12
    Wise Cold Ghoul Piyush's Avatar
    Feb 2010
    GZB.
    30K.. no problem
    Intel i3 2100 + Gigabyte GA-H61M D2H @ 9.5k
    2gb DDR3 1333Mhz @ 0.6k or 4gb @ 1.1k
    Generic Case without PSU @ 0.5k
    WD 250GB/500GB @ 3.6k/4.3k
    LG 22X DVD Writer SATA @ 0.8K
    Generic KB/Mouse combo @ 0.6k
    Monitor Dell 20" 1600*900 @ 5.4K
    NUMERIC 600VA UPS @ 1.5K
    MSI HD 6670 @ 5.2k
    TOTAL=30K(with 2gb RAM and 250GB HDD)
    TOTAL=31.2K(2ith 4gb RAM and 500GB HDD)
  13. #13
    Nov 2011
    Mangalore
    @Piyush 5.2k for 6770 ?
    It must be 6670
    Gadgets/Gaming RIG
  14. #14
    Feb 2010
    GZB.
    Quote Originally Posted by serpent16 View Post
    It must be 6670
    its 6670
    you must have read it wrong
    or I was fast enough to edit it first
  15. #15
    Nov 2011
    Mangalore
    ^ Dafuq.It was 6770 .I was shocked
    Gadgets/Gaming RIG
  16. #16
    May 2011
    New Delhi
    Its not for me ...its for my uncle's son and he is not having any item thar can be reused
  1. Replies: 1
    Last Post: 29-03-2011, 10:02 PM
  2. Replies: 3
    Last Post: 17-03-2010, 02:09 PM
  3. Replies: 1
    Last Post: 19-10-2008, 10:25 PM
  4. Replies: 1
    Last Post: 06-03-2008, 05:03 PM
  5. Replies: 8
    Last Post: 03-03-2008, 10:53 PM
