Results 1 to 16 of 16
01-05-2012, 10:47 PM #1Right Off the Assembly Line
- Join Date
- Jun 2011
- Location
- Kolkata
- Posts
- 24
PC upgradation.....budget ~32k-33k
Ans:mostly for gaming,hd movie viewing & some photoshop works
games like crysis 2,BF3,Skyrim,Rage,Modern warfare 3 will be played in mid high settings
2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
Ans:32-33k.
3. Planning to overclock?
Ans:No
4. Which Operating System are you planning to use?
Ans:Windows 7 ultimate
5. How much hard drive space is needed?
Ans:Already have Seagate 500GB+1 Tb external+320 GB external
Ans:Yes...22" full HD 1920*1080
Ans: CASE(already have CM Elite 310)
GPU(already have Sapphire HD Radeon 6850)
HDD(already have 500 GB seagate Barracuda)
Mouse(already have Razer Abyssus)
Keyboard(already have Razer Arctosa Black)
PSU(already have Coolermaster extreme 600W!!!should I replace this?)
UPS
Speaker(already have Altec lansing VS4121)
8. When are you planning to buy the system?
Ans:By 31st May,2012
Ans:By me and a friend .I have built before.
Ans:Kolkata...buying locally....sorry not open to buy online.
Ans:
Will your suggested CPU need additional cooler or stock cooler will be fine??
The psu I posses has dubious reputation....should I consider replacement??...
I need mobo,proccy,RAM & monitor...and maybe a psu!!
33 K max
Thanx in advance!
01-05-2012, 11:37 PM #2Professional Newbie
- Join Date
- Apr 2012
- Location
- At Home : 22.5697° N, 88.3697° E
- Posts
- 372
Re: PC upgradation.....budget ~32k-33k
I can think of 3 combinations for you:
Intel i5 2400 (Rs 11000)+ Intel DH67CL(Rs 5600)+Corsair Value RAM 4GB(Rs 1200)+ Seasonic S12ii-520(Rs 3700) + Dell ST2220M (Rs 8000)= Rs 29500
Intel i5-2500k (Rs 12750) + Biostar TZ68K+ (Rs 7235) + G.Skill RipjawsX 4GB (Rs 1500) + Seasonic S12ii-520(Rs 3700) + Dell ST2220M (Rs 8000)= Rs 33185
Intel i5-2500k (Rs 12750) + ASRock Z77 Extreme 4 (Rs 9880) + G.Skill RipjawsX 4GB (Rs 1500) + Seasonic S12ii-520(Rs 3700) + Dell ST2220M (Rs 8000)= Rs 35830
The last config is really recommended but if it's simply not affordable then you might skip the PSU for now as your GPU is not that power hungry and neither are these SB chips. Though don't try overclocking with it.
02-05-2012, 10:03 PM #3Right Off the Assembly Line
- Join Date
- Jun 2011
- Location
- Kolkata
- Posts
- 24
^^^^Thanks
02-05-2012, 10:48 PM #4
Yes you should replace you Cooler Master 600W,As you might end up burning your Computer with i5+6850.
Better get a seasonic or corsair 500-600w.
As CM extreme 600W is not 80+ certified and its underpoweredGadgets/Gaming RIGA girl is someone who eyes an Iphone,wants a S3,Read's all good about Xperia and LG but at last ask's her Noob friend how is micromax and buys it
HD 7750||Nexus 10 :) || Canon Sx150 || Ipod touch 4g|| Sound magic es18
02-05-2012, 11:13 PM #5
keep the PSU but don't overclock anything. Go for the last config. overclock it later when you feel your processor is slow. of course, change PSU then for the safety of your own PC. but this won't happen for another 2-3yrs for sure
02-05-2012, 11:29 PM #6Right Off the Assembly Line
- Join Date
- Jun 2011
- Location
- Kolkata
- Posts
- 24
thanks @sam & @serpent16
@serpent16 Precisely...I am thinking about keeping my psu(As It's only 6 months old and doing fine on E7500+6850.....ran games with high settings) for some time and then change it later....
Another thing...Do I need a cpu cooler to safely run my i5??or the stock cooler will be fine??
03-05-2012, 12:10 AM #7
03-05-2012, 09:39 AM #8
03-05-2012, 09:47 AM #9
Actually, no unless you are overclocking quite a bit.. It will work on just the edge.. I will recommend you get Corsair GS600 as its 80+ Certified and will give you overclocking potential
03-05-2012, 10:13 AM #10
No. If no overclocking is done, that too, for just a peace of mind, then there will be absolutely no problem with his system.
It won't "work on the edge". This certainly means that the GS600 you are recommending is also of no use coz his system will be using like 600W?
i5+6850 build takes at MAX 350W. So his PSU is not getting overloaded. No need to change it.
Seriously people have to stop "hating" on some PSUs just because they are considered somewhat lower class. Practically the scenario is always different and we should advice keeping that in mind. "Changing" is not always the option.Review : Samsung Galaxy S3 I9300
How well will this game run on my Graphics Card
Gaming Rig
AMD Phenom X4 960T | Gigabyte GA970A-UD3 | Corsair XMS3 4GB | Gigabyte HD7850 OC | Caviar Blue 500GB | Seasonic S12II 520W | Dell ST2320L | Corsair 300R
03-05-2012, 12:10 PM #11
His PSU, eh.. Lets take can kick 420W as it can take 70% effieciency. Now if he overclocks a bit, its A-OK. What if he seriously overclocks (Quite a bit) to be precise, and too his CPU and GPU, he will have to change his PSU.
Try to understand others befor DOMINATING their openions, please, sorry if that language ws not understood, will write simpler next time.Spoiler:
03-05-2012, 04:41 PM #12
koolent, are you calculating the power provided by a 70% efficient PSu like this: 430W X 70% = 430X70/100 W = 301 W and telling it can't provide enough power when overclocked. If yes then it is completely wrong.
If a PSU is true 430W then it can provide 430W power all the time within its working temparature irrespective of its effeciency. Efficiency means the amount of power the PSU takes from the home circuit to provide the rated power. So if a 430W PSU is 70% efficient then and it takes P Watt power from your switch board then
P X 70% = 430 -> P = 430X100/70 = 614.3W
So it will take around 614W power from the circuit to provide 430W power. Better efficiency means less power consumption, not higher power output.AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
03-05-2012, 07:02 PM #13
03-05-2012, 10:09 PM #14Right Off the Assembly Line
- Join Date
- Jun 2011
- Location
- Kolkata
- Posts
- 24
Thank you for all your support guys...
@Cilus I see that you live in kolkata...can u point out a shop which store G Skill Ripjaw RAMs??I am having a hard time finding that in chandni market,kolkata
04-05-2012, 12:47 AM #15
They are available in M.D. Computer, Kolkata.
Call @ 09830581667 to Mr. Palash who is the incharge of gaming section. Tell him that you got the price of 3.1K fro the 8 GB 1600 MHz from Digit forum. He is well aware of our forum.AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
04-05-2012, 08:04 PM #16Right Off the Assembly Line
- Join Date
- Jun 2011
- Location
- Kolkata
- Posts
- 24
^^^^Thanks a lot!
cpu upgradation help
By im.h.s in forum PC Components / ConfigurationsReplies: 4Last Post: 10-06-2012, 12:15 PM -
upgradation help needed with a budget of 10000
By Ronnie11 in forum PC Components / ConfigurationsReplies: 8Last Post: 02-06-2011, 07:57 PM -
Upgradation Budget dependent on sale
By shwetanshu in forum Hardware Q&AReplies: 6Last Post: 12-06-2010, 12:38 AM -
Ram Upgradation
By cool_kals9 in forum Hardware Q&AReplies: 4Last Post: 01-02-2009, 08:51 PM -
Upgradation pls help me?????????????
By rahulbalmuri in forum Hardware Q&AReplies: 5Last Post: 04-05-2007, 09:06 PM
LinkBack URL
About LinkBacks
