Results 1 to 6 of 6
  1. #1
    Apr 2012
    Default Multi-Purpose Build (र 40, 000)
    1. What is the purpose of the computer?
    Productivity (Unity3D, 3DSMax, Video Editing) & Gaming
    2. What is my budget?
    Rs. 40, 000 to Rs. 45, 000
    3. Am I planning to overclock?
    Yes
    4. Which OS am I planning to use?
    Windows 7 w/ Arch Linux
    5. How much storage space do I need?
    A terabyte or two
    6. What don't I need?
    A Monitor. Already have this one.
    7. Have I built a desktop before?
    Indeed, I have.
    8. Where do I live? Will I be buying online?
    I live in Chennai. Yes, I will be buying all parts online, from FlipKart to be exact. So please, do use it as reference.
    I've had my eyes on the tri-module Bulldozer (FX 6100) for quite a while now. It seems to suit my needs best and me being an AMD Fanboy is perhaps another reason. But at the end of the day, I'm willing to give-in to a better processor, if it justifies my needs.
    I guess that's all I have to say. I'm looking forward to your swell suggestions (and proper citation to sources that influenced your decisions would be nice too).
    Thanks!
  2. #2
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Default Re: Multi-Purpose Build (र 40, 000)
    1st of all, a big no to Bulldozer, especially FX 6100. In performance it is behind 1090T and in gaming performance, it is behind Phenom II X4 processors.
    AMD Phenom II X6 1090T @ 9K
    Gigabyte GA-970A-UD3 @ 6.6K
    G-skill RipjawX 1600 MHz DDR3 @ 1.5K
    Seagate 1 TB HDD @ 5.4K
    CM Elite 370 @ 2K
    Seasonic S12II 520 @ 3.7K
    Amakette Classic Duo Keyboard & Mouse Combo @ 0.4K
    Altec Lancing BXR 1221 Speaker @ 1.1K
    Sapphire HD 7850 2 GB GDDR5 @ 15.6K
    total around 44.5K.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  3. #3
    Apr 2012
    Chennai, Tamil Nadu
    7850s aren't available on FlipKart. I've checked with local dealers, no-one seems to have it, yet.
    The tri-modules aren't that big a disappointment. I've read a few favorable reviews, notably on their performance in productivity suites. Let me add that gaming isn't top priority. I just need to have something that'll game decently.
    What about a Sandy Bridge alternative? Could you list a build under that configuration.
  4. #4
    defeating my fears..... the_conqueror's Avatar
    Mar 2012
    Kanpur
    SB alternative:
    Intel DH67CL(b3) @ 5k
    Intel core i5 2400 @ 11k
    1.5K
    Seagate 1 TB HDD @ 5.2K
    CM Elite 370 @ 2K
    Seasonic S12II 620 @ 4.7K
    Mouse Combo @ 0.4K
    @ 1.1K
    Total ~ 46k
    For sapphire hd 7850, you should contact the distributor of it in your area. He will give you the correct info. It is Aditya infotech in Lucknow. Don't know about Chennai. Go for Sapphire HD 6950 2 GB version for same amount if you are unable to find HD 7850.
  5. #5
    SoLa BeLLaToR... RiGOD's Avatar
    Feb 2012
    Migrator
    Configuration suggested by Cilus is the one to go for. Push you budget a bit more and grab Seasonic S12II 620 & NZXT Source 210 Elite.
    AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
  6. #6
    Wise Old Owl a_k_s_h_a_y's Avatar
    May 2007
    bangalore
    for professional use, again throw in 8 gig of rams... minimum that is.
    Sony Ericsson Flashing, Modding, Patching, Hacking And More !
    http://www.akshayy.com/sonyericsson/
  1. Multi purpose PC for 45K
    By saratdear in forum PC Components / Configurations
    Last Post: 22-06-2012, 01:54 AM
  2. Multi-purpose build upgrade
    By PentiumD in forum PC Components / Configurations
    Last Post: 13-05-2012, 05:04 PM
  3. multi purpose desktop
    By choudang in forum PC Components / Configurations
    Last Post: 24-02-2011, 04:26 PM
  4. New Multi purpose rig
    By robbinghood in forum PC Components / Configurations
    Last Post: 02-08-2010, 01:30 PM
  5. Multi-Purpose Build - 60k Budget
    By Mystic in forum Hardware Q&A
    Last Post: 22-06-2010, 11:05 PM
