Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 30 of 134
  1. #1
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    Default Configuration for Rs 50000 Gaming Build !!!
    Hi guys , I need a good gaming Pc that will last for minimum 4 to 5 Years !!!
    1. What is the purpose of the computer?
    What all applications and games are you
    going to run?
    ANS:- Mainly Gaming . Games like BF3, Crysis 2 , GTA 5 , Max Payne 3 , Dirt 3 , FIFA and Pes 12 , NFS the Run , COD4 , Assasins Creed 3 . Browsing web , Listening Music , Running small Softwares .
    2.What is your overall budget? If you can
    extend a bit for a more balanced
    configuration, then mention this too.
    Ans- 45K to 50K
    3. Planning to overclock?
    ANS - NO !
    4. Which Operating System are you
    planning to use?
    Ans windows 7 ultimate.
    5. How much hard drive space is needed?
    Ans- 1 TERABYTE
    6. Do you want to buy a monitor?
    Ans- I want to buy a full HD 22" monitor .
    7. Which components you DON'T want to
    buy or which components you already have
    and plan on reusing?
    Ans: I need a complete system.
    8. When are you planning to buy the
    system?
    Ans: ASAP
    9. Have you ever built a desktop before or
    will this be done by an assembler?
    Ans: I have built a desktop before.
    10. Where do you live? Are you buying
    locally? Are you open to buying stuff from
    online shops if you don't get locally?
    Ans:
    11. Anything else which you would like to
    say?
    Ans: Dont waste money on Ups.
    A normal ups for Rs 1500 will be fine. Also a normal speaker for 1K will be enough.
  2. #2
    d3p
    d3p is offline
    PowerHouse d3p's Avatar
    Jan 2010
    Bangalore
    Default Re: Configuration for Rs 50000 Gaming Build !!!
    Here goes my suggestions. Adjust with 500GB. Upgrade to 1TB later, when the price of HDD falls.
    2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
    My Game Collection & Sapphire HD 7970 Unboxing
  3. #3
    Apr 2012
    Does the motherboard you suggested supports USB 3.0 ?
  4. #4
    Human Spambot MegaMind's Avatar
    Nov 2010
    Perambalur, TN
    Quote Originally Posted by Sainatarajan View Post
    Yes it has 2*USB 3.0 ports..
    i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
  5. #5
    Apr 2012
    Can you also suggest me a good AMD Rig ?
    I think intel is too costly.
  6. #6
    d3p
    d3p is offline
    Jan 2010
    Bangalore
    Just replace the processor & Motherboards.
  7. #7
    Apr 2012
    Will the processor and motherboard last for atleast 4 Years.
  8. #8
    d3p
    d3p is offline
    Jan 2010
    Bangalore
    Will you be alive for next 4 yrs ??? Future is unpredictable.
    This gaming rig will able to play the recent games at higher settings, but i'm not sure upcoming gaming, how are they going to react. But still then you will able to get playable frame rates.
  9. #9
    SoLa BeLLaToR... RiGOD's Avatar
    Feb 2012
    Migrator
    Quote Originally Posted by d3p View Post
    >Get a better UPS like Intex 1KVA. This one won't offer backup.
    >The GS 600 costs around 4.3k now. Get Seasonic S12 II 520 for 3.7k.
    >For AMD get AMD Phenom II 955 + Gigabyte MGA-970A-UD3 and change the case to NZXT Source 210
    Elite.
    EDIT : @d3p-Saw your post just now buddy.
    AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
  10. #10
    Nov 2010
    Perambalur, TN
    ^^If planning on using for some years, intel will be the better option..
  11. #11
    Feb 2012
    Migrator
    ^^Why so? The SNB architecture vs outdated Phenom architecture you say?
  12. #12
    Nov 2010
    Perambalur, TN
    Quote Originally Posted by RiGOD View Post
    Ya & also Since OP's purpose is gaming, no OCing, i5 2400 is a clear winner..
  13. #13
    Apr 2012
    My budget has been increased to 60K !!!
    I5 3570K , any good board , 8 GB RAM , 1 TB HDD , DVD ROM , 22" LED HD Monitor , microsoft key + mouse , NZXT Lexa S , creative 2.1 speaker, seasonic 520w . HD 7850. Is this a good Build . Can HD 7850 play games at high to ultra settings
  14. #14
    Feb 2012
    Migrator
    ^^AFAIK the SNB's are better OC'ers than IVB's. So get the i5-2500k+ASRock Z77 Extreme4. And yes, the HD7850 can max out almost all games at Full HD resolution.
  15. #15
    Professional Newbie
    Apr 2012
    At Home : 22.5697° N, 88.3697° E
    @Sainatarajan the things you have isted will cost more than 10k to upgrade.
    In the config that d3p has suggested get these parts instead:
    i5 2500k
    ASRock Z77 Extreme 4
    NZXT Lexa S
    This will increase your total by around 10.5k
    Stay with the Corsair GS600 as you will need the extra power for overclocking.
    If you want 8GB RAM then go for Corsair vengeance LP 8GB kit for 2.5k or GSkill RipjawsX 8GB kit for 3000. Or if you're happy with value RAM then just add another stick of the 1.1k RAM suggested to you. Also the monitor suggested is a 22" LED Full HD monitor.
  16. #16
    d3p
    d3p is offline
    Jan 2010
    Bangalore
    ^^ How can you suggest OP to get a unlocked K Processor, when he don't want to OC ??
  17. #17
    Professional Newbie
    Apr 2012
    If someone has a budget of 60k for a PC then why wouldn't you suggest the best option. Also even if you read OP's latest post you'll say that he himself wants the 3570k CPU so I simply recommended it's SB equivalent.
  18. #18
    Apr 2012
    Is the CPU Performance of I5 2500K and I5 2400 same ?
    Does sandybridge support PCI 3.0 ?
  19. #19
    d3p
    d3p is offline
    Jan 2010
    Bangalore
    ^no.
    2400 << 2500k << 3570k
  20. #20
    Apr 2012
    Will the performance get affected If I put a PCI 3.0 x16 GFX card in PCI 2.0 x16 slot?
  21. #21
    Nov 2010
    Perambalur, TN
    2400 vs 2500k
    sandybridge CPUs doesn't PCI 3.0..
    No..
  22. #22
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    d3p, I think 2500K is more suitable here because it is quite clear that OP needs the system for long run. "I'll never overclock" thing might last for 1 years/1.5 years but after that OP can learn it and get some extra performance boost through overclocking.
    I used to have a AThlon X2 3800+ and didn't overclock it until 1.5 Yrs of the purchase. Then I started like hell.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  23. #23
    Feb 2012
    Migrator
    ^^You're right. The i5 2400 will wipe the floor with any Phenom BE out there. But in the long run, considering the OC'ing potential of the latter, I guess it would be a wise choice to go for it. If OP is planning to go for Intel, then it'll be the i5 2500k. Its always better to have something OC'able in a gaming rig
  24. #24
    d3p
    d3p is offline
    Jan 2010
    Bangalore
    If OP can increase his budget & gaming is the only purpose. In that case i would suggest him a Better Cabinet, PSU, either 7850 CF or 6950 CF with AMD 960 or 970 BE.
  25. #25
    Apr 2012
    Oh my god !!! CROSSFIRE is CROSSFIRE a good setup instead of a single card.
  26. #26
    Nov 2010
    Perambalur, TN
    ^^definitely..
  27. #27
    Feb 2012
    Migrator
    Phenom II 970 + Gigabyte MGA-970A-UD3 + SeaSonic SS-750JS + 6850 CF ~ 37.3k
    Gaming DNA Unleashed
  28. #28
    Nov 2010
    Perambalur, TN
    ^^But OP's budget is 45 - 50k
  29. #29
    Feb 2012
    Migrator
    ^^Yeah, was just suggesting. BTW I find that ASUS board, CM Case & iBall UPS really misfitting. Gigabyte MGA-970A-UD3, NZXT Source 210 Elite & Intex 1KVA would be better alternatives.
  30. #30
    Nov 2010
    Perambalur, TN
    Asus M5A97(4+2 phase) - 6K
    Gigabyte MGA-970A-UD3(8+2 phase) - 6.5K
    M5A97 is a great OCer, a guy in hwbot was able to OC 955BE to 4.6GHz..
    Source 210 Elite & Intex 1KVA will add extra bucks..
  1. Gaming PC @50000
    By Drajai in forum PC Components / Configurations
    Last Post: 14-12-2011, 07:31 PM
  2. 50000 Rupees PC build
    By chirag1303p in forum PC Components / Configurations
    Last Post: 31-10-2011, 08:26 PM
  3. Help for Gaming pc under Rs 50000
    By varunoverhere in forum PC Components / Configurations
    Last Post: 09-11-2010, 10:42 PM
  4. Gaming pc under Rs 50000
    Last Post: 29-10-2010, 07:03 PM
  5. An Ultimate Gaming Mchine For 50000
    By killzone in forum Hardware Q&A
    Last Post: 21-10-2006, 10:47 PM
