Results 1 to 16 of 16
Thread: PC upgrade (not a new rig)
20-04-2012, 11:07 PM #1AMD - Aaja Meri Darling
- Join Date
- Sep 2009
- Location
- Aapnu Amdavad, Gujjuland.
- Posts
- 132
EDIT EDIT
i've already updated my rig with the following components in bold
Updated Spec:
AMD athlon X4 620
M4A785TD-V EVO
Transcend 1333 (9-9-24) DDR3 Ram (2x2gb)
Corsair value select 1333 DDR3 ram (4x2 gb)
Gigabyte HD7770 1GB DDR5 (yet to arrive)
3x 1TB WD Caviar blue
Coolermaster Real Power Pro 460W (80+ bronze cert.)
Viewsonic VS213239 22" Full HD (LED)
NZXT Lexa S cabinet
Now my query is just one
Which cpu cooler can I go for that will fit in the Lexa S cabinet that isn't noisy as the stock cooler that came with the AMD Athlon II X4 620 ?Last edited by Xeno; 28-04-2012 at 01:58 PM.
AMD Athlon II X4 620 | ASUS M4A785TD-V EVO - 785G
20-04-2012, 11:21 PM #2Professional Newbie
- Join Date
- Apr 2012
- Location
- At Home : 22.5697° N, 88.3697° E
- Posts
- 402
Re: PC upgrade (not a new rig)
Xeno bhai only 1 thing wrong with your post. You forgot to mention one tiny detail that changes everything. What's that? Your budget
20-04-2012, 11:23 PM #3AMD - Aaja Meri Darling
- Join Date
- Sep 2009
- Location
- Posts
- 132
Ohhh sorry
I thought I had written it. Should have read it before I posted it.
Budget is 10-12k max
21-04-2012, 11:14 AM #4Professional Newbie
- Join Date
- Apr 2012
- Location
- Posts
- 402
GPU: Gigabyte HD 7770 Rs 8400
GIGABYTE GV-R7770 5-1GD
RAM: Corsair Value RAM 4GB Rs 1216
Flipkart: Corsair DDR3 4 GB (1 x 4 GB) PC RAM (CMV4GX3M1A1333C9): Ram
CABINET: Cooler Master Elite 311 Rs 2190
Flipkart: Cooler Master Elite 311 Mid Tower Cabinet: Cabinet
Total Rs 11806
21-04-2012, 11:38 AM #5
Replace Your CM PSU with Corsair CX500(Recommended) or Corsair CX430V2.
Your Huge HDD setup needs a good PSU + Your new GPU too!
For GPU- 7770 or Cyclone 6850.Last edited by Sujeet; 21-04-2012 at 12:03 PM.
HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
Samsung Galaxy Tab 2 |7.0 P31000
21-04-2012, 11:52 AM #6
21-04-2012, 09:43 PM #7AMD - Aaja Meri Darling
- Join Date
- Sep 2009
- Location
- Posts
- 132
The CM Real power pro 460w is a 80+ bronze rated smps. Not to confuse with the extremepower series which have rather shoddy reliability.
Thank you for the inputs, however finally decided on the following components.
NZXT Lexa S case ( 5635/- including shipping and a CM 140mm fan)
Initially was considering the Gamma however it comes only with one fan, while this case comes with 4 included.
Cooling is pretty much a priority as temps in Ahmedabad are quite hot most of the year.
(ordered from primeabgb)
MSI R6670 1GB DDR5 (5822/-)
for a mid range card, does quite well while not requiring me to change my SMPS (for now)
(ordered from flipkart)
Corsair CMV4GX3M1A1333C9 DDR3 4GB x 2 (2432/-)
since i dont plan to OC, pretty much suits what I need.
(ordered from flipkart)AMD Athlon II X4 620 | ASUS M4A785TD-V EVO - 785G
21-04-2012, 10:08 PM #8
my sapphire 6670 1 gb ddr5 costs 5100 at kolkata.
NZXT PHANTOM WHITE+3INTAKE 2EXHST|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 1GB DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1+1 TB|LOGITECH G110|APC 650 VA|+WD MY PASSPORT 3.0 1 TB
27-04-2012, 10:25 PM #9AMD - Aaja Meri Darling
- Join Date
- Sep 2009
- Location
- Posts
- 132
Well, flipkart couldn't process the order for Msi HD6670
So now upscaled the budget and ordered the Gigabyte HD 7770 1GB from the theitwares
Additional info
When I was installing the 4GB corsair value select ram on my asus m4a785td-v-evo the board at first wouldn't recognise it and pc failed to startup.
Updated the bios to ver 2105 and flashed it in bios using Asus ez-flash.
now im running 4x2Gb corsair in one channel and 2x2GB transcend in the other channel.AMD Athlon II X4 620 | ASUS M4A785TD-V EVO - 785G
27-04-2012, 10:33 PM #10Professional Newbie
- Join Date
- Apr 2012
- Location
- Posts
- 402
Ohh. Anyways now that things are working good jalsa chhe tamne
27-04-2012, 10:45 PM #11AMD - Aaja Meri Darling
- Join Date
- Sep 2009
- Location
- Posts
- 132
Arey dada ami bangali, kintu gujarat e thakee
also... while my cpu is staying prefferably cool enough, I don't like the stock cooler that came with this cpu as its very noisy when the fan runs at full speed. Any cheap alternatives that aren't noisy enough and will keep it cool ? Although the CM Hyper 212 evo seems a very good buy I have doubts that it will fit in my case as it seems 16 cms tall
27-04-2012, 11:06 PM #12Professional Newbie
- Join Date
- Apr 2012
- Location
- Posts
- 402
LOL me the opposite case. Hu gujju but Kolkata ma rahu chhu
You can try Cooler Master Vortex Plus. But I'm not so knowledgeable about CPU cooler so other members please help out OP.
28-04-2012, 09:33 AM #13
You can get the NZXT LEXA S for only 4.3K at here
Theitdepot - NZXT Lexa S Mid-Tower Black Gaming CabinetsIntel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
28-04-2012, 11:47 AM #14Wise Old Owl
- Join Date
- Aug 2007
- Location
- Chinchwad Pune
- Posts
- 1,461
If he can stretch that much then better get a 400R.
Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
28-04-2012, 01:59 PM #15AMD - Aaja Meri Darling
- Join Date
- Sep 2009
- Location
- Posts
- 132
Guys I've already updated my rig with the new components. All now I am looking for is a cpu cooler that isnt as noisy as the stock one under full load.
See the first post !
28-04-2012, 02:09 PM #16Wise Old Owl
- Join Date
- Aug 2007
- Location
- Chinchwad Pune
- Posts
- 1,461
CM Hyper 212 EVO @ 2.1k or TX3 @ 1.3k
Shall I upgrade?
By kingofkings in forum PC Components / ConfigurationsReplies: 17Last Post: 30-04-2012, 05:02 PM -
9600GT Without Upgrade or 8600GT With Upgrade
By pratik03 in forum Hardware Q&AReplies: 23Last Post: 31-03-2008, 12:20 PM -
Upgrade woo-hoos to Upgrade blues. Help!
By mightyboosh in forum Hardware Q&AReplies: 1Last Post: 27-11-2006, 12:14 AM -
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!!
By karthik316_1999 in forum Internet & WWWReplies: 11Last Post: 18-07-2006, 08:10 PM -
graphic card upgrade(PCI) or motherboard upgrade?
By thetopcyborg in forum Graphic cardsReplies: 5Last Post: 13-01-2006, 02:32 PM
LinkBack URL
About LinkBacks
