Results 1 to 20 of 20
  1. #1
    Wise Old Owl ajayritik's Avatar
    Aug 2007
    Hyderabad
    Default Can I connect my dekstop to LED-backlit LCD TV to watch movies?
    Guys sorry if I'm posting in the wrong section. I wanted to check if I can connect my Desktop to my recently purchased 46" LED TV (Samsung D6000). I have lots of personal videos etc which I wanted to view on the TV without copying them to a pen drive and then connecting to the TV. I think it's possible to hook the desktop directly to the TV but will this result in loss of quality in the videos being played. Does HDMI come into picture?
    Can someone please help
  2. #2
    SoLa BeLLaToR... RiGOD's Avatar
    Feb 2012
    Migrator
    Default Re: Can I connect my dekstop to LED TV to watch movies?
    Your GPU?
    AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
  3. #3
    Aug 2007
    Hyderabad
    Default Re: Can I connect my dekstop to LED-backlit LCD TV to watch movies?
    My apologies bro! Can you give more details on what GPU is? Does it refer to having an external graphics card apart from the inbuilt available. I have Intel DG965RY motherboard purchased in 2007 July.
  4. #4
    Oct 2011
    Bangalore
    If you have HDMI port on your PC you can surely use if for watching movie on your LED T.V.
  5. #5
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    GPU stands for Graphics Processing Unit which is known as Graphics card to all. I think your TV has couple of HDMI input ports. So if you are not using any graphics card and if your motherboard does have HDMI or DVI output then you can connect your PC to your Television using a HDMI or DVi-HDMI cable.
    If you have a graphics card then also you can connect it by using the HDMI output of the Graphics card.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  6. #6
    Feb 2012
    Migrator
    Quote Originally Posted by ajayritik View Post
    I don't think that board will have an HDMI out. Buy a discrete Graphic Card having HDMI out and then connect it to your HDTV.
  7. #7
    Aug 2007
    Hyderabad
    Quote Originally Posted by RiGOD View Post
    How much would the graphics card cost? Also what is the difference if I hook up the Desktop directly to the TV using the VGA port.
  8. #8
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    May be VGA wont be able to provide that clarity. Just get a cheap card like the GT-520 for 2.3k and connect using DVDI-HDMI cable.
    Check here
    My Blog :D
  9. #9
    Feb 2012
    Migrator
    Grab either of these.
    Asus GT 520
    OR
    Zotac GT 520
  10. #10
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Post details of your exact need(s).
  11. #11
    Rubik's Uncle!! RCuber's Avatar
    Sep 2004
    ಬೆಂಗಳೂರು (Bengaluru)
    your motherboard does not support HDMI, you need to get a GFX card (low end cards like the one mentioned above). I would recommend this over VGA because the HDMI cable carries audio also.
    Please note that HDMI is just the data path, the quality of the picture reproduced on your TV depends on the video you are playing. A 720p/1080p video will look awesome , but handy cam videos (say VGA resolution) may look crappy on your huge TV screen .
    the cake is a lie
    621311.251521
  12. #12
    Aug 2007
    Hyderabad
    Quote Originally Posted by d6bmg View Post
    Too be honest before I knew about HDMI I thought I could directly connect my desktop to the LED TV using the VGA ports. And assuming I'm playing the 1080p and 720p videos.
    I was not sure how the HDMI port/ Connecting both the devices using the HDMI cable would make the video better as compared to watching it connected using VGA cable.
    Quote Originally Posted by Charan View Post
    hmm well I was planning to upgrade my rig sometime mid of this year. So I'm thinking is it a good idea to buy this card? If I do buy the card then I have to postpone upgrading my rig.
    Also with regards to the kind of video. Just wanted to check if I'm trying to play a 1080 or 720p file from my desktop to the TV how much difference would it be if I have only VGA connected Vs if I have HDMI connected? Is the difference significant?
  13. #13
    Oct 2011
    Bangalore
    VGA don't have bandwidth for HD videos even it is not suitable for LCD monitor you can see every thing is washed out in monitor if you use VGA.
    It will limit you to some odd resolution.
    you have to use HDMI you will get better audio and video quality with it.
    I would say it will make significant difference.
  14. #14
    Sep 2004
    Is this your TV? UA46D6000SR - OVERVIEW | SAMSUNG India
    ok here are a few questions.. do you only want to watch Videos from your PC on your TV? or do you want to play games also??? .. cause your requirement is quite confusing..
    If you want to Connect your PC to TV then you have to buy the GFX card and use it via HDMI cable. This way you will do justice to your TV. I wont debate on VGA Quality.
    I also noted that there are couple of features available in the above TV.
    1. DLNA
    2. Ethernet Port
    3. Your TV can take a WiFi adapter..
    with these above features you can actually stream videos from your PC directly to your TV over your home network. do some research on this. ask me if you get confused.
    Lastly.. you can check with Network Media Players .. you can play any damn thing on that (except games )
    WD TV Live - not sure about the price .. check ebay/local market..
    Playon!HD2 :: AC Ryan | Defining Digital Entertainment - I have this, paid 9K
    the cake is a lie
    621311.251521
  15. #15
    Aug 2007
    Hyderabad
    Quote Originally Posted by Minion View Post
    Well sorry for being noob. Actually before I had the LCD Monitor which I purchased an year ago for my Dekstop PC I thought we could get the video display using only VGA connection. So without connecting through VGA port between my LCD Monitor and the desktop cabinet can I still use some other wire or port and get a better display. I thought VGA is must to connect between either laptop or desktop to other devices like monitor etc. Can you explain further? If that is the case then I will get rid of this VGA for good.
  16. #16
    Oct 2011
    Bangalore
    VGA lowest quality
    DVI better quality than VGA
    HDMI better SOUND and PICTURE quality(HDMI can carry both sound and video)
    Yes, you can connect it through DVI port in LCD by the way can you mention exact model which monitor you are using now?
    See this you will get all your answer here
    http://superuser.com/questions/15884...vs-displayport
  17. #17
    Aug 2007
    Hyderabad
    1. DLNA
    2. Ethernet Port
    Yes, that's the TV.
    Currently watching movies from PC to TV ,no games atleast not right now.
    Ok will think about buying the External card.
    Also I know that I can connect wireless but I may need a dongle for that.
    I think the current Model is playing most of the formats so will have to postpone buying the media player for sometime.
    Thanks for your time!
    I also have a laptop but which is being used by other family member hence not at my home. I can get that once in a while that does have a HDMI port.
    Bro thanks for that AC Ryan link. That looks very useful.
  18. #18
    Alpha Geek avinandan012's Avatar
    Jul 2010
    hyderabad
    VGA lowest quality
    Picture quality wise DVI=HDMI
    steam :|D|H| chery012
    garena : avinandan012
    Audio Equipment: Edifier C2
    Android : Galaxy Grand
  19. #19
    .NET Guru Champ's Avatar
    Jan 2006
    Delhi
    Quote Originally Posted by avinandan012 View Post
    IIF both source and destination are HDCP complaint.
    Girls are like Roads, The more curves they have the more dangerous they are !!!
  20. #20
    Mar 2009
    Kolkata
    I think there are some confusions regarding VGA, DVI and HDMI.
    ajayritik, VGA cable carries analogue signal. So when the video signal leaves the computer and goes to the VGA cable, VGA cable chipset converts the digital video signal to anlogue signal, resulting loss of some quality during the conversion. Again when the analogue signal leaves the cable and goes to the TV HDMI input, it again gets converted from analogue to Digital signal, resluting another level of quality loss. So VGA actually provides very lossy quality, the output is always of lower quality than the source.
    On the other hand, both DVI and HDMI can carry digital signal without any conversion. So you'll get exact same quality of the Source video in your display (Here it is your LCD TV).
  1. Replies: 21
    Last Post: 01-04-2012, 06:40 PM
  2. Must Watch ''Twist In The End'' Movies
    By soumya in forum Chit-Chat
    Last Post: 12-04-2009, 01:11 AM
  3. Must watch kannada movies
    By New in forum Chit-Chat
    Last Post: 26-10-2007, 04:48 PM
  4. Movies you should never watch...
    By confused!! in forum Chit-Chat
    Last Post: 12-09-2007, 04:45 PM
