Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 60 of 115
  1. #31
    SoLa BeLLaToR... RiGOD's Avatar
    Feb 2012
    Migrator
    Default Re: Mid range PC - Budget 30-35K
    ^^Everything except the case is free shipping. The shipping cost of the case would be around 600.
    AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
  2. #32
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Quote Originally Posted by RiGOD View Post
    Here you are
    EDIT : Here's the link for RAM.
    SMC is selling most of the components in cheaper price. And avoid Sparkle Gfx card, they are of very bad quality. Spend couple of bucks more and get the Zotac GT 240 1 GB GDDR5 Flipkart: Zotac NVIDIA GeForce GT240 1 GB GDDR5 Graphics Card: Graphics Card @ 3.3K. It performs better than gt 520.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  3. #33
    Mar 2012
    Thank you Cilus. I'm not sure if it's worth to shell out 700 bucks more for graphics card, esp. if I don't need it for gaming. Or do you mean GT 520 is faulty piece of hardware? I know ddr5 is the winner but if I don't do gaming, is it worth to still opt for GT 240 (DX 10.1) which is basically older tech than GT 520 (DX 11)?
  4. #34
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    GT240 is a more future proof solution but if you won't play games then get GT520 / HD6450 ( get the cheapest one ) - both are good for HD movie watching
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  5. #35
    Mar 2009
    Kolkata
    Actually GT 520 is very weak card and priced almost at 3K. This card will face problem to run games at 1080P resolution, sometimes even with the lower details. That's why I've suggested GT 240 for casual gaming. Price will be only 300-500 bucks extra compared to the standard price of GT 520.
  6. #36
    Mar 2012
    Hey guys, I'm now into ordering the above rig. Thanks all for your contributions.
    How about getting this processor Flipkart: AMD 3 GHz AM3 Phenom II 1075T Processor: Processor instead of Phenom II 960T? I can spend extra 400-500 bucks if that processor works much better for my purpose? Please help me take final decision.
    Sorry for making haste, someone please suggest me if 1075T is better to go for or 960T is good enough (I'm worried if I can unlock 2 extra cores as it involves good bit of luck in it )
  7. #37
    Jul 2006
    Geek's Heaven
    ^^ go for it (1075T) ... at that price it's a lot more better
    Who Dares Wins
    Avenging Angel !
  8. #38
    Mar 2012
    Thanks a lot topgear. Will go for it! Problem is I order 960T yesterday, need to cancel it.
  9. #39
    Undead!!! Sujeet's Avatar
    Dec 2011
    India
    ^You should do it fast then.
    HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
    HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
    Samsung Galaxy Tab 2 |7.0 P31000
  10. #40
    Mar 2012
    How is this power supply instead of Corsair CX 430 V2? It costs 300 bucks more but is it worth the extra cost?
  11. #41
    Jul 2006
    Geek's Heaven
    ^^ overpriced and the cables are sleeveless too though it offers 24W more than CX430v2 it's better to stick with either cx430v2 or get CX500v2 - if you want something cheap then consider getting corsair VS450 @ 2.2k
    Who Dares Wins
    Avenging Angel !
  12. #42
    Mar 2012
    Okay thanks topgear once again. Will stick to CX430 V2.
  13. #43
    Mar 2012
    Hey guys, I have got some extra funding (Rs. 3000 more) but unfortunately the processor 1070T got out of stock from flipkart
    Now I want to decide from following options -
    AMD FX 6100 Zambezi 3.3 GHz - 6 Core - 8000/-
    v/s
    AMD Phenom II X6 1090T Black Edition - 6 Core - 8950/-
    Which would overclock best and give the best performance for my needs? Or any better option than that? I don't want to spend more than 9-10K at max on processor. Sadly, now I can't go Intel way as I already got AMD motherboard
    BTW I have bought and got these components till now -
    Motherboard - Asus M5A97 - 6050/-
    RAM - 2 x 4GB Corsair Vengeance 1600 - 3300/-
    GPU - Zotac Geforce GT 240 1 GB DDR5 - 3235/-
    Case - NZXT Gamma - 2600/-
    PSU - Corsair CX 430 V2 - 2490/-
  14. #44
    Feb 2012
    Migrator
    AMD 3.5 GHz AM3 Phenom II 970. With the money you save get a CM Hyper 212 Evo an OC it like hell.
  15. #45
    Oct 2011
    Bangalore
    Quote Originally Posted by 1manshow View Post
    RiGOD and Cilus, thank you very much for your valuable suggestions. Though I have some doubts.
    How about recent APU from AMD like A6-3650? Can't it play full HD content on HD Monitors? Do I really need a discrete GPU to watch HD movies?
    APU like A6 3650 will be best bet for watching movies. and some mild gaming.Oops you bought your motherboard go for this then AMD Phenom II X6 1090T Black Edition
  16. #46
    Mar 2009
    Kolkata
    If you are planning to get an after market CPU cooler then I strongly suggest to get G-Skill RipjawX 1600 instead of Vengeance. The big heat sink in Vengeance is known to create problem with the placement of the CPU coolers. Beside that, Ripjaw's performance is also better.
    And regarding Motherboard, get the Gigabyte GA-970A-UD3 motherboard at 6.6K. This baby has 8+2 phase VRM design and far better for overclocking. It is also more feature rich than the ASUS M5A97
    Sorry, didn't notice you've bought all the components.
    regarding selection of processor, FX 6100 is simply out of the equation due to its very poor performance. Now if you're gonna use multi-threaded apps like Audio/Video encoding apps, Photoshop etc, get 1075T or 1090T which offers better performance than FX 6100. These two hex core can also be overclocked in very high level with a decent CPU cooler. both are capable of running at 4 GHz + with Hyper 212 EVO. So gaming performance is also very good.
    But if main concern is gaming then grab the Phenom II X4 970 and overclocked it like hell as RiGOD suggested.
  17. #47
    Mar 2012
    Thank you RiGOD, but I am not going to game using PC much. My needs are better multi-tasking and use of VMs/remote assistance tools. For gaming, I have Jtagged Xbox 360, which serves well for now.
    Quote Originally Posted by Cilus View Post
    Thank you Cilus. I was suggested the M5A97 motherboard by many people in previous posts here, so I bought it . Dunno if I can ask for replacement, as I bought it from ITWares online shop.
    For RAM, G.Skill was not available and it was suggested by Itwares owner Rahul that Vengeance is much better performance wise and is comparable to Sniper series than RipjawX? Also I was made convinced by him that Vengeance works fine with Hyper EVO, only one Noctua cooler (D40 or something like that) has problems with Vengeance. Should I ask for replacement if it doesn't work with any aftermarket cooler?
    Ok, so back to CPU, which one would be best to plunge upon -
    AMD Phenom II X6 1055T - 7600/-
    or
    AMD Phenom II X6 1075T - 8350/-
    or
    AMD Phenom II X6 1090T - 8975/-
  18. #48
    Mar 2009
    Kolkata
    I don't think Vengeance is a problem with Hyper 212 EVO as the cooler isn't that big.
    Regarding processor, if your budget permits, get the 1090T.
  19. #49
    Jul 2006
    Geek's Heaven
    @ OP - I think this should help
    if there's ain't enough space between cpu socket and ram slots you may have to install the cooler fan like the above pic but if you have two ram modules only you can install the fan on the opposite direction too facing the ram slots like this :
    or the cooler can be installed like this as well
    Who Dares Wins
    Avenging Angel !
  20. #50
    Mar 2012
    Thanks again mate, but what I meant to ask between those processors is if paying 1.5K more worth if I get 1090T? I've heard all three of them can be overclocked till 4 GHz (that is what I'm aiming at, no more than that).
    Quote Originally Posted by topgear View Post
    Thank you topgear, will see if I need those adjustments in my case. Hope it fits fine with the RAM modules I got.
  21. #51
    Mar 2009
    Kolkata
    All of them can be overclocked but with the Non-BE processors, you have to play with the Base clock frequecny (which is 200 MHz by default). Now the clock also drives the speed of other components like the PCI-E speed, Memory speed. Also you have to be extra careful while increasing voltae.
    On the other hand, 1090T is a Black edition processor and comes with unlocked multiplier. So just increase the multiplier and you are flying.
  22. #52
    Mar 2012
    Thank you very much Cilus, will now go for 1090T. I see you too use same processor. How is the performance overall? How much stable overclock you can expect with stock cooling?
    Also will I be able to overclock fine with Asus M5A97? Or I must get it replaced with Gigabyte offering you suggested earlier?
  23. #53
    Jul 2006
    Geek's Heaven
    for OCing GA-970A-UD3 is better - the extra 4 power phases will come into play while OCing.
    Who Dares Wins
    Avenging Angel !
  24. #54
    Mar 2012
    Okay. The dealer has agreed to swap the motherboard with GA-970A-UD3. Now I want to know, is it really worth the extra 600 Rs. or M5A97 should be good enough to let my system run better with overclocking? Do note that I don't want to create any overclocking record, just would like to get my 1090T processor clock run at 4+ GHz 24/7. Any insights? Should I go for Gigabyte or content with M5A97?
  25. #55
    Feb 2012
    Migrator
    ^^While suggesting the GA-970A-UD3 nobody here expected you to make a world record dude. The VRM's of the same are way better than M5A97's and the extra 600 you're shelling out is really worth it. You're lucky that the dealer has agreed to exchange the same.
  26. #56
    Mar 2012
    Ok. Thanks RiGOD and topgear. Will arrange for motherboard replacement. Can someone suggest me the best price for 1090T and CM Hyper Evo cooler?
  27. #57
    Jul 2006
    Geek's Heaven
    1090T @ 9k
    Buy AMD Phenom II Processor | AMD Phenom II X6 1090T Processor in India
    Cm Hyper 212 Evo is ~2.2k at everywhere - only SMC may have a little cheaper price though.
    Who Dares Wins
    Avenging Angel !
  28. #58
    Mar 2012
    Thank you topgear. I ordered it from Prime
    I've read some other threads and most of the experienced members emphasized on better PSU (over 500W) if you want to go overclocking way.
    I have bought low end graphics (GT 240) and I am only going to do very casual gaming on PC. Most of the times I'll watch HD movies only for entertainment, most gaming will be done on Xbox 360. So in total, I won't be stressing PSU from graphics end.
    Though processor wise, I'm planning to overclock in order to squeeze in the best performance possible out of it. Now I want to ask if Corsair CX 430 V2 would cut it fine even if I do CPU overclocking?
  29. #59
    Feb 2012
    Migrator
    ^^A SeaSonic S12 II 520 is recommended for OC'ing.
  30. #60
    Human Spambot MegaMind's Avatar
    Nov 2010
    Perambalur, TN
    Since you don't have a pow. hungry GPU, CX430 V2 will suffice..
    i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
  1. Good Mid Range PC (15K Budget)
    By navneetagarwal in forum PC Components / Configurations
    Last Post: 26-06-2012, 09:21 PM
  2. Need a Mid-Range Config within 35k budget
    By bloodlife in forum PC Components / Configurations
    Last Post: 15-04-2012, 09:38 PM
  3. new mid range gaming pc-45-50k max budget
    By preyingangster in forum PC Components / Configurations
    Last Post: 05-03-2011, 12:51 PM
  4. Budget range LCD television
    By gokuljawahar in forum TVs / Monitors
    Last Post: 24-12-2008, 08:25 PM
  5. [Suggest Laptop] - Budget range
    By omk in forum Reviews
    Last Post: 17-03-2008, 09:50 PM
