Results 1 to 15 of 15
Thread: Upgrading my old system
11-02-2012, 07:43 PM #1Right Off the Assembly Line
- Join Date
- Feb 2012
- Location
- Mysore, Karnataka, India.
- Posts
- 6
This is my final attempt online to find a suitable advice(AND not sarcasm) on my guidelines of upgrade.
That's it. Now, my father had bought a second-handed system - Pentium E2140, Intel mobo D945GCPE, which has 82945G graphics controller, I GB RAM(Transcend), 80GB SATA HDD, LG DVD reader/writer.
This is NOT enough for my use, i.e., gaming. I tried to play games, but they all just crashed. I can't upgrade the graphics card , 'coz mobo doesn't have a PCI-e slot (ouch). I am looking for suitable motherboards within budget of 1500rs to 2500 MAX (yes, second-hand motherboards). I want support for my current HDD, and RAM, and want to make a little more our of my processor *cough* if you know what I mean, overclocking. I want it to have PCI-e slots(x16, for current cards) will look into matter of graphic cards later, if the motherboard has an average in-built graphic controller.
I hope this is sufficient. If you need to know anything else, just ask for it, politely. I am a newbie and a sensitive person.
Thanking all of those who may help, in advance.
11-02-2012, 09:47 PM #2
Re: Upgrading my old system
trust me, building a new system will cost same as upgrade but offer several times better performance. why?
1. thats a 1.6Ghz 5yr old processor. you can't expect to run games using such a slow processor. even at lowest of settings, games will seriously lag.
2. if you change board, you need to spend around ~2k.
3. 1Gb DDR2 which will again need to be upgraded. say you add 2Gb DDR2 stick. that will cost 1.5k
4. GPU that won't bottleneck your processor is of the range of HD6450, which not to mention is seriously slow for games.
instead get a new PC keeping monitor, keyboard-mouse, etc same. so how much is your budget for the upgrade? or you prefer to jump platform to a new & better build?
12-02-2012, 03:27 PM #3Right Off the Assembly Line
- Join Date
- Feb 2012
- Location
- Posts
- 6
Well, what you are saying is true, but I don't know where to sell it. I am still looking locally if someone wants to buy the computer, but I'm not successful. And even if I am planning to sell of this old PC, I need to convince my parents, which is neck-breaking task.
BUT, can you still suggest some motherboards just for my sake, if not well-fare??
Thanking you again.
12-02-2012, 06:16 PM #4
I'd suggest that u change the cpu as well as your motherboard if u wish to use your pc for gaming- a pentium dual core 805 cpu and an Intel 945gnt or equivalent motherboard will suffice for your needs.You should be able to get them for rs 2000 or less at any computer shop which deals in used peripherals,just make sure they are in good condition.
12-02-2012, 08:29 PM #5
Even i have e2140 getting 20fps in bf3 with it at 800X600 resol. With nvdia 8400gs and 2gb ram
On TDF after a loooo...nng time!
12-02-2012, 08:44 PM #6
Karthikk, can you tell us what is the maximum budget of yours?
AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
13-02-2012, 03:20 AM #7
You need a new computer. That's it. - CPU, Motherboard, RAM, Power Supply.
Hard Disk is SATA. And I also hope the DVD Writer is SATA. SATA will work in new computers.
For gaming, this is the cheapest recommendation I can give.
AMD A6-3650 quad-core processor with built-in Radeon HD 6530D graphics - Rs. 6300
Gigabyte A55M-S2V motherboard - Rs. 3600
4 GB Gskill Ripjaws X 1600 Mhz RAM - Rs. 1600
Corsair CX430v2 Power Supply - Rs. 2300
Buy from Flipkart.com
If you want, you can get AMD A6-3500 tri-core processor with built-in Radeon HD 6530D graphics for Rs. 4600.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
15-02-2012, 06:55 PM #8Right Off the Assembly Line
- Join Date
- Feb 2012
- Location
- Posts
- 6
1) Cilus, my budget is 1000 - 2500 rupees for the motherboard. I think I will sell my old mobo so I think I can cash another 1k extra (MAYBE
2)My HDD and DVD reader/writer is SATA.
And you naughty boy ICO, I'm on a cut throat budget. With the specs you mentioned(they WERE good, no offence), I could build another two medium-end PC's.
I'm going for a low budget, and am also planning on how to overclock.
And that's my second question, i.e., HOW do I overclock my processor, iff I have the proper mobo(WHICH is what I'm asking you guys, get it?)
15-02-2012, 08:26 PM #9
2.5k for motherboard, 1.5k for 2Gb ram (which is a must), 4k for GPU & then maybe a new PSU. why not save a bit more and go for a new system?
in case you need a new motherboard now only grab this: Gigabyte GA-G41MT-S2 DDR3 or Intel DG41CN DDR2. but you can't overclock using the Intel board.
15-02-2012, 08:29 PM #10
The specs given by ico are probably the best for you.
1 it has good enough IGP for your gaming needs which doesnt require you to buy another graphic card.
2 new PC is worth it over the old one. only a little expensive over what you are going to spend.
the specs he gave was of a mid end Pc. The best you can build at that budget is a low end pc which probably wont give you gaming experience you are after.With the specs you
medium-end PC's.Follow me on Twitter: http://twitter.com/wuodland
15-02-2012, 09:02 PM #11
By upgrading your current machine, you are wasting money. A year down the line, you are again going to feel what you are feeling now.
Spend a bit more and go for what I said. That's the best for you. Otherwise, it is your wish.
I'm putting facts in front of you.
You need a graphics card to run games properly. Your motherboard does NOT have a PCIe slot. For your system to run fine with a graphics card, you need a better power supply as well. You need more RAM too. DDR2 is expensive. 1GB DDR2 RAM costs as much as 4 GB DDR3 RAM now. Lastly, your processor is not good enough.
Verdict = by spending a little more, you get a new PC which is worth it.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
05-03-2012, 12:03 PM #12Right Off the Assembly Line
- Join Date
- Feb 2012
- Location
- Posts
- 6
Well, it has struck me now. If ico gave me the configuration of a mid-end gaming PC, what would you suggest for an entry level gaming PC???
Good and cost-effective answers, anyone?
05-03-2012, 01:40 PM #13
^^ you can't go lower than that. if you go for Athlon II / Phenom II if still on sale, then you'll need a new GPU which will make total cost even higher.
05-03-2012, 04:11 PM #14
Actually what Ico gave you is an entry level Gaming pc,Save some money and get what Ico has suggested
Gadgets/Gaming RIGA girl is someone who eyes an Iphone,wants a S3,Read's all good about Xperia and LG but at last ask's her Noob friend how is micromax and buys it
HD 7750||Nexus 10 :) || Canon Sx150 || Ipod touch 4g|| Sound magic es18
05-03-2012, 07:19 PM #15Right Off the Assembly Line
- Join Date
- Feb 2012
- Location
- Posts
- 6
Well, I think I will take the motherboard Sam recommended. I looked into the supported frequencies of the mobo, and it had 1033 with O.C. in brackets. What exactly does it mean? because I'm planning to buy this stick - http://www.flipkart.com/corsair-ddr3...8-4902c083ed1a . Is it a good option, considering my motherboard and my processor, Pentium dual-core E2140???? If not any other suggestions??
FYI - sorry for the last wrong post... still can't find the $%^& start thread button.....Last edited by Karthikk; 13-03-2012 at 03:48 PM. Reason: Well, it contained irrelevant data.
Upgrading my system ?
By Neeraj J in forum PC Components / ConfigurationsReplies: 10Last Post: 05-01-2012, 06:52 AM -
Upgrading my System (MB and Proccy)
By ikkru in forum Hardware Q&AReplies: 23Last Post: 21-09-2010, 05:21 PM -
help upgrading system
By anni in forum QnA (read only)Replies: 22Last Post: 07-11-2009, 07:43 PM -
Upgrading a 5 year old system
By spider in forum Hardware Q&AReplies: 5Last Post: 08-04-2009, 09:31 PM -
Need help - upgrading system
By silkyboy in forum Hardware Q&AReplies: 3Last Post: 05-06-2007, 08:16 AM
LinkBack URL
About LinkBacks
