Results 1 to 27 of 27
28-01-2012, 10:33 PM #1Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
Motherboard and processor combo question.
my current pc,a lenovo k series,is not working now.So i am planning to change and upgrade.
I have the following components already:
- sparkle nvidia geforce 8400 GS 512 mb graphics card
- 500 GB hard disk
- 2 GB DDR2 strontium RAm
- 2 512 MB DDR2 sticks of RAM
- a monitor
- speakers
- mouse
- keyboard
- UPS
- printer
so in short,i need a motherboard and a microprocessor
i am planning to go with core i3,
i dont want any AMD processor.only intel strictly.
my budget is of 5000 INR
please suggest what i can get at this budget.If i cant,please do post what i can get.USb 3.0 will be good,but can be sacrificed.I need it urgently,so please do suggest.
any company will do,but i need it to fit in my cabinet too..
I would like to stick to the budget.
provide the cheapest and the best please.
i am willing to buy only the processor and motherboard.
28-01-2012, 11:09 PM #2Human Spambot
- Join Date
- Nov 2011
- Location
- NCR
- Posts
- 2,606
Re: Motherboard and processor combo question.
cheapest current generation core i3 2100 processor costs ~6600.cheapest mobo supporting this processor costs ~3200.all core i supporting mobo are ddr3 ram not ddr2
option 1:increase budget to ~11000.
option 2:get pentium G620(based on same design as core i series but slower) for 3500 by increasing budget to ~7700.Is God willing to prevent evil, but not able? Then he is not omnipotent.
Is he able, but not willing? Then he is malevolent.
Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
29-01-2012, 09:11 AM #3Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
29-01-2012, 11:32 AM #4Human Spambot
- Join Date
- Nov 2011
- Location
- NCR
- Posts
- 2,606
my advice is instead of reviving a outdated system save some money & get a latest generation system which will suffice for next 2-3 years.if not possible then cheap pentium dual core(based on core2duo)is available for ~3000 & compatible mobo for ~2600 with ddr2 ram support.another option is get the discontinued older generation i3 540 for ~5600,compatible mobo for ~4100 & 4gb ddr3 ram for ~1200 but keep in mind that you will not be able to upgrade anything on this system because older generation core i series & compatible mobos are discontinued.
29-01-2012, 12:41 PM #5
lol..not possible in your budget.
In any case, if you increase your budget to 11k, then Intel will be waste of money.
AMD A6-3650 (quad core APU) + Gigabyte GA-A55M-S2V + 4 GB 1600 Mhz DDR3 RAM = 6200 +3500 + 1500 = 11,200.
A6-3650's built-in Radeon HD 6530D should be 4 times faster than nVidia 8400GS lol.
Better than Core i3-2100 + 8400 GS.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
29-01-2012, 12:46 PM #6Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
ok so i have a pentium dual core processor here,from a friend got it for free..suggest me a capable mobo...
what about 9000 budget?
and please provide all possible configs ddr2 and ddr 3
with ram for ddr3,but for ddr2 i have 3 sticks already.
for 9K,please provide all possible configs
29-01-2012, 12:48 PM #7
Tell the EXACT model number.
I've given you a config for 11K. That's what is worth it.
Going for Core i3-540 is waste of money.
Going for Core i3-2100 without adding a discrete graphic card costing Rs. 5,000.....i.e. extending your budget to around 18K, is again waste of money as far as overall performance is concerned.
29-01-2012, 12:57 PM #8Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
29-01-2012, 01:02 PM #9
should have told that earlier, right?
HTPC...you don't even need a Core i3 in that case.
Pick this up.
AMD A6-3500 (tri core) @ 4500.
Gigabyte A55M-S2V @ 3500. This motherboard doens't have HDMI port. Do you need one?
4GB DDR3 1600 Mhz @ 1500.
Total = 9500.
Pentium G640 processors + H61 motherboards are fine as well. But I suggest AMD A6-3500 because of better GPU.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
29-01-2012, 01:09 PM #10Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
29-01-2012, 01:11 PM #11
29-01-2012, 01:37 PM #12Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
29-01-2012, 01:37 PM #13AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
29-01-2012, 01:44 PM #14Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
29-01-2012, 01:46 PM #15
29-01-2012, 01:48 PM #16Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
29-01-2012, 01:52 PM #17
Graphics Card Hierarchy Chart : Best Graphics Cards For The Money: December 2011
Look out for the gap between 8400 and HD 6530D
Use your browser's Find function.
Extra info in simple words - AMD created the currently used 64-bit architecture. Intel copied it because they lost and AMD's was better.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
29-01-2012, 01:57 PM #18Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
i just see that it has USB 1.1 and 2.0 so outdated. any other mobo in sight?
see for yourself :
GIGABYTE - Motherboard - Socket FM1 - GA-A55M-S2V (rev. 1.0)
29-01-2012, 02:01 PM #19
29-01-2012, 02:03 PM #20Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
29-01-2012, 02:05 PM #21
anything that is supported by Intel will be supported by AMD as well.
at your budget this is what you get. you can't get the best of everything on a shoestring budget. moreover, you may buy a board with USB 3.0 & find it useless for many years. or you can buy this board, drop in a USB 3.0 card at a later date. i'll simply suggest buy what you really need & don't run after brands just following the hype they create by launching highend product.
29-01-2012, 02:09 PM #22
Do you even realize the fact that USB 1.1 is nothing more than mention to specify backwards compatibility? Every port is 2.0. Every USb 2.0 port is backwards compatible with 1.1.
You've got only USB 2.0 "ports" at the back.
I'm not answering anymore "weird" questions. Before coming to this forum, you need to do your homework.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
29-01-2012, 02:13 PM #23Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
agreed.but i aim to be getting the best possible-everybody does right?
i was looking at this list and see what i can get:
link
how about a6 3650 or a8 3850??
well no i dont i am a new one at all the hardware stuff that's why i need help and sorry if you find it dumb,i want to be sure while i buy..that bad it aint aint it??
29-01-2012, 02:13 PM #24
29-01-2012, 02:15 PM #25Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
29-01-2012, 02:17 PM #26
No, I'm not frustrated because you don't know about these things. I am frustrated because you missed the forum rules and sticky threads - FAQ and Posting Guidelines for new members
We have already given straightforward answers to every question you have asked in this thread.
In reality, because your thread wouldn't have been approved because it wasn't conforming to the PC Configuration Template we have here.
This is something what is known as doing the home work on your own.
We are here to help out. But not spoonfeed.
Read the link I listed above.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
29-01-2012, 02:21 PM #27Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- kolkata
- Posts
- 29
Processor + Motherboard Combo
By vidhubhushan in forum CPU / MotherboardsReplies: 10Last Post: 02-09-2011, 09:28 PM -
The best Motherboard+Processor Combo under 20K for Overclocking
By layzee in forum OverclockingReplies: 4Last Post: 07-07-2008, 10:00 AM -
Processor Motherboard Combo for 12k
By Swift in forum Hardware Q&AReplies: 14Last Post: 08-05-2008, 12:09 AM -
Processor Name??????Big Question.1 Processor 3 Names
By vutonium in forum Hardware Q&AReplies: 12Last Post: 05-07-2007, 11:07 PM -
processor+mobo combo 4 8k
By varunprabhakar in forum Hardware Q&AReplies: 13Last Post: 22-06-2007, 05:33 PM
LinkBack URL
About LinkBacks
