Results 1 to 2 of 2
  1. #1
    Jan 2012
    Lightbulb Processor and MoBo and Graphics Card
    I'm planning of building a good gaming and multitasking pc for myself...but 'm confused for processor between amd and intel
    1) AMD Phenom 2 X6
    2) Intel i5 2500k
    3) AMD bulldozer (but thinking of dropping it as the critics have panned it badly)
    4) Intel i7 2600k
    i need good graphics support must...i do lot of multitasking and video encoding stuff too so the processor must be able to handle that smoothly...
    till now i have pondered for i5 2500k but need second opinion also my budget is 20-25k including components like 1Tb hard-disk,4/8 GB ram, 1GB graphics card
    as for motherboard have just looked at the ones which support 2500k
    1) Asus p8z68-v
    2) ASROCK extreme3 gen3
    ( Z68 MoBo's only)
    also need super high suggestion on graphic card should support highend gaming and preferably under 5k
  2. #2
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Default Re: Processor and MoBo and Graphics Card
    Now i5 2500K costs around 13K, a good Z68 motherboard is around 8K (Biostar TZ68+), 4GB ram is around 1.5K, 1TB HDD is 5.5K and a standard Graphics card is around 5K. So total is around 31.5K. Now you need a good PSU around 3K to handle all these above mentioned components. In other words, your requirements can't be fulfilled at a budget of 25K with Intel Setup.
    So go with
    AMD Phenom II X6 1090T @ 9K
    Gigabyte GA-880GM-USB3 @ 4.8K
    G-skill RipjawX 1600 MHz 4GB Ram @ 1.5K
    Seagate 250GB HDD @ 3.4K
    MSI HD 6670 1 GB GDDR5 @ 5.4K
    Corsair CX 500 V2 @ 3K
    Total is around 27.1K
    AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
  1. Replies: 6
    Last Post: 20-03-2010, 07:54 PM
  2. Which Processor & Graphics Card Should I Buy.
    By ASH_DSG in forum Graphic cards
    Last Post: 20-01-2008, 10:40 PM
  3. Need suggestion...Mobo,Processor,Pci-e Card,laptop..???
    By Aniruddh in forum CPU / Motherboards
    Last Post: 28-05-2005, 01:09 PM
