Results 1 to 11 of 11
  1. #1
    Right Off the Assembly Line Neeraj J's Avatar
    Jan 2012
    New Delhi
    Default Upgrading my system ?
    Hi TDF friends,
    I am new to this forum, though I read it daily & also want to share that the solutions provided here helps me a lot in keeping my computer knowledge updated.
    I have a system 2-3 years old. And its config is Intel Core2Duo processor, Mercury PI945GZD MB, Hynix 2GB DDR2 RAM, Intex Cabinet along with Power Supply, Logitech K/B & Mouse combo, 2.1 Speakers, 17" LG LCD monitor. Now my system have some unknown issue of no display,but power is there on M/B. I've checked swapping RAM & SMPS too but all in vain so I decided to upgrade my system (only Processor,M/B & RAM).
    1. What is the purpose of the computer? What all applications and games are you going to run? (Generic answers will not work. Be exact and avoid the word 'et cetera.')
    Ans: Internet Surfing, Watching Movies/Songs, Office Work, Simple games(mostly flash based)
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans:8-10K
    3. Planning to overclock?
    Ans: No, Never
    4. Which Operating System are you planning to use?
    Ans: Win7 Ultimate or Linux (Ubuntu or Mint) or Unix
    5. How much hard drive space is needed?
    Ans: HDD I already have 160GB SATA, so right now not required.
    Ans: LG Flatron L1752S , Resolution supported: 1280 x 1024
    Ans: Keyboard, Mouse, Cabinet & PSU(if possible), Speakers & Monitor
    8. When are you planning to buy the system?
    Ans: This month
    Ans: I will assemble myself.
    Ans: New Delhi, can try online.
    Ans: Will add a good graphic card later for medium gaming. Also upgrade my monitor to 22-24 inch in future.
    As per all system config threads I've selected these combination & want your comments/suggestions.
    AMD A6-3650
    Gigabyte GA-A55M-S2H
    Asus F1A55-M-LE
    Gskill Ripjaws X F3-12800CL9S-4GBXL
    OR
    AMD Athlon II x4 635
    Gigabyte GA-78LMT-S2P (rev. 3.1)
    Also I want to know what is merits & demerits of using AMD A6-3650 as processor as some of members are in favour of this and some are strongly against that. Waiting for your reply plz.
  2. #2
    Constructed New Rig..!!
    Nov 2011
    Mumbai
    Default Re: Upgrading my system ?
    I guess PSU you are having with Intex case is generic one and you need to change it.
    For A6-3650, well it is a Quad-Core proccy with GPU. It is bit slower than i3-2100 in CPU front but better than Intel HD2000 GFX. It is CPU if you do not want to add any Discrete GFX Card and want casual/entry level gaming. So one can hate or love it as per his/her needs.
    Mac Book Air 13 2009|HP DV6-3057TX|Dell Mini 12|955BE|Gigabyte 880GM-USB3|Kingston SSD 64GB|Seasonic S12II 620W|HD6970 aka unlocked Sapphire HD6950 2GB|NZXT Gamma|CM Hyper 212 EVO|Corsair Vengeance 8GB |WD Red 2TB|Dell ST2220L
    iPad 1 32GB WiFi |HTC Explorer
  3. #3
    Wise Old Owl mithun_mrg's Avatar
    Oct 2003
    Assam
    first advice even if u r not installing a dedicated gpu please install a good psu
    i think AMD Llano is good for HTPC use only if ur into serious gaming or u may think for in the future then better go with the second option which i feel is much more versatile then the first one add a dedicated gpu later for the jobs u mentioned ur current core2 duo will be able to handle them easily
    Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
  4. #4
    Jan 2012
    New Delhi
    Thanks for this piece of information. but can you please suggest/comment on my narrowed configurations? I have used i3 in on of my friends system & found it slow. Does AMD proccy I have selected are slower than i3 too?
  5. #5
    Nov 2011
    Mumbai
    i3 which generation ?
    i3-2100, second generation, being a dual-core (4 cores via HT) outperforms Phenom II X4 955BE in single threaded apps.
  6. #6
    Oct 2003
    Assam
    Quote Originally Posted by Neeraj J View Post
    in which sense did u find it slower please expain
  7. #7
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    mithun_mrg, who said that Llano is for only HTPC use? The high end models like A8-3800 series offer same performance of a Phenom II 925 or almost same as i3 2100 and far better Graphics performance. And HD 6550D is not at all any HTPC graphics, it is equal to a HD 5670 in terms of performance. Even if you want gaming, you can always add another GPU to it.
    As per the OP's need where hardcore gaming is not even in the list, I think Llano based config is the best solution.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  8. #8
    Jan 2012
    New Delhi
    Smile Re: Upgrading my system ?
    Quote Originally Posted by mithun_mrg View Post
    @mithun_mrg: Mostly uses application by me is, GNS3 simulator , Dynamips, VMware and NetBrain Personal Edition. Despite additional RAM I found it slower. Now suggest please...
    @Cilus: as per my requirements which config I should go with:
    AMD A6-3650
    Asus F1A55-M-LE
    OR
    You can suggest Intel config also, but I think that would exceed my budget max. 12K. Also I don't have much info about PSU as suggested by vyral_143, so suggest some PSU in low budget with thing in mind that I would install a Graphic Card later on. Also would I need to change my existing cabinet???
  9. #9
    Mar 2009
    Kolkata
    The AMD A6-3650 based config is the best for you.
  10. #10
    Jan 2012
    New Delhi
    please suggest for best motherboard and a budget psu for this config.
  11. #11
    Nov 2011
    Mumbai
    Motherboard: Asus F1A55-M LX PLUS @ 4000
    PSU : Corsair CX430 V2 - 2200 or Seasonic S12II 430W - 2600
  1. Upgrading my old system
    By Karthikk in forum PC Components / Configurations
    Last Post: 05-03-2012, 07:19 PM
  2. Upgrading my System (MB and Proccy)
    By ikkru in forum Hardware Q&A
    Last Post: 21-09-2010, 05:21 PM
  3. help upgrading system
    By anni in forum QnA (read only)
    Last Post: 07-11-2009, 07:43 PM
  4. Upgrading a 5 year old system
    By spider in forum Hardware Q&A
    Last Post: 08-04-2009, 09:31 PM
  5. Need help - upgrading system
    By silkyboy in forum Hardware Q&A
    Last Post: 05-06-2007, 08:16 AM
