Results 181 to 210 of 740
Thread: PC Buying Guide 2012 - Q4
27-01-2012, 08:46 PM #181
Re: PC Buying Guide 2012 - Q1
yes all components are compatible. yes you can get elite 310.
UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
HP Pavilion G6 2005AX - Genuine Windows 8 Pro, Samsung Galaxy Y Duos
30-01-2012, 01:10 AM #182
can i use intel G620 with this mobo?
MSI H61M-P21 (B3)
Flipkart: MSI H61M-P21 (B3) Motherboard: MotherboardAMD Phenom II X4 B25, Gigabyte GA78LMT-S2P rev.3.1 [AM3+] , 4GB DDR3 Corsair value select 1333MHz, 1TB WD caviar Green, XFX Radeon HD6770 1GB GDDR5 , Corsair CX500V2 Xbox 360S 250GB LT2.0 , PS3 Slim 160GB @ 3.55 kmeaw, PSP E1004 @ 6.60 proB10, LG Optimus One P500 @ stock GB , Apple iPod touch 4G 8GB
30-01-2012, 01:16 AM #183
^^Yes you can install Intel Pentium G620 Dual-Core(sandybridge) in Socket 1155 based motherboard i.e.
H61,H67,P67 and Z68.My Gizmos O_O
||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
30-01-2012, 04:31 PM #184
And can i install ivy bridge cpu on same motherboard in future?
Also how much performance boost can i expect from g620 as compared to dual core E5300 i used to own?AMD Phenom II X4 B25, Gigabyte GA78LMT-S2P rev.3.1 [AM3+] , 4GB DDR3 Corsair value select 1333MHz, 1TB WD caviar Green, XFX Radeon HD6770 1GB GDDR5 , Corsair CX500V2 Xbox 360S 250GB LT2.0 , PS3 Slim 160GB @ 3.55 kmeaw, PSP E1004 @ 6.60 proB10, LG Optimus One P500 @ stock GB , Apple iPod touch 4G 8GB
30-01-2012, 05:45 PM #185
P67/Z68 will support ivy-bridge CPUs.
Inactive in TDF.
30-01-2012, 09:53 PM #186
Its a H61 board
31-01-2012, 08:11 PM #187Right Off the Assembly Line
- Join Date
- Jan 2012
- Posts
- 1
is there any website from where i can buy assembled gaming system without monitor and keyboard.pls guide
31-01-2012, 09:59 PM #188
^its fun to assemble yourselves, we can guide you
01-02-2012, 11:52 AM #189
A good alternative to GS600 & S12II 620 - XFX ProSeries 650
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
01-02-2012, 11:47 PM #190
Seagate's Profitability Skyrockets Due to Constraints in Hard Drives Shipments - X-bit labs
Essentially, Seagate implies that the hard drive industry will never be the same and HDDs will not become commodity products like dynamic random access memory (DRAM) where customers dictate pricing.Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
Android: Galaxy R | Galaxy Y
02-02-2012, 12:01 AM #191
^ No explicit comment, but this is not good.
Inactive in TDF.
02-02-2012, 02:58 PM #192
JAS, in guide where we're suggesting Phenom II X4 965/975 CPUs, I think that can be updated with Phenom II X4 960T 3.3 GHz Zosma processors which are basically Quad core Thuban processors. Reasons are:-
i. Price is in the same range. It is available in Flipkart @ 6.8K
ii. Better Thermal and voltage management, common to all Thuban over Deneb.
iii. Support for AMD Turbo Core Technology
iv. Very high chance of unloking it to X6 1065T, 3.3 GHz 6 core.AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
03-02-2012, 05:24 AM #193Right Off the Assembly Line
- Join Date
- Feb 2012
- Location
- Kolkata,WestBengal
- Posts
- 36
I want to buy a new Gaming PC worth 110000 INR
FIRST,NVIDIA GTX 590 IS A MUST FOR ME AND I WANT 3D VISION 2 GAMING EXPERIENCE.SO A 3D HDMI 1.4 SUPPORTED MONITOR ALSO MUST WITH NVIDIA 3D VISION 2 GLASSES.
PLEASE SUGGEST ME THE OTHER PARTS AS PROCESSOR,COMPITIBLE GAMING MOTHERBOARD,8 GB OR 12 GB RAM AND A GOOD PSU,GAMING KEYBOARD AND MOUSE.A GOOD SOUND SYSTEM WORTH 4000 INR ETC.and also i dont know which will be good for gaming.32 bit or 64 bit operating system ?
I really need your help friends.I cant decide other parts to make it in 110000 INR,its always becoming 1 lakh and 40 thousand INR.
and i dont understand the difference between core i7 and core i5 same frequency processors.also please explain if buying nvidia 590 is a wrong decession for me.My current PC have 9400 GT with 2 GB ddr2 ram and core 2 duo 2.8 GHz processor with a frontech cabinet.and its really sucks.Games that relesing recently running soo slow in this PC at 1366*768 resoloution.Please Help.
03-02-2012, 11:06 AM #194
^ 1. Welcome to TDF.
2. Create a new thread using template.
3. Please don't use caps.
Inactive in TDF.
03-02-2012, 04:21 PM #195
03-02-2012, 10:56 PM #196Right Off the Assembly Line
- Join Date
- Feb 2012
- Location
- Posts
- 36
03-02-2012, 11:33 PM #197
Before I will even look into your thread, I would like to ask you one question.
Is it possible for you to wait for 2 more months? Cause new gen Intel processors (i.e. Ivy bridge) is coming with new chipsets and it is rumored that they have better overclocking potential than present gen sandy-bridge processors combined with better performance.
Or, if you can not, then I will be more than happy to suggest you configuration.Inactive in TDF.
04-02-2012, 03:16 AM #198Right Off the Assembly Line
- Join Date
- Feb 2012
- Location
- Posts
- 36
ooo...ok i will wait
.thank you for this info.I want to buy everything latest that i wont have to suffer with it in future when games will run sooo slow.i hope that acer and BenQ 27" 3d lightboost monitors also become avialable here.I have exams too in march.so i will buy it in the last week of april.hoping that the price of doller also reduce that time.
btw I am so excited about this 3d thing.is it any good like i saw it in Inox forum or in science city ?
04-02-2012, 09:48 PM #199
04-02-2012, 11:38 PM #200
what do you guys think of the newly launched dell alienware x51... should i go for it or assemble 1...!!?
05-02-2012, 07:59 PM #201
^ waste of money. Assemble.
alienware = best for those persons to whom hardware is like alien.Inactive in TDF.
06-02-2012, 11:37 AM #202
But This 1 i guess is a good deal.. check out the specs
New! Alienware X51 Desktop ? High-Performance Gaming Computer | Dell India
and also you get an year of warranty... a console sized tower, reliability of alienware, and no hassle in assembling..!!And on top of that a good performance.
heres a resonable comparison
Dell Alienware X51, SFF PC Gaming Refined - HotHardware
06-02-2012, 11:56 AM #203
^ If you really wish to buy this, then no comment, end of discussion.
But if you want some comparison, then I will say:
A rig with i5-2320, GT 545, 4GB 1333MHz RAM, 1TB HDD and only added/branded with Alienware logo, design isn't good for spending 50K and that too without any monitor.
I think your main purpose is gaming. GT545 is a entry level graphics card with which you can't play any latest game even at medium setting at 1080p resolution.
Build a new rig at 50K, and you will get some good vfm components.Inactive in TDF.
06-02-2012, 11:57 AM #204
You know, what you can get in 70k budget ???...
But the alienware x51 offers you a very much low end card, paired for 1080p gaming, which in other words called as SH!T. The only advantage here is the service, 1TB HDD & Looks.....Compare then config one to one & find the difference. Compare it yourself.2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
My Game Collection & Sapphire HD 7970 Unboxing
06-02-2012, 12:03 PM #205
@d3: Price of 2500K is still 13K?
I mean is that latest? Money: dollar have come down to 48.3. So I think we should expect decrement in price.
Inactive in TDF.
06-02-2012, 12:11 PM #206
^^ u remember what I said regarding HD 7970? when it was launched @ 35K the dollar rate was rs.51.50, now it comes down to rs.48.60, but still it costs same..why??? as far I am concern MD computers quoted 12.5k for i5 2500K 1 week ago...
Free from tension :D
06-02-2012, 12:52 PM #207
Yeah, I remember that. I'm asking now because, I was waiting for the weekend to go by and then some decrease in price. 13K is too much for 2500K IMO.
Inactive in TDF.
06-02-2012, 01:45 PM #208
I think this link is enough..<link>
06-02-2012, 06:59 PM #209Alpha Geek
- Join Date
- Jun 2007
- Posts
- 688
in order to not be dissapointed i hope for price cuts in april and sep-october/
one or other hardware does drop somehow.
but i think this year new launches will mke price drops so lets wait and watch .
btw i found this Full Kepler lineup revealed
and since ivy comes on apr 8 , this summer is all about pixel power lol.
06-02-2012, 07:05 PM #210
MD Computers also stock
Intel Core i5 2500K is available at 12.48K.Check this outMy Gizmos O_O
14-12-2012, 01:19 PM
Devil Keys
Refback This thread21-07-2012, 11:17 PM -
22-06-2012, 10:52 PM
31-03-2012, 08:36 PM
Mobile Buying Guide: May 2013
By sam in forum Buying AdviceReplies: 890Last Post: 23-05-2013, 10:07 PM -
Help buying Norton Internet Security 2012
By Shibaprasad in forum Software Q&AReplies: 19Last Post: 07-07-2012, 03:40 PM -
New Laptop Guide 2012
By mayoorite in forum Laptops and NetbooksReplies: 0Last Post: 03-06-2012, 08:20 AM -
PS2 buying guide
By satyanjoy in forum GamerzReplies: 1Last Post: 10-04-2007, 03:53 PM
LinkBack URL
About LinkBacks
