Page 4 of 25 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 24 ... LastLast
Results 91 to 120 of 739
  1. #91
    Apr 2008
    Default Re: PC Buying Guide 2012 - Q1
    the point is that the production run's target is an 8 core processor. We did not get quad core gulftown chips
    Selling Palit GTX 580 3GB, EVGA GTX 560 Ti Crysis 2 edition and HIS HD 7970 IceQ X2. Please check the bazaar section for details.
    Civilization and Polandball fans, please support this petition to include a polandball achievement in the upcoming expansion pack!!
  2. #92
    Right Off the Assembly Line linuxman's Avatar
    May 2006
    Intel Core i5 2500k is only 11700? Is it from primeabgb.com?
  3. #93
    In The Zone $$Lionking$$'s Avatar
    Nov 2011
    Extreme Gamer - No no the target is not at all more than 6 core be it intel or amd.
    Here is how 8/10/12 cores are achieved..... AMD MCM Opteron(Socket G34 LO-LGA 1944 pin) you can see 2 processor die in a single chip packaging.... intel does the same... for higher core count cpus....
    Sweet mother of all that is good & pure! ;)
  4. #94
    Apr 2008
    Quote Originally Posted by $$Lionking$$ View Post
    You would be correct for i7 Gen. 1.
    Right now they use the laser for SB-E.
  5. #95
    Nov 2011
    they use laser for what?!
  6. #96
    Apr 2008
    You've never heard of it?!
    High precision lasers are used to separate faulty segments from the main circuit so that the bad chips can still be sold. It can also be done to keep the products within the thermal envelope.
    Why do you think intel has 20 (exaggeration, more like 12-15)different processors from the same die?
    The part you mentioned is used in case yields are very good, so as to substantiate numbers. Bloomfield got that treatment; one QPI link was ignored except to keep the processor components in sync. After that it gets physically disabled.
  7. #97
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Too much off topic discussion is going on. This is not a right place to discuss procerssor architecture, so please don't continue the fighting here.
    And Extreme Gamer, The laser cut part... I didn't understand the relevance of it. I guess Lionking is telling that 6+ core chips are basically Multi-Chip Package (Like the Pentium D processors), having 4 to 8 cores per module in the package. Could you please elaborate a little?
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  8. #98
    gamer Shivam24's Avatar
    Nov 2011
    Planet Earth
    I would like to ask why you guys did not considered AMD FX series processors, mainly the FX8120 and 8150, as according to me they should be included in high end budgets, as their price vs. performance is better than intel's price vs. performance i think...
    intel core2duo e7400 2.80GHz, intel DG41TY, Kingston 3 GB DDR2 800MHz, 1TB seagette SATA, 320 GB WD sata, samsung 22x DVD-RW, sapphire AMD RADEON HD 6870 1 GB GDDR5, CM xtremepower 600W, logitech z506, samsung BX2031N, HCL keyboard, microtek 600VA UPS, Microsoft XBOX360 controller, Nokia Xpressmusic 5320
  9. #99
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    ^^ Nope they are not recommended and they don't offer good performance for the price.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  10. #100
    . Jaskanwar Singh's Avatar
    Feb 2010
    Amritsar
    Quote Originally Posted by The Sorcerer View Post
    Those who are recommending FSP 500w to people: do note that it uses a 4 pin ATX connector. Some people might start getting into the habit of checking the connectors and features before running blind and posting it around without even thinking.
    Just my 2 cents .
    no, see this -
    4+4 pin
    BTW which psu is this?
    Buy Corsair Builder Series VS 450 Power Supply in Mumbai India
    UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
    Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
    HP Pavilion G6 2005AX - Genuine Windows 8 Pro, Samsung Galaxy Y Duos
  11. #101
    Human Spambot The Sorcerer's Avatar
    May 2008
    Quote Originally Posted by Jaskanwar Singh View Post
    but it was such a vfm psu
    I've said it before: I know about 400w unit, that is similar to Gigabyte Superb 460. Anything other than that with FSP is something I don't know. I don't know what vfm part you're referring to, but that 500w unit was always 4 pin ATX connector.
  12. #102
    Feb 2010
    Amritsar
    sorcy post updated
    bigger image -
    ImageShack® - Online Photo and Video Hosting
    but yes the FSP Saga II 400 uses 4 pin connector. i used it before.
  13. #103
    Nov 2011
    Planet Earth
    Can anybody explain me logicwise why AMD FX series processors have not been recommended?
  14. #104
    Feb 2010
    Amritsar
    Quote Originally Posted by Shivam24 View Post
    a Phenom II 1100T BE beats FX8120 in most things.
    AMD Phenom II X6 1100T versus FX-8120 Performance Guide
  15. #105
    Nov 2011
    Extreme Gamer - Yeah... I was saying what Cilus explained... So I cudnt figure out where did lasers come from??! hehehe..
    anyways... any update on Asus situation?
    Shivam - FX 8120 shud be definitely considered... because every week here atleast 5 guys are coming and saying hey we want a rendering machine.... and for less than 2500k... and with 8 cores 8120 definitely deserves a mention!!!
    Jaskanwar - Bhai, 1100T beats it in most things but in purely core oriented apps the case is reversed.... isnt it??
  16. #106
    Nov 2011
    Planet Earth
    i am not asking to replace amd with amd FX, but with intel i5/7 in your high end gaming configs.
    please visit the link:
    AMD FX Competitive Comparison
    if the reasons stated in above link are true then why not suggest AMD FX series, if these are false, then give me the proof...
    as they seems to be better than i5/i7 series, ....
  17. #107
    Human Spambot MegaMind's Avatar
    Nov 2010
    Perambalur, TN
    8150 vs 2500k
    8150 vs 2600k
    Count it yourself & see which is better...
    i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
  18. #108
    May 2008
    There is a 4 pin 500w FSP unit that is available easily. If anyone is recommending it, mention the series as well. I am not sure of the rev version either, but keep these in mind before recommending it to anyone.
  19. #109
    Aug 2009
    Gotham City
    The link you provided comes from amd themselves and its to bias people. Read unbiased and neutral reviews to know more.
  20. #110
    Nov 2011
    Planet Earth
    Quote Originally Posted by MegaMind View Post
    8150 vs 2500k
    8150 vs 2600k
    but don't you see there is a price difference of 3k between 8150 and 2600k, which you have just compared in above link, Provided below is the link of a leading shop in Delhi, prices given are final, inclusive all taxes...
    http://www.costtocost.in/list/pricelist.pdf
    now you tell me which is better...
    OK FINE, I HAVE SEARCHED FOR THE COMPARISONS BETWEEN 2500 AND 8150, AND ITS BEEN CLEAR TO ME THAT 8150 IS A DISSAPOINTMENT...
    AMD FX-8150 vs. Core i5-2500K and Core i7-2600K CPU Review | Hardware Secrets
    Power Consumption: FX 8150 v i5 2500k v i7 2600k | KitGuru
    AMD Bulldozer FX Processors Benchmark Results vs Core i7 2600K - Lenzfire
    ISSUE SOLVED!!!!
  21. #111
    May 2008
    How many of you guys know about this: http://svgtech.net
  22. #112
    Apr 2008
    intel doesn't follow that design. During fabbing, they either don't focus on unwanted segments beyond synchronization(lasting off the rudimentary section later) or they laser off bad segments of failed chips to get some ROI.
    If AMD's method was followed, LGA 2011 would not be shared by both desktop and server. Traditionally intel's designs have not been as modular as amd's.
    No update on asus situation
  23. #113
    Aug 2009
    Gotham City
    How many of you guys know about this: svg tech
    Nope didn't knew about this. Are they good?
  24. #114
    Feb 2010
    Amritsar
    its not Saga II 500. its Saga+ 500R you are talking about.
  25. #115
    Feb 2010
    Amritsar
    check till 70k -
    Motherboard Notes -
    1. rev 3.1 of Gigabyte GA-78LMT-S2P is better for overclocking. rev 4.0 cuts on phases to 3+1 instead of 4+1. Also rev3.1 hits its capability threshold with an x6 at 1.45V protective shutdown at this point despite cooling. And rev3.1 supports 140w processors onstead of 95w support of rev4.0. So try to find rev3.1 of that board.
    2. Gigabyte GA-880GM-D2H also has same case. rev3.1 is better. has 4+1 phase design and supports 140w processors and oppsoed to 95w support and 3+1 phase of rev4.0.
    Sub 20k (Best for office work,movies,downloading)
    Optional upgrades for 20k -
    Sub 25k (Best for office work, multimedia)
    Optional upgrades for 25k -
    Sub 30k (Casual gaming,multi media)
    Optional upgrades for 30k -
    Sub 35k (Entry level gaming,multi media)
    Optional upgrades for 35k -
    Sub 40k (Mid range gaming,multi media)
    Optional upgrades for 40k -
    Sub 50k (Mid range gaming)
    Sub 60k (High end gaming)
    Sub 70k (High end gaming)
    Biostar TZ68K+ review -
    Biostar TZ68K+ - Energy-Efficient LGA1155 Mainboard for Thrifty Users - X-bit labs
  26. #116
    Mar 2009
    Kolkata
    Jas, in the Sub 50K one, I think we can go with AMD Phenom II X6 1090T @ 8.8K + CM Hyper 212 EVO @ 2K combo. This config really offers better tweaking capability and Multi-threaded performance than i5 2400.
  27. #117
    saz
    saz is offline
    Broken In saz's Avatar
    Mar 2011
    Delhi
    well, I was following this guy last year on another forum (here) who was
    working on the Liquid cooling project but I was not sure if his project was successful as the website link was not working. But glad to see he was finally able to come up with successful liquid cooling solution
    AMD Phenom II X4 955 | GA-880G-UD3H | 2X2GB Corsair 1333Mhz | Segate 500 GB + WD 500 GB | Corsair H50 | HD6770 |Tacen Supero 500W | CM430
  28. #118
    MasterZ of Yahooo !!!!! Brazen's Avatar
    Sep 2011
    System32
    Thumbs up Re: PC Buying Guide 2012 - Q1
    Quote Originally Posted by linuxman View Post
    Yes same question here Any online Store where We can buy 2500K for this price ???
  29. #119
    Feb 2010
    Amritsar
    MSI Active Phase Control blowing
    Quote Originally Posted by Cilus View Post
    http://www.thinkdigit.com/forum/pc-c...ml#post1558127
    Quote Originally Posted by Brazen View Post
    updates are coming.
    guys is Intel Core i7 2600K worth at 18.9k for 100k rig? or 2500k + 7970.
  30. #120
    d3p
    d3p is offline
    PowerHouse d3p's Avatar
    Jan 2010
    Bangalore
    2500k + Asus P8Z68 Pro + 7970....My Vote.
    2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
    My Game Collection & Sapphire HD 7970 Unboxing
  1. Mobile Buying Guide: May 2013
    By sam in forum Buying Advice
    Last Post: Yesterday, 11:05 AM
  2. Help buying Norton Internet Security 2012
    By Shibaprasad in forum Software Q&A
    Last Post: 07-07-2012, 03:40 PM
  3. New Laptop Guide 2012
    By mayoorite in forum Laptops and Netbooks
    Last Post: 03-06-2012, 08:20 AM
  4. PS2 buying guide
    By satyanjoy in forum Gamerz
    Last Post: 10-04-2007, 03:53 PM
