Page 19 of 25 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 LastLast
Results 541 to 570 of 739
  1. #541
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Default re: PC Buying Guide 2012 - Q4
    Ya, 2500K is a better choice. I think we can have a separate config with H77 + i5 3550 combination if someone wants an Ivy Bridge rig.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  2. #542
    . Jaskanwar Singh's Avatar
    Feb 2010
    Amritsar
    sure cilus.
  3. #543
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Quote Originally Posted by Jaskanwar Singh View Post
    ya right, cilus. 2500k it is at 12.8k then?
    I think you should know that locally its still 12.2K
  4. #544
    Nov 2004
    Can you guys include a STRICT Budget HTPC ?
    Features like
    HDMI
    DOLBY
    1080p
    Multi format.
    wifi (if possible)
    USB 3.0
    Most of the machine 25-30k range will do that but i see that gigabyte a55 doesn't include a HDMI port rather it have a DVI port.
    So kindly suggest and include that in the template
    And Thank you all of you for dedicating time in building this thread...
  5. #545
    Mar 2009
    Kolkata
    DVI port is enough unless you are using your LCD TV or Monitor with in-built speakers. The only diff between HDMI and DVI is that HDMI can carry both digital Video and Audio signal whereas DVI can carry only Video signal. But the video quality offered is smae for both.
  6. #546
    Feb 2010
    Amritsar
    Quote Originally Posted by d6bmg View Post
    ok sir.
  7. #547
    SoLa BeLLaToR... RiGOD's Avatar
    Feb 2012
    Migrator
    I guess we should use this board for budget builds instead of P8H61-M LX.
    AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
  8. #548
    Away from Forums, Again! desiJATT's Avatar
    Jan 2012
    Jalandhar, India.
    Bumping to get advice on these suggestions by me, made earlier this thread.
    Quote Originally Posted by desiJATT View Post
    Guys I think we should have a look at these - Cabinets Price List India: Computer Components: Flipkart.com
    Lancool cabinets are now available at Flipkart. It's priced between 3.5k to 5.5k for some lower end models and ranges upto 12k for higher end ones. I think we can recommend the Lancool PCK56 and PCK56W which are available at 3.5k and 3.7k respectively.
    For those looking something above the NZXT Source 210 (Most people can't find it anyways, not available in North India and many other parts), and below 4k, Lancool can be a good option.
    These cabinets will beat the Cooler Master 431, and 430 models by a good margin. They have better looks, transparent window (PCK56W model), cable management, and also comes with 2 fans built in as compared to 1 fan in CM, no cable management, and costly choices.
    I think instead of adding NZXT Source 210 Elite, we should now add Lancool PCK56W in all PC configurations above, posted by RiGOD.
    Moreover, we should stop recommending Altec Lansing BXR1221. Many people have had bad experience with them including me, my sister and my two friends. Instead, Creative SBS235 2.1 Speakers are much much better choice, costs 1300 in local market, base output is good,sound is very crisp and clear, mids are also good. Overall it's a much better choice over BXR1221.
    Lol no
    Well I already specified that, most people can't find NZXT Source 210, and some people are willing to go for CM 431 and 430. This cabinet will be best for them.
    So here's a little hierarchy chart on which cabinets people buy with different budgets under 5k -
    1.8k - CM 310
    2.2k - CM 311
    2.4k - NZXT Source 210 2lite
    2.7k - NZXT Gamma
    3.2k - CM 311 Plus, CM 430
    4k - CM 431
    4.4k - Corsair 300R
    Now I want to change the second and third last options to Lancool PCK56W instead of 311 Plus, CM 430, CM 431. Obviously Corsair 300R is way better choice over Lancool and CMs, but it'a price is a little over 4.4k, so people refrain from buying it.
    Review : Samsung Galaxy S3 I9300
    How well will this game run on my Graphics Card
    Gaming Rig
    AMD Phenom X4 960T | Gigabyte GA970A-UD3 | Corsair XMS3 4GB | Gigabyte HD7850 OC | Caviar Blue 500GB | Seasonic S12II 520W | Dell ST2320L | Corsair 300R
  9. #549
    Feb 2012
    Migrator
    ^^BitFenix Merc Alpha is also a good alternative to NZXT Source 210 Elite. Atleast they're of the same price range.
    I see no point in going for CM Elite 430/431 for high end builds as cable management is kinda pain in them. In that range PC-K56/K56W can be suggested.
  10. #550
    Nov 2004
    Still if DVI than what will be the config for HTPC ?
  11. #551
    Jan 2012
    Jalandhar, India.
    Quote Originally Posted by RiGOD View Post
    Yes, Merc Alpha can also do the Job. But there are MANY people who go for CM 430 and 431, everytime they do, my heart cries
    Gaming Rig
  12. #552
    Aug 2011
    Kolkata
    Quote Originally Posted by blackbird View Post
    Can't get you mate.
    Cause, they have transparent side panel. Marc Alpha haven't.
  13. #553
    In The Zone dfcols71's Avatar
    Feb 2012
    Moreover, we should stop recommending Altec Lansing BXR1221. Many people have had bad experience with them including me, my sister and my two friends. Instead, Creative SBS235 2.1 Speakers are much much better choice, costs 1300 in local market, base output is good,sound is very crisp and clear, mids are also good. Overall it's a much better choice over BXR1221.-desiJATT
    i didnt find any reviews of Creative SBS235 2.1 Speakers,if you can find one please post
    altec lansing has few reviews
    Altec Lansing BXR1221 - PC multimedia speaker system Review | ZDNet
    more viewer feed back of altech lansing BXR1221 over Creative SBS235 2.1 in flip kart seems to be better
    i 7 2600k/asrock z77 extreme 6 /sg barracuda 1000m003 1tb/corsair 120 gb force 3/asus243bst/corsair hx850/msi 7870 oc tf iii/gskiils sniper1600 2x4gb/nzxt phantom 410/asus ml238h/coolermaster 212 evo/altec lansing br1221/apc 1.1 kva/logitech mk320 combo
  14. #554
    Aug 2011
    Kolkata
    Logitech Z313 could also be suggested which is being sold @1.7K
    It was there in previous versions of guides but I don't know why it was removed.
  15. #555
    Apr 2012
    In PC config, add a starter PC at 15k for school students & also a best HTPC config with mini-ITX for power saving. Many indians dont know about mini-itx which is very much popular in west..
    Now celeron 430 processor is available at flipkart & also mini-itx motherboards
  16. #556
    Aug 2011
    Kolkata
    Should 3770K be suggested over 2600K? Ever?
    Pros:
    1-3% better performance over i7 2600K at 4.7GHz (iGPU not included).
    HD 4000 performs better than the HD 3000, but if you're using a discrete graphics card, it won't matter. It also won't affect Quick Sync times that much, either.
    Supports PCIE 3.0, but only about a 1% improvement with a HD 7970 and GTX 680.
    Cons:
    ~30% higher temperatures over an i7 2600K at 4.7GHz
    No power consumption advantage over an i7 2600K at 4.7GHz, even though it's using .5V less.
    After analyzing these facts, I would definitely say, no.
    Wait for HasWell.
  17. #557
    Live.To.RISE. rajatGod512's Avatar
    Aug 2011
    Kanpur,India
    Pls Help Anyone Quick : Which one of these speakers should I buy ?
    1. Creative SBS A335 @ 1.675k
    2. F&D A-520 @ 1.617k
    My usage are Gaming , Some Music Listening and Watching Movies.
    The Final Avenger
    Core i7 2600k|ASUS P8Z77-V LX|G.Skill Ripjaws X 1600 Mhz 8GB (4x2)|Gigabyte HD 7850 2GB OC|WDC Blue SATA III 500 GB +160GB |Asus DRW-24B5ST|Seasonic S12II-520|CM 690 II Advanced USB 3.0 (Transparent Side Panel)|Logitech G300|Logitech K100|F&D A-520|Razer Goliathus Speed|Compaq 510|Samsung Galaxy Y GT-S5360|
    “Today, at the edge of our hope, at the end of our time, we have chosen to believe in each other. Today, we face the monsters that are at our door. Today, we are canceling the apocalypse!”
  18. #558
    Feb 2012
    Migrator
    ^^F&D A-520 is a steal for that price. Just placed an order for A-510.
  19. #559
    Aug 2011
    Kanpur,India
    order placed for A-520 .
    The Final Avenger
  20. #560
    Feb 2012
    is this a good deal
    Combo Offer
    ASRock Z68 Extreme3 Gen3 Motherboards
    Intel Core i7-3770K 3.5 GHz Processor
    Gskill F3-12800CL9S-4GBXL X 2
    rs-Rs. 28,450.00
    Buy ASRock Z68 Extreme3 Gen3 i7-3770K RAM 8GB in Mumbai India
    primeabgb edited the link actualy it was showing i7 3770k ,but now they have changed it to i5 3570k so not worth the deal
    as proof of their editing there is no cpu i7 3570k only i5 3570k
  21. #561
    MasterZ of Yahooo !!!!! Brazen's Avatar
    Sep 2011
    System32
    Arrow re: PC Buying Guide 2012 - Q4
    Guys & geeks Urgent Help required here for IVY Bridge Config:
    please suggest me few IVY bridge config ,please also include 1-2 VFM Config:
    with I5-3550 & i5-3570 in your suggestion. I have CM Elite 335 Cabinet so pls exclude it.
    Planning to buy asap as prices gona shoot up for sure & products getting out of stock (called SMC where all ivy bridge already sold )
  22. #562
    Feb 2012
    Migrator
    ^^Make a new thread mate. It'll be more effective.
  23. #563
    Aug 2011
    Kolkata
    Quote Originally Posted by dfcols71 View Post
    is this a good deal
    Combo Offer
    rs-Rs. 28,450.00
    Intel Core i7-3570K
    They are misleading people.
    But specification wise not as good as Logitech Z313 which is also available @1.7K.
  24. #564
    Super Moderator Skud's Avatar
    Jun 2004
    10 light years away
    Can we recommend this for the high end builds?
    Buy Crucial 128GB m4 2.5 inch SATA 6GBs SSD in Mumbai India
    Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
    HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
    Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
    Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
    Android: Galaxy R | Galaxy Y
  25. #565
    Aug 2011
    Kolkata
    Quote Originally Posted by Skud View Post
    Price is very good. So, recommending? Why not?
  26. #566
    Feb 2012
    crucial is very good but any idea of its warranty details in india
  27. #567
    Aug 2011
    Kolkata
    @Jas: Update time mate!
  28. #568
    Feb 2010
    Amritsar
    very little left d6bmg
  29. #569
    hNs
    hNs is offline
    Jun 2012
    Kolkata, India
    thanks a lot...helped a ton because I am planning a update to my very old amd sempron (socket 775)
  30. #570
    Mar 2009
    Kolkata
    Very old AMD Sempron is not LGA 775 based, it is either socket 939 or AM2 based. LGA 775 is an Intel Socket standard, not AMD.
  1. Mobile Buying Guide: May 2013
    By sam in forum Buying Advice
    Last Post: Today, 12:46 AM
  2. Help buying Norton Internet Security 2012
    By Shibaprasad in forum Software Q&A
    Last Post: 07-07-2012, 03:40 PM
  3. New Laptop Guide 2012
    By mayoorite in forum Laptops and Netbooks
    Last Post: 03-06-2012, 08:20 AM
  4. PS2 buying guide
    By satyanjoy in forum Gamerz
    Last Post: 10-04-2007, 03:53 PM
