Results 1 to 4 of 4
11-12-2011, 03:19 PM #1Right Off the Assembly Line
- Join Date
- Dec 2011
- Posts
- 10
Multimedia/Medium-level gaming PC required.Need advice on configution
hi, everyone. i require a new Desktop PC as my present PC is 7 years old and giving me pain in the neck.Please suggest a good configuration:-
Here's my Questinnaire :-
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:Watch HD movies,Medium level games(like Call of duty:Modern Warfare 3, Battlefield 3, etc.)
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:Yes
3. What is your MAX budget?
A:30,000
4. Planning to overclock?
A:Yes
A:Windows 7 Home Preemium
A:>1TB
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A:Already have one. 20" Lg e2040, 1600x900
A:3
A:Assembler
A:Within 2 Months
A:Yes, Definitely
A:Monitor,Keyboard
A:Kota,Rajasthan. yes i can manage that
A:It should be fast, and be able to run most of the games smoothly. Hd movies should not run slow and Multitasking
14-12-2011, 07:58 PM #2Right Off the Assembly Line
- Join Date
- Dec 2011
- Location
- Konohagakure
- Posts
- 17
Re: Multimedia/Medium-level gaming PC required.Need advice on configution
Total:Rs 31500
Stick with this 250GB HDD for the time being as HDD prices have sky rocketed due to floods in Thailand and get a new 1TB one when the prices come down
14-12-2011, 11:42 PM #3
ntel Core i5 2400 @ 9500
Intel DH67CL-B3 @ 5400
Corsair 1333 MHz 4GB X 1 DDR3 Value RAM @ 1200
Corsair GS 600 @ 4000
NZXT Gamma @ 2.5k
Sapphire HD 6790 @ 8k
Asus DVD burner @ 1k
Total: 31.5K
(not a balanced rig, missing UPS)
I have posted this config only for the purpose of giving you the rough overview of Intel based rig at your budget. Better option is to go with AMD config:
AMD Phenom II X4 960T 3.3 GHz Thuban @ 6.5K
Gigabyte GA-880GM-USB3 @ 4.8K
Gskill 4GB X 1 1600 MHz DDR3 Ram @ 1.6K
Corsair CX500 V2 or Tagan StoneRock TG-500 @ 3K
Asus Black 24X SATA DVD R/W @ 1K
Sapphire HD 6790 1GB GDDR5 256 bit @ 7.9K
NZXT Gamma Cabinet @ 2K
250 GB Seagate SATA @ 3K
Intex 1KVA UPS @1.9K
Total: 31.7K
(AMD based config was given by Clius in another thread)
15-12-2011, 01:06 AM #4
d6bmg, good suggestion. Just to clear a little about the 960T, here is the details:-
Phenom II X4 960T is not same as the other X4 processors like Phenom II X4 955 or 965. It is based on the Thuban architecture, same architecture powering the Phenom II X6 processors. So it supports Turbo core technology for dynamic CPU speed increase and better power and temp management. It is also a 95W TDP processor.
The best thing is it is just a 6 core Thuban with two cores disabled. With 99% success till date those two cores can be unlocked to make it a full fledged Thuban Phenom II X6 processor.AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
Buying advice for a medium segment PC
By aaruni in forum PC Components / ConfigurationsReplies: 5Last Post: 02-06-2012, 12:32 PM -
Medium gaming config between 35-40 K
By guru_da_preet in forum PC Components / ConfigurationsReplies: 21Last Post: 29-05-2012, 10:09 PM -
Rig Config: Medium/High End Gaming
By TheCentralGovernment in forum PC Components / ConfigurationsReplies: 34Last Post: 14-03-2011, 10:22 PM -
Urgent : Need to purchase a medium range gaming + multimedia pc for Under Rs.30000000
By whoru007 in forum Hardware Q&AReplies: 6Last Post: 28-02-2010, 12:59 PM -
New pc for multimedia and medium gaming
By junkyardmob in forum QnA (read only)Replies: 10Last Post: 04-10-2005, 05:06 PM
LinkBack URL
About LinkBacks
