Results 1 to 7 of 7
  1. #1
    Sep 2011
    Default Upgrade again...Suggestion please
    Currently i have two PCs
    My dad wants a pc for learning and movies. So i planned to give him the pentium D pc and upgrade the core 2 duo
    Here is my plan. Please suggest me the components. My total budget is 30k. Not urgent may be buying one by one for next two months
    I am not filling the template, because the requirement is mixed for 3 PCs
    PC1
    Usage - gaming, HD movies, photo editing
    CPU - i am going to OC in the future
    Motherboard - Should support crossfire for 6850, usb 3.0 required, 7.1 good audio
    RAM - 8gb
    PC2
    Usage - Surfing, interactive cd/dvd for my kid
    Monitor for PC2
    I want a 24" TN panel for dual setup with PC1(asus PA238Q) and used for gaming.
    PC3
    Usage - watching movies and photos. Learning computers for my dad
    I dont want spend much on these so PSU+Case max budget is 2k
    Please suggest me if you have any alteration
    Below is my current configs. The "?" are the required components
    Thanks,
    Mani
    i5 2500k 3.3Ghz + CM Hyper 212 Evo |MSI Cyclone R6850 PE/OC |Asus P8Z68 V/Gen3 |Gskill Ripjaws 1600Mhz 2x4GB |Corsair GS600 |NZXT Gamma |ASUS PA238Q IPS+ BenQ G2420 |Seagate 1TB+500GB |ASUS 24X DVD RW
  2. #2
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Default Re: Upgrade again...Suggestion please
    Please clarify one thing. You have posted:
    I guess that's for each PC, right?
    And also tell the list of component which you already have.
    Inactive in TDF.
  3. #3
    Sep 2011
    Thanks for the reply d6bmg...
    The above table is having all the components which i already have. Only the "?" are required. The total budget is 30-35k is for all three PC, not each PC.
  4. #4
    Aug 2011
    Kolkata
    PC1:
    CPU:- AMD Phenom II X6 1090T @9K
    CPU Cooler:- stock
    Motherboard:- MSI 890GXM-G65 @6.8K
    RAM:- Gskill F3-12800CL9D-8GBXL @3.1K
    PC2:
    Monitor:- Benq G2420 @10.8K (don't know much about its quality, wait for other members advise)
    PC3:
    PSU:- FSP SAGA II 500W @ 2.2K
    Case:- Zebronics Bijli cabinet w/o SMPS @ 1.1K
    Total: 33K
    Inactive in TDF.
  5. #5
    Sep 2011
    I am more interested in intel...
    CoolerMaster CMP 350 Case+PSU - Hardwire.in Is this good for PC3?
  6. #6
    Whompy Whomperson Nipun's Avatar
    Mar 2011
    New Delhi
    Stay away from CoolerMaster PSU..
    And if you need more info about G2420, skud can help. He also has same monitor
    And going for FSP Saga II 400w will be better for PC3, as it has no high end components...
    The beauty of Indian roads is that one needs to look on both sides while crossing a one way road!
    ▒▒ ¯TF2 COMIC MAKER!_ ▒▒
    Drive sensibly, please!
    Educated Illiterates
  7. #7
    Aug 2011
    Kolkata
    PC1
    Intel is possible at your budget, buy you won't get a 'K' series CPU. So, you can't overclock it. So, what I'm trying to say is that if you opt for Intel, then you have give away your choice of OC'ing the CPU.
    Inactive in TDF.
  1. Need suggestion for RAM upgrade
    By StrYker_BLACK_E in forum PC Components / Configurations
    Last Post: 11-05-2012, 07:55 PM
  2. Rig Upgrade Suggestion!!!!!!!
    By max_snyper in forum PC Components / Configurations
    Last Post: 31-12-2010, 08:23 PM
  3. Suggestion For Upgrade
    By imgame2 in forum Hardware Q&A
    Last Post: 10-05-2010, 02:34 AM
  4. Upgrade Suggestion
    By nregmie in forum Gamerz
    Last Post: 06-11-2007, 08:52 AM
  5. Upgrade Suggestion
    By nishant_nms in forum Hardware Q&A
    Last Post: 07-08-2006, 01:21 PM
