Results 1 to 4 of 4
Thread: Need Webcam under Rs 1000/-
14-11-2011, 11:00 AM #1
hi
I need a webcam to be used with a desktop computer under Rs 1000/-
Please suggest some good webcam.....
It is for Home use.
Thanks
14-11-2011, 02:13 PM #2
Re: Need Webcam under Rs 1000/-
^ add few more hundreds & grab this HD webcam from Logitech.
Logitech HD C310 - 1.3k.....Click Here for the Features.
I have paid 1.3k almost 8 months back, so now the price will be close to 1k.
Or even consider buying Logitech HD Webcam C270h as its price is somewhere close to C310 & it comes with a Headset also instead on mic embedded with webcam.2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
My Game Collection & Sapphire HD 7970 Unboxing
14-11-2011, 03:00 PM #3
are you able to experience HD video chat ?Registered LINUX USER #438929
14-11-2011, 03:06 PM #4
Yes, if you have a decent connection like 512KBps or Higher than its really awesome.
Especially with SKYPE, its good.
Otherwise the FPS drops & image looks little bit blurry to the otherside, but not to you.2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
Laptop from the US, under $1000
By pranav0091 in forum Laptops and NetbooksReplies: 18Last Post: 07-07-2012, 12:18 PM -
Laptop under 1000 GBP
By Faun in forum Laptops and NetbooksReplies: 0Last Post: 02-07-2012, 02:00 PM -
Webcam between Rs.500-Rs.1000
By Tachyon1986 in forum PeripheralsReplies: 1Last Post: 26-07-2011, 10:59 PM -
1000+ Proxy's for you
By hullap in forum Chit-ChatReplies: 29Last Post: 08-02-2010, 09:57 PM -
Rs 1000 for 0.2 GHz?
By danny_geo in forum QnA (read only)Replies: 5Last Post: 24-11-2004, 09:40 AM
LinkBack URL
About LinkBacks
