Results 1 to 17 of 17
  1. #1
    Nov 2011
    Lucknow
    Default Suggestion for gaming PC
    Hello,
    I am seeking suggestion for my gaming PC.
    I don't know very much about computer hardware,so please suggest me for the configuration for my PC,my budget is around Rs.30000.
    My main work on PC using internet,some assignment work and the formost is playing games,usually like Assassins Creed:Brotherhood,Call of Duty:MW3 and such big games.
    Please give your valuable suggestion for it.
  2. #2
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Default Re: Suggestion for gaming PC
    Well, won't ask you too much technical question then. Just let me know if you wanna buy all the components like Monitor, Sound box, Keyboard, Harddisk or you do have some components. If yes, then let us know the components you already have.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  3. #3
    Nov 2011
    Lucknow
    Yes, have to buy all of them, and by all of them i mean whichever necessary and best i can get in this budget.
  4. #4
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Suggestion originally given by: Jas. I've only changed the cabinet.
    Inactive in TDF.
  5. #5
    Nov 2011
    Lucknow
    Thanks for the suggestion!
    What if i want i5 2320?
    Budget no bar!!
  6. #6
    Mar 2009
    Kolkata
    Quote Originally Posted by vishilu7 View Post
    Budget no bar!!
    ^^ Mention the budget buddy; configs really exists for budget no bar and I don't think if we post those things here, you're gonna like it.
    So 1st thing 1st: Mention your Total budget 1st.
  7. #7
    Nov 2011
    Lucknow
    Actually i just wanna know the best processor for gaming pc...
    Still,i come to my perspective,i am increasing my budget till 45k.
    And please-please suggest 2 or 3 different graphic card as an option..
    Thanks a lot for your concern.
  8. #8
    Pro/An---tagonist xD
    Dec 2009
    Kolkata
    ^ You mentioning the budget helps a lot mate. Otherwise you could have ended up with a suggested config costing a lakh or even more.
    Desktop :- Amd athlon II X3 435 unlocked to Phenom II X4 B35 | MSI 785 G-E53 | MSI R6850 Cyclone power edition [OC edition] | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz | Corsair GS600 | Seagate 500 gb 7200.12 | Cooler Master CM 690II Advanced | Dell ST2220L |
    Laptop:- Dell Inspiron 15R Turbo => i5-3210m,4gb RAM, 1 tb HDD, AMD HD 7730M 2gb.
  9. #9
    Nov 2011
    Lucknow
    Quote Originally Posted by Jripper View Post
    rightly said...
    It took a bit for me to understand that!
  10. #10
    Mar 2009
    Kolkata
    If 45K is the budget, then the config from my side is:
    Intel Core i5 2400 @ 9.7K
    Intel DB67CL-B3 Full ATX @ 5.6K
    Corsair Value 1333 Mhz DDR3 4GB X 1 @ 1.2k
    Seagate 250GB 7200.12 3.4k
    LG 22X DVD Writer SATA @ 0.85K
    Corsair GS600 80+ PSU @ 4K
    NZXT Gamma Cabinet @ 2.2K
    Acer P206HQ 20" Display @ 5.2K
    MSI Cyclone Power Edition HD 6850 @ 9.7K
    Logitech MK200 Keyboard & Mouse @ 0.7K
    ALTEC LANSING BXR1221 @ 1K
    Intex 1KVA @ 1.9K
    Total 45.5K
  11. #11
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    If possible the above monitor can be ditched in favour of benq g2220hdl for 6.8k. Its fullhd and has led backlighting.
    The speakers should be logitech z313 @ 1.4k. They are better than bxr1221.
    Rest of the config is perfect except for harddrive. But considering current high prices due to thailand floods, very little can be done on that aspect.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  12. #12
    Nov 2011
    Lucknow
    I am really thankful to u..
    Please let me know that in graphic card,i could have anything better with increase in budget 2k-3k for graphic card or as suggested by you is more than enough?
  13. #13
    Aug 2009
    Gotham City
    ^^ Of course you can go for a more powerful gpu if you really want to. It will increase your overall budget. iF you are willing to spend 3k more on gpu, then sapphire 6950 1gb dirt 3 edition around 13.5k -14k.
    It will give you an even better experience in games.
  14. #14
    Nov 2011
    Lucknow
    Thanks to all of u guys for giving your valuable suggestions!!!
    Thanks a lot!
  15. #15
    Nov 2011
    Lucknow
    bought my rig!!!
    yet i wonder where my last post has gone?
  16. #16
    Aug 2011
    Kolkata
    ^ Last posts have been deleted during the up gradation.
    Congrats on your purchase and please try to post some pictures of your rig & components on the showoff section.
    Inactive in TDF.
  17. #17
    Nov 2011
    Lucknow
    @d6bmg-thanks!!
    Quote Originally Posted by d6bmg View Post
    ^ try to post some pictures of your rig & components on the showoff section.
    done.
  1. 35k - 40k Gaming PC suggestion
    By Mehul Chauhan in forum PC Components / Configurations
    Last Post: 07-06-2012, 03:32 AM
  2. Need suggestion for gaming rig
    By nieur in forum PC Components / Configurations
    Last Post: 23-06-2011, 04:56 PM
  3. Gaming PC Within 20 - 23k suggestion
    By himanshu978 in forum PC Components / Configurations
    Last Post: 15-11-2010, 10:44 AM
  4. Suggestion for a new gaming rig?Plz.
    By clerkman1612 in forum Hardware Q&A
    Last Post: 19-10-2010, 06:40 PM
  5. GAMING PC SUGGESTION
    By heman12 in forum Gamerz
    Last Post: 07-04-2009, 08:43 PM
