Page 1 of 2 1 2 LastLast
Results 1 to 30 of 43
  1. #1
    Jan 2011
    Talking Advice for High end Gaming cofig (only cabinet + internal parts) - budget 1-1.2 Lakhs
    1: What is your budget?
    1-1.2 Lakhs (CPU only)
    2: What is your existing hardware configuration (component name - component brand and model)
    CPU - Core 2 Duo (2.3 GHz)
    Motherboard - Asus xxx
    GPU - nVidia 9800 GTX+
    RAM - Kingston 2*2GB
    Monitor - BenQ G2400 HD (not looking to replace)
    SMPS - Cooler Master 450W
    3: Which hardware will you be keeping (component name - component brand and model)
    Monitor - Dell 2409
    4: Which hardware component are you looking to buy (component name).
    CPU -
    Motherboard -
    GPU -
    5: Where will you buy this hardware? (Online/City/TE Dealer)
    New Delhi
    Open to online purchase
    6: Would you consider buying a second hand hardware from the TE market
    No
    7: What is your intended use for this PC/hardware
    Gaming, Gaming, Gaming
    Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
    Asus, Corsair, nVidia cards (if ATI offers significant performance upgrade at the same price then I may consider. I really like PhysX effect in games like Mafia II etc. so would prefer an nVidia card.)
    Q: If you will be playing games then which type of games will you be playing?
    Battlefield 3, Skyrim, Heroes VI, COD: MW3
    Q: What is your preferred monitor resolution for gaming and normal usage
    Gaming - 1920*1080
    Desktop - 1920*1080
    Q: Are you looking to overclock?
    Yes
    Q: Which operating system do you intend to use with this configuration?
    Windows 7 64 bit
    May add a sound card later, preferably Asus Xonax STX (7500). Please note that the prices are only indicative and I may decide to delay my purchase by another month (max) in case the dollar prices (and flood issues in South Asia) influence the prices too much. Please let me know what can I change in my system to make it better. For me looks are very important so the best Chasis (Thermaltake Level 10 GT or Corsair Obsidian 800D). Also please let me know whether my choice for graphic card is right or not (several reviews on guru3d, anandtech and overclockers have indicated that 2*560 TI performs better than a single 580).
    TIA
  2. #2
    Human Spambot clmlbx's Avatar
    Aug 2006
    Indore
    Default re: Advice for High end Gaming cofig (only cabinet + internal parts) - budget 1-1.2 Lakhs
    Oftopic:: Ok you want whole system excluding Monitor.. for a moment I thought you just want Processor for 1-1.2L.
    Athlon II X4 635 @ 2.9Ghz Gigabyte GA-MA785GMT-US2H Kingston 2x2 Gb 1333Mhz DDR3 WDC 500Gb Green Palit GTS 250 512mb Tagan 500W Samsung B2030 Lg DVD Writer
  3. #3
    Jan 2011
    LOL.. no dude
    Whole system excluding monitor (BenQ 24") & UPS (Numeric 1KVA) & KB (MS Sidewinder X4) & Mouse (Logitech MX518)
  4. #4
    not an otaku
    Apr 2008
    2nd config. Get a Maximus IV Extreme-Z mobo. Get an H100 cooler from corsair. Get OCZ vertex 3 SSD and change the case to HAF-X.
  5. #5
    Live.To.RISE. rajatGod512's Avatar
    Aug 2011
    Kanpur,India
    Intel Core i5 2500k @11.2k
    Corsair Hydro H80 @6k
    Asus P8Z68-V PRO Motherboard @ 14k
    Gskill Ripjaws X F3-12800CL9D-8GBXL @3.65k
    Corsair Obsidian Series 800D @ 16.5k
    Corsair AX 850 @10.3k
    Western Digital Caviar Black 1TB @6k
    Corsair Force Series 120 GB @12.5k
    2*MSI R6950 Twin Frozr III Power Edition/OC @32k
    Total = approx 1.12 lakhs
    8 GB RAM is more than enough for any rig for now ... almost all games use max. upto 4 gigs(and those games are very few). I too like the obsidian and i would recommend it to anyone and i have changed PSU to AX850 which is a fully modular PSU and 2xhd6950 is more than enough for any game at 1080p (dont quite know about battlefield3 ultra settings) to run on atleast 60 fps.
    The Final Avenger
    Core i7 2600k|ASUS P8Z77-V LX|G.Skill Ripjaws X 1600 Mhz 8GB (4x2)|Gigabyte HD 7850 2GB OC|WDC Blue SATA III 500 GB +160GB |Asus DRW-24B5ST|Seasonic S12II-520|CM 690 II Advanced USB 3.0 (Transparent Side Panel)|Logitech G300|Logitech K100|F&D A-520|Razer Goliathus Speed|Compaq 510|Samsung Galaxy Y GT-S5360|
    On June 14 KNEEL BEFORE ZOD!
  6. #6
    Manchester United <3 Ishu Gupta's Avatar
    Oct 2010
    Noida
    I have seen BF3 using around 6+ GB. And RAM is very cheap. 16GB just sounds cool.
    i5 2500k 4.4GHz @ 1.26v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
    GSkill RipjawsX 2x4GB 1600MHz CL9 | 160GB 7200 + WD Black 2TB | W7 + ArchLinux
    CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
    Razer DA Black + Razer Goliathus | XBox360 wired x2
    Senns HD201 | PSP Slim 8GB MSPD | Xperia U StockICS[Rooted] | Speedtest
  7. #7
    not an otaku
    Apr 2008
    Default Re: Advice for High end Gaming cofig (only cabinet + internal parts) - budget 1-1.2 L
    16GB reduces OC potential Ishu.
  8. #8
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    ^^ How? Is there any revarse relation between OC'ing a processor & amount of RAM?
    @OP:
    If you can, you will get better VFM for every product you buy.
    ASUS P8Z68-V PRO Rs. 11,200.00
    old price. Presently it resides at 13K
    Inactive in TDF.
  9. #9
    not an otaku
    Apr 2008
    more stress on the IMC. This means it needs more voltage on the IMC to get RAM to their rated speeds, and/or looser timings.
    It also means more power through the mobo to the RAM, and slightly lesser to the CPU, which may cause the CPU to need more volts to reach same clocks.
    Source
    Change CPU in rajat's setup to 2600k, place HX-850 instead of AX-850, and switch the H80 for H100. Perfect for the OP.
  10. #10
    Aug 2011
    Kolkata
    Thanks for the explanation, didn't have any idea about that. But the like which you have posted from tom's hardware is invalid. :/
    Inactive in TDF.
  11. #11
    not an otaku
    Apr 2008
    Typo... corrected. TY.
  12. #12
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    Exclamation Re: Advice for High end Gaming cofig (only cabinet + internal parts) - budget 1-1.2 L
    Quote Originally Posted by Extreme Gamer View Post
    But if RAM requires more power, why can't mobo supply required amount of power without compromising on CPU supply?
    If I suppose what you quoted, then it would mean that a mobo is capable of supplying R amount of power(which is constant by your logic), divided into X no of components, and X[p] be the amount/power/measure of component. Now if I increase p, the respective power supplied to the component would decrease gradually. But again my this point contradicts comparing 2GB and 4GB mem, then why this case in 16GB?
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  13. #13
    Oct 2010
    Noida
    Quote Originally Posted by dashing.sujay View Post
    No of DIMMS, not amt of RAM. 8GB modules not available in India?
  14. #14
    not an otaku
    Apr 2008
    not atm. I dont know 8GB sticks past fully buffered server RAM. any models you know?
    There is more load on the involved circuits. The cleanliness of the signal is also affected.
  15. #15
    Aug 2011
    Kanpur,India
    @Extreme Gamer
    Why AX 850 instead of HX 850
    The Final Avenger
  16. #16
    not an otaku
    Apr 2008
    lol its the other way round rajat. the HX850 is awesome. while the AX models are better, the HX is good enough. the price decrease can be used to get H100 and 2600k. his limit is 120k
    if the AX still fits, definitely go for it
  17. #17
    Aug 2011
    Kanpur,India
    LOL !!!! I got it all wrong
    The Final Avenger
  18. #18
    War4Peace masach315's Avatar
    May 2009
    Aizawl
    @almighty rohit. Get the new storm trooper (if it's your taste) than level10gt. You can use the money you save for a nice water cooling kit.
    i5 750, Corsair 2x2GB, DH55TC, XFX HD4850 XXX, CNPS9900A LED, 500GB WD, RealPowerPro 460W, CM690, AOCF22, MX518, Comfort Curve, Windows 7 Ultimate, PS SX120IS, Nokia 1616 :sniper:
  19. #19
    iDota Sarath's Avatar
    Apr 2011
    Bangalore, Visakhapatnam, Abu Dhabi
    Quote Originally Posted by almightyrohit View Post
    No
    TIA
    TE market?
    ◊ Online Shopping guidePS3™ master guidePS3™ vs PC ◊
    Gaming:♦ PS3 ♣ i5|HD6970 Gaming RIG | Dell U2311H review iΡod & iPhone 4 ♥ Xperia™ Arc review
    Audio gear: Logitech Z623 | Klipsch X10 | Siberia V1 | M1 | M2 | CX180
  20. #20
    Oct 2010
    Noida
    Quote Originally Posted by Sarath View Post
    TE market?
    Template copied from TechEnclave.
  21. #21
    Aug 2011
    Kolkata
    Quote Originally Posted by Ishu Gupta View Post
    nvm, I think at first he was trying to post there, and then he copy/pasted it from there.
    Inactive in TDF.
  22. #22
    Nov 2009
    Bhopal
    Then also question remains, why does the power division thing ?
  23. #23
    Apr 2011
    "It also means more power through the mobo to the RAM, and slightly lesser to the CPU, which may cause the CPU to need more volts to reach same clocks."
    That was very useful. But two RAM sticks are fine right?
  24. #24
    not an otaku
    Apr 2008
    Yes.
    Sujau, with 4 sticks the power draw from the atx pin and the CPU pin increases.
  25. #25
    Nov 2009
    Bhopal
    Sujau
    Its Sujay
    Its obvious that 4 sticks will draw more power, but my question is why power supply to CPU is compromised in this case? I guess. mobo is not made to supply limited power supply.
  26. #26
    Wise Old Owl mithun_mrg's Avatar
    Oct 2003
    Assam
    BTW op can choose gskill sniper which runs at 1.25V
    Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
  27. #27
    Nov 2009
    Bhopal
    ^^IIRC ripjaws have more ocn capability than sniper.
  28. #28
    Oct 2003
    Assam
    ^^If i am correct the oc'ing limitations are due to the fact how SB platform oc memory not the ram itself
  29. #29
    not an otaku
    Apr 2008
    Its Sujay
    I was using ipod :damn: sorry.
    There is a limit to the amount of power that can be drawn from ATX and CPU power connectors without frying the mobo.
    Other reason already stated, that there is more stress on IMC.
  30. #30
    Nov 2009
    Bhopal
    Thnx for explaining.
  1. High-end gaming laptop advice needed (Budget around 90k)
    By xOvErClOcKeRx in forum Laptops and Netbooks
    Last Post: 14-06-2012, 03:08 PM
  2. High End Gaming & Graphics Machine- Advice needed
    By digitraju in forum PC Components / Configurations
    Last Post: 02-09-2011, 01:31 PM
  3. Final Check - High End Gaming Rig!! Please Advice
    By Storm_Alias in forum PC Components / Configurations
    Last Post: 25-04-2011, 03:31 PM
  4. High end gaming on a budget
    By GauravCJ in forum QnA (read only)
    Last Post: 12-01-2009, 04:56 PM
  5. WTB: Powerful gaming rig - High Budget - Help!
    By Core i7 965 Extreme in forum Hardware Q&A
    Last Post: 02-12-2008, 12:18 PM
