Results 1 to 5 of 5
  1. #1
    Nov 2008
    Default Gaming rig components required
    1. What is the purpose of the computer?
    A: Gaming, HD Movies
    2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
    A: Yes
    3. What is your MAX budget?
    A: Strictly 40-50 k not a single penny more
    4. Planning to overclock?
    A: No
    A: Win 7 Ultimate (already have genuine one)
    A: already have a 500gb ..will add another 500
    7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
    A: i already have a LG LED monitor ..will NOT change it
    A: 7
    A: yes i have assembled the deskyop myself twice.
    A: in 2 days
    A: Definitely
    A: Speakers, dvd rom, cabinet .. as i am going to buy lexa s nzxt, keyboard and mouse, UPS and the monitor
    A: Delhi so getting it from Nehru Place
    A: I only want to buy the mobo, processor, ram and GPU .. and a configuration that can run for atleast 3-4 years.. also suggest me a good smps.. please donot add other components in the pricing .. and tell me the amount and configuration for only the parts i want
  2. #2
    Aug 2007
    Chinchwad Pune
    Default Re: Gaming rig components required
    Intel Core i5 2400 - 9.3k
    Intel DH67BL-B3 - 5.5k
    G.skill RipjawsX F3-128000CL9S-4GBXL-1.6k
    MSI R6950 Twin Frozr III-15.3k
    Corsair GS600 PSU - 4K
    Total = 34K
    11k Lower than your budget but this can do the job for you.
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  3. #3
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    @op: apart from the above suggestion, you can also add another module of G.skill RipjawsX 4GB kit as it will get into your budget nicely.
    Inactive in TDF.
  4. #4
    iDota Sarath's Avatar
    Apr 2011
    Bangalore, Visakhapatnam, Abu Dhabi
    ^Once again does that mobo support 1600mhz Ram?
    ◊ Online Shopping guidePS3™ master guidePS3™ vs PC ◊
    Gaming:♦ PS3 ♣ i5|HD6970 Gaming RIG | Dell U2311H review iΡod & iPhone 4 ♥ Xperia™ Arc review
    Audio gear: Logitech Z623 | Klipsch X10 | Siberia V1 | M1 | M2 | CX180
  5. #5
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    here's goes mine
    Intel Core i5 2500k @ 10.5k
    ASUS P8Z68-V PRO @ 13k
    G.skill RipjawsX 2x F3-128000CL9S-4GBXL @ 3.8k
    MSI R6950 Twin Frozr III @15.3k
    Corsair TX650 V2 @ 5.5K
    Cm Hyper 212+ @ 1.9k
    even if Op don't want to OC buying a K sku cpu with a quality Z68 mobo makes more sense and he is going to use that rig for next 3-4 years for which the option to OC the core i5 2500k is a must have as it will boost the cpu performance for more demanding games of future
    the cooler will keep the cpu cool enough upto ~4.5 Ghz and with that mpob the cpu can be pushed even higher.
    With TX650v2 OP can add a more powerful gpu or another HD6950 later and 8GB ram is what gamers should get to have a future proof pc
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  1. help!? i'm buying new sparely used gaming comp but are these components good?
    By sota_packed in forum PC Components / Configurations
    Last Post: 23-05-2012, 03:43 PM
  2. pls help me select components for a desktop (for gaming purpose only)
    By NG235 in forum PC Components / Configurations
    Last Post: 07-05-2012, 12:29 PM
  3. confusion in buying components for gaming?
    By tharun313 in forum Graphic cards
    Last Post: 06-02-2012, 05:53 PM
  4. Components required within INDIA
    By longlife in forum Hardware Q&A
    Last Post: 06-09-2007, 08:13 AM
