Results 1 to 18 of 18
20-09-2011, 03:03 PM #1Right Off the Assembly Line
- Join Date
- Sep 2011
- Posts
- 13
Gaming Rig In 30k .. please Help :-D
1. What is the purpose of the computer?
A: Multimedia- hardcore gaming, hd movies
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: Yes, Amd bulldozer ( can wait for it, release date anyone? )
3. What is your MAX budget?
A: 30-32k ( strictly )
4. Planning to overclock?
A: if possible, Yes ( under normal cooling )
A: windows 7
A: 500 gb if budget supports ( i have a 250gb so can exclude HDD frm the budget )
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A: HD 21 inches or more ( HDMI port if possible )
8. How would you rate your hardware knowledge from the count of 1-10?
A: 7
A: yes, i have. this will be my 3rd
A: End of this month or according to the release date of bulldozer
A: yes
A: Speakers, Mouse, Keyboard, Mouse pad
A: Mumbai, will buy stuff from here
A: Dvd writer (if budget supports), usb 3.0 if possible, a decent gfx card.
please suggest both Intel as well as AMD specs
thanks again
Also was Planning to go for Nzxt Lexa S
or guardian 921 Rb
both of them cost around 4k~4.4k according to
Prime ABGB Today's Cool Deal !
suggestions are most welcome
20-09-2011, 03:48 PM #2
Re: Gaming Rig In 30k .. please Help :-D
Bulldozer "Would" Probably come out in the 2nd week of October . So, you should probably wait and let the news come.
20-09-2011, 04:07 PM #3Right Off the Assembly Line
- Join Date
- Sep 2011
- Posts
- 13
20-09-2011, 05:07 PM #4
BTW Intel rig
Intel core i5 2400 @ 9k
Intel DH67VR-B3 @ 4.5k
Corsair Value Series 1333 MHz 4GB X1 DDR3 @ 1.2k
WDC Blue 500GB @ 1.9k
LG 22X SATA DVD @ 0.9k
MSI R6670 GDDR5 1GB Graphic Card @ 5.5k
FSP SAGA II 500W SMPS @ 2k
NZXT Gamma @ 2K
Benq G2220HD @ 7k
TOTAL = Rs.34,000
If you remove HDD From here then it would be 32k
AMD Rig
AMD Phenom II X4 965 @ 6k
Gigabyte GA-880GM-USB3L @ 4.2k
G-skill F3-10600CL9S-4GBNT(4Gx1) @ 1.1k
Seagate 500GB 7200.12 @ 1.9k
FSP Saga II 500W 2k
Sapphire HD6790 1GB - 7.5k
NZXT Gamma @ 2K
Benq G2220HD @ 7k
TOTAL - Rs.32,600
The motherboard which i have suggested is AM3+ Ready which means it is compatible with Bulldozer cpu's.
IF I Would to choose i would definitely take the amd one as it is better overall and has quite better GPULast edited by rajatGod512; 20-09-2011 at 10:10 PM. Reason: I Forgot that you mentioned not to include Speaker , Keyboard and mouse , so I made some changes
20-09-2011, 05:39 PM #5Right Off the Assembly Line
- Join Date
- Sep 2011
- Posts
- 13
20-09-2011, 06:55 PM #6
rajatGod512, Asus M5A78LT-M LX supports CPU upto 95W whereas 965 BE is a 125W CPU. So change the motherboard with something eles, with a 8XX based one.
AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
20-09-2011, 07:04 PM #7Right Off the Assembly Line
- Join Date
- Sep 2011
- Posts
- 13
ure suggestion cilus ???
give whole rig please
try and include lexa s
20-09-2011, 10:12 PM #8
@Cilus Oops!! I forgot to see that, my bad.
I have edited my post , thanks for correcting me.
22-09-2011, 04:19 PM #9Right Off the Assembly Line
- Join Date
- Sep 2011
- Posts
- 13
ne suggestions/?
im getting 6850 for 7k. is it worth?
22-09-2011, 10:47 PM #10
Are you sure its HD 6850 and not HD 6750. If yes then,
HD 6850 @ 7k which brand ... From where??? But yes it is definitely worth actually it's more than worth it ... I think it's a steal!
22-09-2011, 11:00 PM #11
^^ Agreed, HD 6850 at 7K is a ultra superb deal. But make sure it is only HD 6850, not HD 6770 or HD 6790.
23-09-2011, 11:54 AM #12Right Off the Assembly Line
- Join Date
- Sep 2011
- Posts
- 13
yes
and its
Gigabyte HD 6850 Oced To 820 mhz ( i guess its Factry OCed )
dual fans
friend got it from US. Its sealed. he got a mac book pro so he doesnt need the GFX.
so he said i can have it for 7k or so....
Whats the Current cost of 6850 HD of Gigabyte
some says its 12.5k
some says its 10k
some says 8.9k
im confused :S
also how is
AMD A8-3850 Quad Core Gaming Processor ??
and
AMD A6-3650 is quad core processor
23-09-2011, 03:47 PM #13
Looks like a brilliant deal to me . Go for that card. I dont know the exact price of it but it would be around 10k. But IDK.
But what I do know is that AMD'S A8 and A6 are not in the same league as Phenom or the Intel core series .
As these A8 , A6 are APU -(An accelerated processing unit (APU) is a processing system that includes additional processing capability designed to accelerate one or more types of computations outside of a CPU. This may include a graphics processing unit (GPU), a field-programmable gate array (FPGA), or similar specialized processing system.)
This is called as AMD Fusion but to say simply - It is not as powerfull as other processor mentioned.
BTW , back to the card , it also looks Cool
23-09-2011, 03:58 PM #14
The Gigabye HD 6850 OC is a superb card and @ 7K, it is a steal. But keep in mind two things:-
1. The availability of Gigabyte Gfx card is very limited in India.
2. As it is purchased from US, you won't get any warranty support in India unless it has global warranty. AFAIK, the Graphics cards don't come with global warranty.AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
23-09-2011, 05:20 PM #15Right Off the Assembly Line
- Join Date
- Sep 2011
- Posts
- 13
@rajat : card looks awesome.!
im going for it
@cilius :- friend said it has 3 years warranty but sadly only in STATES
he said if the card gives problem in future it'll take @least 4-5 months for him to get it replaced or whateva
but im for the the card newaz
hope it works for @ 2+ years widout problems
Check your inbox please
hows the following ?
23-09-2011, 05:56 PM #16Right Off the Assembly Line
- Join Date
- Sep 2011
- Posts
- 13
images for cilus
23-09-2011, 06:05 PM #17
Replied, Please check. BTW, I will provide my suggestion for your rig with explanation in today night.
23-09-2011, 06:22 PM #18Right Off the Assembly Line
- Join Date
- Sep 2011
- Posts
- 13
To get Logitech G15 Gaming Keyboard and MX518 Gaming Mouse
By debasis_7012005 in forum Hardware Q&AReplies: 24Last Post: 10-09-2007, 02:37 PM -
what's the difference btwn Online gaming & Internet gaming
By singh in forum GamerzReplies: 2Last Post: 12-08-2006, 12:03 PM -
Can small gaming companies suceed in todays gaming market
By Charley in forum Technology NewsReplies: 16Last Post: 03-03-2005, 10:56 PM
LinkBack URL
About LinkBacks
