Results 1 to 2 of 2
Thread: Mid range gaming rig under 30k
19-09-2011, 09:08 PM #1Right Off the Assembly Line
- Join Date
- Sep 2011
- Posts
- 2
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: A home build, gaming , HD movies, internet surfing & bit of downloading, a little office work.
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: sure
3. What is your MAX budget?
A:~30000
4. Planning to overclock?
A: yes if possible
A: win 7 32bit or 64 bit
A: 1TB
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A: I want 20" LED from a decent brand
A: 6
A: assembler
A: within a month
A: yup, why not
A: no
A: Rajkot, Gujarat
A: graphic card & motherboards are two things that often put me into dilemma.Last edited by RishIT; 22-09-2011 at 01:45 PM.
20-09-2011, 08:57 PM #2
Re: Mid range gaming rig under 30k
Please fill up this: http://www.thinkdigit.com/forum/pc-c...-template.html
before you can get any suggestion(s).Inactive in TDF.
Gaming Rig within range of 30 K
By shuro in forum PC Components / ConfigurationsReplies: 16Last Post: 12-06-2012, 12:45 AM -
Mid Range Gaming Rig for 45k!
By tasamono in forum PC Components / ConfigurationsReplies: 6Last Post: 29-09-2011, 10:44 AM -
MID Range Gaming PC
By Omi in forum PC Components / ConfigurationsReplies: 9Last Post: 24-07-2011, 09:19 AM -
Sub 53k(mid range gaming)
By Da_Avenger in forum PC Components / ConfigurationsReplies: 10Last Post: 20-05-2011, 05:13 PM -
Help With MID-Range Gaming Rig !!!
By Aj12 in forum PC Components / ConfigurationsReplies: 56Last Post: 14-04-2011, 12:24 PM
LinkBack URL
About LinkBacks
