Results 1 to 9 of 9
  1. #1
    Alpha Geek vwad's Avatar
    Mar 2005
    Why ? Are you coming for dinner ? Pls. Don't.
    Default Need Expert Opinion on following configs
    How do they look ? Do you need any changes, one important point is that Strictly From Mumbai Dealers Only to be bought in Pune.
    Budget 35k to 40k for a friend. General Watching Movies, Editing Videos, Mpeg2 Encoding and Entry Level Photoshop Jobs.
    An Old Lady Died In Her Childhood.
  2. #2
    . Jaskanwar Singh's Avatar
    Feb 2010
    Amritsar
    Default Re: Need Expert Opinion on following configs
    since your friend is into movies etc i will suggest the above config.
    Steam ID - HD6950, UPlay - Jas808, Origin - Jas9009
    Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
    HP Pavilion G6 2005AX - Genuine Windows 8 Pro
  3. #3
    Mar 2005
    Quote Originally Posted by Jaskanwar Singh View Post
    Thanks a lot. Great. Hmm. HD 5670 is it a must ? And any AMD counterparts of this ?
  4. #4
    Aug 2007
    Chinchwad Pune
    Phenom X4 955 BE @ 5.5 K
    Gigabyte GA-880 GM USB 3 @ 4.8K
    Rest Config Same.
    I guess Would be better to have a Decent GFX to run BluRay Movies flawlessly
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  5. #5
    Mar 2005
    Quote Originally Posted by Tech_Wiz View Post
    Rest Config Same.
    So you also go with HD 5670 or anything else ?
  6. #6
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Replace CORSAIR Builder Series CX600 V2 600W with GS600 or FAP SAGA II 500W, already suggested by Jas.
    Inactive in TDF.
  7. #7
    Aug 2007
    Chinchwad Pune
    Within that Price its the best buy.
  8. #8
    Feb 2010
    Amritsar
    Quote Originally Posted by vwad View Post
    get a 5670 for little casual gaming too.
    and see these posts -
    http://www.thinkdigit.com/forum/pc-c...ml#post1490184
    get i3. low power consumption and enough for your needs.
  9. #9
    Mar 2005
    Hmm. Thanks a lot.
  1. Seeking expert opinion on my desktop configuration.
    By kabira in forum PC Components / Configurations
    Last Post: 30-01-2012, 12:08 AM
  2. Comparing two configs.....
    By GeekyBoy in forum PC Components / Configurations
    Last Post: 06-08-2006, 01:32 PM
  3. EXPERT OPINION URGENTLY NEEDED...!!!!!!
    By sincereheart in forum Mobiles and Tablets
    Last Post: 16-10-2005, 02:32 PM
  4. Low , Mid , High End AMD 64 PC Configs for All
    By quad master in forum CPU / Motherboards
    Last Post: 10-06-2005, 10:29 PM
  5. Replies: 4
    Last Post: 18-02-2005, 10:12 PM
