Page 1 of 4 1 2 3 4 LastLast
Results 1 to 30 of 115
  1. #1
    Human Spambot abhidev's Avatar
    Sep 2009
    Default Assembling new pc for my bro...Help!!
    I asked my bro to fill up the questionnaire...
    1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
    A: Daily work & Gaming
    2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
    A:Would prefer Intel
    3. What is your MAX budget?
    A:under 50k
    4. Planning to overclock?
    A: not really but maybe in future
    A: Windows XP/7
    A: 1 TB or more
    7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
    A: 21” screen
    A:5
    A: Will be done by me
    A: in 1 month
    A: yes
    A:BD player
    A: only from Mumbai
    A:
    Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
  2. #2
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Default Re: Assembling new pc for my bro...Help!!
    AMD Phenom II 955 @ 5.4K
    Asus M5A88-M (AM3+, USB 3.0, SATA 3, 140W CPU support) @ 5.3K
    Corsair XMS3 1600 MHz 4GB X 1 @ 1.5K
    Seagate 1 TB 7200.12 SATA @ 2.7K
    Acer S226HQ 21.5" @ 6.4K
    Corsair CX 500 V2 80+ @ 3K
    MSI HD 6770 1 GB @ 6.3K
    NZXT Gamma @ 2K
    Logitech MK100 Keyboard & Mouse @ 0.5K
    LG 22X SATA DVD R/W @ 0.85K
    Intex 800VA UPS @ 1.4K
    Total : 35.35K
    For Intel get the following Items:
    Intel Core i5 2400 @ 9K
    Corsair Value Series 1333 MHz 4GB X1 DDR3 @ 1.2K
    Acer P206HQ 20" @ 5.1K
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  3. #3
    knocking on heavens door sumonpathak's Avatar
    Jul 2011
    Skeleton city
    i think you can squeeze in a 900 series mobo in that...contact vedant kolkata for pricing
    Asus M5A97 Auto O.C. Tuning
    2500K|3570K|FX-8150|FX-8350|965BE|E7500
    MVF|P8Z77-V Deluxe|P8Z68 Deluxe|CHV|880GM-USB3|M4A785T-M|G31M-ES2L
    HD7850|GTX660Ti|HD6870|HD6670|HD5450|9400GT
    HyperX Blu|HyperX Predator|RipjawsX|Value Select|CGM2X2|
  4. #4
    Mar 2009
    Kolkata
    Suman, the Asus M5A series, although based on older 7XX/8XX chipset they have almost full compatibility with the Bulldozer module and supports all the features like the new Turbo Boost, high voltage handling etc.
    The reason is unlike other companies like MSI, Gigabyte who have updated their existing mid-range 880, 870 or 7XX series boards through BIOS to support Bulldozer, Asus designed the middle range boards based on 880/870 chipset from the ground level to support Bulldozer. They will even support 1866 MHz memory speed, the default memory controller speed of Bulldozer module.
    But as you said, if any 970 based boards are available within 6K then they will be the best buy. Any news about them in Kolkata?
  5. #5
    Jul 2011
    Skeleton city
    vedant had a few on display...have to contact them on pricing
  6. #6
    Sep 2009
    Hey is it advisable to wait for Ivybridge.....
  7. #7
    . Jaskanwar Singh's Avatar
    Feb 2010
    Amritsar
    my suggestion -
    that mobo is bulldozer ready. upgrade to a bulldozer processor later.
    UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
    Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
    HP Pavilion G6 2005AX - Genuine Windows 8 Pro, Samsung Galaxy Y Duos
  8. #8
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Quote Originally Posted by abhidev View Post
    Obviously yes, if you can.
    Inactive in TDF.
  9. #9
    Aug 2007
    Chinchwad Pune
    When it is actually coming? I thought it was due in Q1 2012 and thats too much of a wait
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  10. #10
    Sep 2009
    yea what the release date for Ivy Bridge??? heard it would be Q4 2011. Well guys please suggest only Intel config, my bro wouldn't prefer AMD.
  11. #11
    Feb 2010
    Amritsar
    ivy bridge is long wait. not recommended.
    if you need intel -
  12. #12
    Sep 2009
    Hey guys...for now you can cut out monitor,keyboard,mouse,ups out from the budget....also please suggest a better vfm config(no i3) which is future proof too...
    One more question...are there mobo's which will be compatible with Ivybridge processors?
  13. #13
    Aug 2011
    Kolkata
    Ivy bride is of long wait. Intel change their chipset almost every-time. So, its better not to predict anything about those processors.
    Inactive in TDF.
  14. #14
    Feb 2010
    Amritsar
  15. #15
    Sep 2011
    New Delhi
    If you are going to overclock then go for i5 2500K and P67 or Z68 based mobo.
  16. #16
    Sep 2009
    yea...also Z68 mobos would make sense right?
    @Jaskanwar: the mobo u hv mentioned...does it support Xfire? also the RAM...is it a good performer(4gb in just 1.k)...? Also please suggest Corsair RAMs ?
  17. #17
    Mar 2009
    Kolkata
    No that does not support Crossfire, infact none of the H61 chipset based mobo have two PCI-E X16 slots for Multi-GPU setup. Only a very few H67 based board have two X16 slots and can run Crossfire @ X16-X4 mode which is not a recommended setting.
    For proper Multi-GPU support in X8-X8 mode, you need to opt for either a P67 or Z68 based motherboard. The cheapest one with X8 Multi-GPU (SLI and Crossfire) is MSI Z68A-GD55 @ 9.6K.
  18. #18
    Wise Cold Ghoul Piyush's Avatar
    Feb 2010
    GZB.
    @abhidev
    wait for Ivy-->not a good idea
    better to go for Jassy's i5 2500 recommendation if your brother is going for Intel way
  19. #19
    Feb 2010
    Amritsar
    if you will oc a k processor or use lucid virtu or ssd caching or cfx or sli.
    and g.skill rams are excellent. dont worry.
  20. #20
    Sep 2009
    how abt Asus P8Z68-V Pro LGA 1155...is it better than MSI?
  21. #21
    Feb 2010
    Amritsar
    ^nice board with features like bluetooth etc.
    msi one is vfm.
    and there is not a significant performance difference between boards using same chipset. oc vise both msi and asus one is good. just see which features you need.
  22. #22
    Sep 2009
    guys updated the thread description...also check the max budget has increased to under 50k
    My brother was considering Alienware x51 desktops....i suggested him to assemble one because in 50k we can get better components. Following is the config for total of 51k. Is it worth?
    Intel Core i5-2500k Quad Core CPU Technical Specifications:
    - Hi-C CAP for GPU provides more precise voltage.
    - All Solid CAPs have longer lifespan.
    Processor Speed: 3.3GHz
    PhysX & 3D Vision Surround GHz
    Speed in Turbo Mode up to 3.7 technology
    - Support PhysX technology effects for realist physics effect.
    Cache: 6MB (L3)
    - Support 3D Vision Surround up to 1100MHz
    Built in High Definition Graphics technology in SLI mode to provide 3
    monitor
    Cores: 4 output simultaneously and real 3D image experience. (Need
    Number with 3D monitor and 3D glass.)
    to work of Threads: 4
    Manufacturing Process: 32nm
    CPU Socket: LGA 1155
    Video Output Function
    8gb 95 Watt x 2
    TDP:
    Dual-link DVI
    Intel Advanced Vector Extensions (AVX)
    Mini HDMI x 1
    MotherboardVideo
    Intel Quick Sync
    VGA(Optional, via DVI to D-Sub adapptor)
    Intel AES-NI
    HDMI(Optional, via Mini HDMI to HDMI dongle)
    Intel Virtualization Technology
    21" LED Monitor
    Bundle MSI developed driver and utilities
    MSI Live Update Series(Live Graphics Card BIOS & Live Graphics
    Card Driver)
    Automatically online download & update Graphics Card BIOS &
    Drivers, reduce the risk of getting the wrong files, and never have the
    trouble on web site searching.
    MSI Graphics Card Driver
    MSI Dual Core Center
    MSI Live
    including all real time life information you need, such as Live MSI
    Product News, Live Daily Information, Live Personal Schedule
    Manager, Live Search and more.
    Adobe Acrobat Reader
    Microsoft® DirectX
    Norton Internet Security™ 2008 60 days Trial
    -Blocks online identity theft by phishing Web sites
    -Detects and eliminates spyware
    -Removes viruses and Internet worms automatically
    -Protects against hackers
    Western Digital AV-GP WD20EVDS (1TBX2)-Green
    DVDR/W
    Cabinet
    Wireless CardWireless 1502 (802.11gn) WLAN Card
    Speaker(2.1)
  23. #23
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    remove the technical specs. we already know it or can easily google it. just give the components name.
    and avoid WD Green. get WD Black. Green have high failure rate and carries 2yr warranty. Black carries 5yr warranty. and the list is most likely mixed up. GPU, motherboard, ram, PSU are missing from the sheet or those are already decided?
  24. #24
    Sep 2009
    guys please revise your config suggestions. Thanx in advance.
  25. #25
    Aug 2011
    Kolkata
    ^ Do you have any preference(s)?
    Inactive in TDF.
  26. #26
    Sep 2009
    Quote Originally Posted by d6bmg View Post
    The processor should be intel and gfx card should be amd...rest you guys can suggest which are better.
  27. #27
    Aug 2011
    Kolkata
    It is 60K rig. If you want 50K overclock-able rig, you will get Phenom II 1090T.
    Inactive in TDF.
  28. #28
    Sep 2009
    hey guys...this is the config for mid range gaming pc suggested by tech2....
    please let me know if this requires any changes/additions. thanks
  29. #29
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    No Need of I5 3570K with an H77 motherboard .
    No need of an SSD . Dont go with Cooler Master PSU . Also 5K Speaker is not needed .
    BTW , What is your Budget . For 70K you can build a Kickass PC with I5 2500K and a GTX 670 !!!
    AMD Phenom X4 970 @ 7.6K
    ASUS M5A97 @ 5.9K
    GSKILL RipJAWSx 2x4 GB DDR3 @ 3K
    WD 500 GB HDD @ 4K
    ASUS DVD ROM @ 1K
    Seasonic S12 520W @ 3.7K
    Cooler Master RC430 @ 3K
    Logitech Combo + BXR1221 Speaker + Numeric 600
    VA UPS = 3K
    BENQ 22'' HD @ 7.5K
    HIS HD 7850 @ 15.3K
    TOTAL @ 54K .
    You can also go for I5 2400 + DH67CL B3 . But you cant OC.
  30. #30
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    Components are highly imbalanced. 7770 with i5-3570k, seriously ?
    Instead opt for i3 + 7850. Bang for buck. And if you're thinking that i3 will bottleneck, then it won't.
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  1. Assembling New PC
    By sxyadii in forum PC Components / Configurations
    Last Post: 04-08-2012, 06:58 PM
  2. help in assembling a pc
    By Jaskanwar Singh in forum PC Components / Configurations
    Last Post: 04-08-2010, 01:52 PM
  3. Help Assembling PC
    By rohit32407 in forum Hardware Q&A
    Last Post: 30-05-2010, 10:43 PM
  4. Few Q's on assembling a PC
    By RMN in forum Hardware Q&A
    Last Post: 15-10-2008, 10:15 PM
