Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 60 of 115
  1. #31
    Pro/An---tagonist xD
    Dec 2009
    Kolkata
    Default Re: Assembling new pc for my bro...Help!!
    @Jas How come all of the 1TB hard disks in your table are listed at 2.7k?
    Desktop :- Amd athlon II X3 435 unlocked to Phenom II X4 B35 | MSI 785 G-E53 | MSI R6850 Cyclone power edition [OC edition] | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz | Corsair GS600 | Seagate 500 gb 7200.12 | Cooler Master CM 690II Advanced | Dell ST2220L |
    Laptop:- Dell Inspiron 15R Turbo => i5-3210m,4gb RAM, 1 tb HDD, AMD HD 7730M 2gb.
  2. #32
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    Those Posts Were posted in Q3 2011 I think so.
  3. #33
    Human Spambot abhidev's Avatar
    Sep 2009
    Quote Originally Posted by dashing.sujay View Post
    Components are highly imbalanced. 7770 with i5-3570k, seriously ?
    whats the issue in this?
    Also guys pls do not ignore speakers and ssd....also aren't the 3rd gen intel processors more efficient and better than sandybridge?
    Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
  4. #34
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    Quote Originally Posted by abhidev View Post
    Well, getting a high end processor when you have no use of it, and adding a mediocre GPU, which will hamper your primary usage is like unbalancing a system. You won't even use 50% of juice of CPU.
    Doesn't matters for you.
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  5. #35
    Sep 2009
    then whats the suitable gpu for this proccy?
    why not...why wouldn't one by somehting that is power efficient and futureproof and also which as at an approx cost as that of sandybridge?
  6. #36
    Nov 2009
    Bhopal
    Its nothing like every CPU has got a suitable GPU, rather it depends upon your requriement/need.
    Its not really power efficient and has got some heating issues due to bad TIM. Futureproof? Even SBs are.
  7. #37
    Sep 2009
    yea read in other thread abt the heating issue...but some reviews don't say that.....well i guess its safer to go with SB than IB....
    can you suggest a config with SB..with a good mobo...have lost track of the new gpus...can you suggest one(budget 10-11k)?
  8. #38
    Nov 2009
    Bhopal
    This>
    Quote Originally Posted by Jaskanwar Singh View Post
    ivy bridge is long wait. not recommended.
    if you need intel -
    Just replace GPU with 6870 (in your budget). Though target for 560ti/6950 @ 13-14k. But 6870 will also be fine. Don't go below that.
    And you want mobo for OC ?
  9. #39
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    Ivybridge temp problems are seriously overhyped in tdf. An existing sandybridge owner has absolutely no need to upgrade to ivybridge whereas a new owner surely can.
    Ivybridge is almost as good as sandybridge as far as temps are concerned and it runs a tad hotter owing to the newer 22nm trigate transistors. Saying ivybridge has heating issues will be absolutely bull$h!t.
    Besides its found out that real temp and core temp do not give accurate temp data for ivybridge processors as they do not have E1 stepping compatibility. See here.
    Check this link to see hardocp's overclocking efforts - Link
    So all new users can surely go for ivybridge without worrying about temps too much. Just go for a cooler as intel's stock coolers are pathetic.
    Check out the following reviewer's comments and make your decision:
    Comment 1
    Comment 2
    Ivy Bridge is a nice jump forward for Intel and its mainstream user group. Ivy Bridge will afford mainstream users the ability to get through heavy workloads faster using less power, allowing for cooler running systems and any IT guy will tell you that is a great thing.
    For enthusiasts, Ivy Bridge looks to be a "push" when sitting next to Sandy Bridge on our test bench. If you are that guy looking for edge-of-the-envelope overclocks, Ivy Bridge is looking to bring you back a couple of CPU multiplier notches compared to Sandy Bridge. If you are running at more realistic every day overclocks in the mid-4GHz range, Ivy Bride will afford you 4% to 7% better IPC than Sandy Bridge.
    The new Z77 chipset features have widened a bit, but for the power user, you likely already have those needed features on your current motherboard.
    Ivy Bridge is going to be a hard up-sell to Sandy Bridge users. Unless you are running at stock clocks, it is hard to look at Ivy Bride as an upgrade for the user. If you are using an Intel system prior to Sandy Bridge, excluding X58 users, then there seems to be little reason to purchase a Sandy Bridge system if Ivy Bridge is open to you as a choice.
    I recently built a new system for my personal usage. I was aware of what was coming down the pike from Intel, and instead of wait for Ivy Bridge, I made the choice to build a Sandy Bridge system. If I was building today, I would go with an Ivy Bridge processor. I guess that really says it all for most [H] users.
    Update- All heating issues was due to this. Going for a good TIM will solve everything.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  10. #40
    Sep 2009
    ^ thanx for sharing the info buddy...so it is indeed safe to opt for Ivy bridge
  11. #41
    Sep 2009
    guys....please....sorry for asking it again....but pls let me know a new config (SB or IB) except keyboard and mouse....
    The budget has increased to 60-65k
    Also if the config gets finalized by tomorrow then I'll get it this Saturday(21 Jul) itself....thanx in advance
  12. #42
    Broken In N@m@n's Avatar
    Jul 2012
    New Delhi
    Cooler Master Hyper 212 EVO Cooler 2101
    Corsair CMPSU-650TXV2UK PSU 5857
    Cooler Master Elite 430/ NZXT VULCAN 3465
    HIS AMD H7850/ SAPHIRE HD7850 2 GB GDDR5 GC 16907
    Seagate Barracuda 1 TB HDD Internal Hard Drive 5422
    GSkill Ripjaws (4 GB X 2) RAM 3520
    Gigabyte z77m d3h 7950
    Intel Core i5-2500K Processor 13250
    Total 58472
    Enjoying Life
    I never think of the future - it comes soon enough. :P
  13. #43
    Sep 2009
    hey thanx for the reply...but i wanna have an i7 config....pls suggest accordingly...
    Anyone here got an IB config???
  14. #44
    Apr 2012
    Why do you need an I7 config.
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  15. #45
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    Just replace i5-2500 with i7-2600k for 4.5k more or i7-3770k for 7k more.
    Check here
    My Blog :D
  16. #46
    Oct 2011
    Bangalore
    For gaming i7 doesn't do any miracles it performs similar to i5 so get i5 with good GPU and motherboard.
  17. #47
    Sep 2009
    Quote Originally Posted by Sainatarajan View Post
    won't an i7 be more future proof than i5 ?
    Also instead of Gigabyte mobo suggested by @Naman ...will the Asus p8Z77-V-M be a better choice??
  18. #48
    Apr 2012
    As minion said , It wont do any miracles . I5 2500K will be my Choice . It can OC and Performs equal I7 in some games. Get a High End Graphic Card and Pair it with I5 2500K . You need a good CPU that will not Bottleneck a Graphic Card .
  19. #49
    Sep 2009
    anyone???
  20. #50
    Jul 2012
    i too wanna buy my system tomorrow
    pls help
    intel i5 2500k @13,150
    intel dz68db @7,550
    2 X 4gb corsair vengeance @3,300
    seagate 2tb barracuda 7200rpm @6,400
    cooler master 550w psu @3,750
    msi 7850 twin frozr @17,150
    cooler master 311 @2,450
    total 53,750 INR
    is this config any good ??
  21. #51
    Apr 2012
    Intel DZ68DB is not a good Choice with I5 2500K. Ask your Questions in your Thread.
  22. #52
    Oct 2011
    Bangalore
    Quote Originally Posted by sarveshrokz View Post
    pls help
    intel dz68db @7,550
    total 53,750 INR
    Get asrock extreme series motherboard and change PSU to Corsair GS series.
  23. #53
    Sep 2009
    no one.....gr8
    can anyone pls pls help me out here...
    hwo abt this config
  24. #54
    Wise Old Owl Myth's Avatar
    Jun 2012
    Bhubaneswar / Kolkata
    Stick to the 2500k. Great cpu power and value for money. It wont be a bottleneck for most graphic cards for sometime to come. Most of the games are gpu dependent. The 2500k can handle the cpu part easily.
    Good choice on the mobo. I have order the same one.
    Take the low latency rams. Lower the better.
    Benq display is cheaper and has lower contrast ratio than dell.
    I am not sure about iball speakers. Choose a better audio system like altec or creative. The sound quality should be able to match the display and the performance.
    For psu, take a good brand and above 550w.
    Read the Power supply blacklist thread for newbies. No CMs.
    Intel i7 2600k, Asus P8Z77-M Pro, Sapphire HD 7950 VaporX with Boost | Palit 9600GT, Corsair TX650v2, CM Hyper 212 Evo(push-pull), CM Elite 430, Altec Lansing ATP3 2.1, Samsung Syncmaster 2033, Corsair 2x2GB, Seagate 1TB + WD 1TB Black + Maxtor 300GB, Win7 Ultimatex64, CPU-Z , GPU-Z
    Need Help :
    * Looking to purchase Noctua NH-U12P SE2 :(
  25. #55
    Sep 2009
    so the updated config goes like this
    guys suggest...
    have added the gfx card...pls suggest....
    just added monitors in the list
  26. #56
    Jan 2011
    Bhubaneswar
    1. CPU is fine
    2. Mobo is fine too
    3. For RAM you can take Corsair Vengance 8GB for Rs.3500
    4. Get WDC Blue 1TB for 5.2k, seagate is not a good choice now
    5. Shell some more and grab the MSI GTX-560 for 10.3k
    6. Take Asus DRW-24B5ST instead of LG.
    7. Monitor is fine
    8. Not sure about speakers, but iBall has decent sound as they are wooden speakers
    9. You can take CM Elite 430 or 431 for the same price too.
    10. For the same price, Seasonic S12II-520 is a better choice.
    So, you changed the card from HD 7770 to HD 6870, but still it doesnt make sense as for 2.5k less GTX-560 is a better choice.
    Check here
    My Blog :D
  27. #57
    Apr 2012
    Why you are going for a I5 3570K . Get a I5 2500K and get a High Graphics Card .
  28. #58
    Jun 2012
    I suggested the same thing, but abhidev wants an IB.
    Need Help :
  29. #59
    Sep 2009
    Isn't IB better...m confused...can tell me why i shouldn't go for IB?
    @saswat: nvidia cards hv heating problem right? Also I would prefer corsair for psu...can u suggest one considering 2yrs down the line I would overclock the proccy...
  30. #60
    Oct 2011
    Bangalore
    Abhidev,Get these don't go for ivy bridge they provide similar performance to sandy bridge but are costly.It is not worth the extra cash you are putting on instead buy a good motherboard like Asrock extreme series.
  1. Assembling New PC
    By sxyadii in forum PC Components / Configurations
    Last Post: 04-08-2012, 06:58 PM
  2. help in assembling a pc
    By Jaskanwar Singh in forum PC Components / Configurations
    Last Post: 04-08-2010, 01:52 PM
  3. Help Assembling PC
    By rohit32407 in forum Hardware Q&A
    Last Post: 30-05-2010, 10:43 PM
  4. Few Q's on assembling a PC
    By RMN in forum Hardware Q&A
    Last Post: 15-10-2008, 10:15 PM
