Results 1 to 4 of 4
  1. #1
    The Last Puff Artemis's Avatar
    Apr 2007
    Democracy of Hypocrisy
    Default Final Config. Please advice!
    AMD Phenom II x4 955BE--5500
    Gigabyte GA-880GM-UD2H--3600
    2 x Corsair 4GB 1333 MHz CL9 Value DDR3--2600
    MSI HD 6950 2 GB Twin Frozr III Power Edition--15300
    Seagate 1TB 7200.12--Cost????
    LG 22X SATA DVD--850
    Corsair GS600--4000
    CM Elite 310--1500
    Benq G2220HD--6800
    Logitech MK100 500----->Price for Mk260??
    Intex 1KVA--1800
    I'm going to buy it tomorrow and the budget is 45k.
    Please suggest any changes to the above mentioned config, keeping in mind the 45k limit.
    MacBook Pro 13”
    LG Google Nexus 4 : Paranoid Android 3.1 and Contrasty Kernel
    Aural Nirvana : Panasonic RP-HJE900 | Grado RS2i
    Source : NuForce uDAC-2 | HifiMan HM-101
    Last.fm
  2. #2
    Wise Cold Ghoul Piyush's Avatar
    Feb 2010
    GZB.
    Default Re: Final Config. Please advice!
    Quote Originally Posted by Artemis View Post
    Corsair GS600--4000
    CM Elite 310--1500
    Benq G2220HD--6800
    Intex 1KVA--1800
    some changes in price and better models recommendations
    2 x Corsair 4GB 1333 MHz CL9 Value DDR3--1.8k-2k
    CM Elite 310--1500 -->CM elite 430 @ 2.5k
    Seagate 1TB 7200.12 @2.7k
    AMD Phenom II x4 955BE-->965 BE @ 6k(many of the guys reported issues with 955BE's HSF)
  3. #3
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    As suggested by in the previous post go with CM elite 430 rather than elite 310.
    Otherwise its looks ok to me.
    Inactive in TDF.
  4. #4
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    @Artemis:
    If you find Intex 1KVA UPS anywhere for 1.8k plz inform me the model no. and a link to it.
    Check here
    My Blog :D
  1. Final Check!!! Please Advice
    By Aj12 in forum PC Components / Configurations
    Last Post: 01-06-2011, 11:40 PM
  2. Final Check - High End Gaming Rig!! Please Advice
    By Storm_Alias in forum PC Components / Configurations
    Last Post: 25-04-2011, 03:31 PM
  3. My Final Config - Need final thoughts
    By noob in forum PC Components / Configurations
    Last Post: 11-04-2011, 01:35 PM
  4. Please Help me to Final my Config
    By Monster_AMD in forum QnA (read only)
    Last Post: 24-05-2005, 09:08 AM
  5. AMD - Final Config
    By impetus in forum CPU / Motherboards
    Last Post: 12-02-2005, 10:51 AM
