Results 1 to 9 of 9
  1. #1
    Jul 2009
    Default cpu compatable with asus p5ql-cm motherboard
    Hi
    Which is the best cpu i can opt for this motherboard. Currently am running intel c2d 2.66 on it.
  2. #2
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    Default Re: cpu compatable with asus p5ql-cm motherboard
    For best cpu for this mobo look for Intel 8 series quad core cpus
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  3. #3
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    ^^ +1 for 8 series cpus with your mobo.
    Inactive in TDF.
  4. #4
    Jul 2009
    how much would they cost any best buyout links
  5. #5
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Actually Core2Quad processors have reached EOL and it is very hard to find them. Also if available, their prices are rediculously high. For example last known price of C2Q 8200 is 7K which is equivalent to a Athlon II X4 620. Now Athlon II X4 635 is available @ 4K only.
    On that price, you can even have an Athlon II X4 + AM3 motherboard combo. So I don't think it is a good idea to buy a new C2Q processor now. Check in different forums if somebody is selling an old one.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  6. #6
    Jul 2009
    so how much would it cost me for the upgrade i guess i might have to upgrade my 4gb ddr2 ram also?. Also by comparison how much boost in my computer i am looking for percentage wise
  7. #7
    Mar 2009
    Kolkata
    Sell of the old CPU+Motherboard+Ram. I think it will fetch at least 4 to 4.5K and let us know the extra amount you can spend. We will suggest according to the total budget.
  8. #8
    Aug 2011
    Kolkata
    AMD Athlon II x4 @4K
    Gigabyte GA-MA78LMT-S2 @2.5K
    G-skill F3-10600CL9S-2GBNT @0.7K (you will need ddr3 ram)
    Total: 7.2K
    Inactive in TDF.
  9. #9
    Jul 2006
    Geek's Heaven
    nice suggestion cilus and good config d6bmg
    Who Dares Wins
    Avenging Angel !
  1. compatable core2duo motherboard with dd3 support
    By abhijeet2021 in forum PC Components / Configurations
    Last Post: 04-10-2011, 03:09 AM
  2. Which Motherboard is Better : ASUS M2N-E vs. ASUS M2N-E SLI
    By kiranbhat in forum CPU / Motherboards
    Last Post: 19-04-2011, 08:23 AM
  3. New ASUS P5QL-CM chassis intrusion detection problem
    By Manickaraj in forum Hardware Q&A
    Last Post: 22-08-2009, 10:58 PM
  4. is Asus P5QL-EM a good mobo
    By sujeet2555 in forum Hardware Q&A
    Last Post: 15-05-2009, 06:56 PM
  5. Need ASUS Motherboard
    By anilthomas26 in forum CPU / Motherboards
    Last Post: 01-07-2005, 11:31 AM
