Results 1 to 11 of 11
  1. #1
    Dec 2004
    Default suggest me a configuration for a BUDGET OF Rs 18k.
    suggest me a configuration for a BUDGET OF Rs 18k. (NOT MORE THAN THIS)
    REQUIREMENT : only to browse INTERNET and Play Movies and downloads.
    should i go for AMD or INTEL? which one is more reliable.
    i already have a set of speakers.
    and require the following :
    CPU, MOBO, HDD, DVD ROM, RAM, Keyboard, Mouse, MONITOR. CAbinet with PSU.
    1. What is the purpose of the computer?
    A: Watching movie and internet browsing internet.
    2. Are you open to alternate ideas/products giving similar better performance but offering more VFM / sellers? If not- why?
    A: YES
    3. What is your MAX budget?
    A: Rs 18000/-
    4. Planning to overclock?
    A: NO
    A: anything
    A: 250Gb min
    7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
    A: LCD 17" min
    A:9
    A: Done before many times.
    A: in 15 days
    A: nothing as such ... since mine is a very basic configuration
    A: -
    A: chennai
    A: -
    Regards,
    AH
  2. #2
    . Jaskanwar Singh's Avatar
    Feb 2010
    Amritsar
    Default Re: suggest me a configuration for a BUDGET OF Rs 18k.
    http://www.thinkdigit.com/forum/pc-c...ml#post1453610
    remove ups and speakers from 20k rig. you will have a 18k rig.
    UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
    Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
    HP Pavilion G6 2005AX - Genuine Windows 8 Pro, Samsung Galaxy Y Duos
  3. #3
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    OR you can just buy a net-book, which is in the range of 18-20K.
    Inactive in TDF.
  4. #4
    Adam young sukesh1090's Avatar
    Aug 2010
    udupi, karnataka
    ^^ better to go with desktop than netbook,as it facilitates future upgrades.
    :razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
    " Behind this mask there's more than flesh Mr.creedy, behind this mask there's an Idea and ideas are bulletproof. " - V for Vendetta.
  5. #5
    Aug 2011
    buddy, i suggest you to wait for a month until Amd launches its bulldozer.
    Coz right now Intel has high hand both in terms of performance, speed.
    There are speculations that prices may come down after launching The Bulldozer. So you'll be able to build a decent build.
    If bulldozer is a hit then you can have latest one at good price or if its fail then Intel is always there!
    If you really want to build right now then you can choose dead end phenom cores from amd, though they are very good in your price range.
    Or Intel i3 cpu, they are very good for gaming. They are even faster then amd phenom quads because they are old techology.
    Go for latest intel and then upgrade to Ivy Bridge in future
  6. #6
    Aug 2007
    Chinchwad Pune
    Considering OP's Requirement nly to browse INTERNET and Play Movies and downloads.
    It really doesnt make any sense to wait for BD. Even a Phenom is a overkill for this.
    Go with Jas's Suggestion. And get any Athlon X2 or X3 and you will be fine.
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  7. #7
    Dec 2004
    whtt are the options for INTEL CPU FOR 18K BUDGET??
    any options to go for intel CPU within 18K budget???
  8. #8
    iGoogle guru_urug's Avatar
    Sep 2010
    Mumbai
    I suggest u go with 880g based chipset to allow flexibilty wrt future upgrades to bulldozer. For your needs this config will last u years, if u just do small periodic upgrades.
    AMD Athlon II x3 440 3200/-
    Gigabyte GA-880GM-UD2H 4000/-
    4GB DDR3 1333Mhz Transcend 1200/-
    Seagate 500GB 7200.12 1900/-
    LG 22X SATA DVD 900/-
    FSP Saga II 500W 2000/-
    Zebronics Bijli 1000/-
    Dell 17"WideScreen LCD Monitor (E1709W) 4500/-
    Logitech MK100 500/-
    total=19.2k
    If u must reduce ur cost then skimp on the processor and get a Athlon II x2 250 for 2.7k
    Then total becomes 18.7k
    Further u can reduce the ram to 2GB DDR3 1333 @ 0.6k
    Then total is further reduced to 18.1k
    This wont affect ur config since ur needs are basic computing. But still this rig has potential to become a powerhouse by just upgrading the ram,procy and adding a gpu(if needed later)
    AMD Athlon II X4 630 | MSI 785GM E51 | 4 GB DDR3 1333 Corsair | 500+160 GB Seagate | SAPPHIRE HD 6850 | NZXT Gamma | Seasonic 500 Watt :D | Samsung 19" LCD | Google Nexus 4 16GB | Google Nexus 7 16GB
  9. #9
    Aug 2011
    if you wanna go intel then
    i3 2100 + H61 Motherboard around Rs.9000
    4gb Kingston DDR3 @ Rs1300
    500gb Seagate Harddrive @Rs.1800
    Corsair CX430 PSU @ Rs.2200
    Ati Radeon 5670 @ Rs. 4000
    total : 18300
    buy cabinet if you can spare 1000 extra
  10. #10
    Aug 2007
    Chinchwad Pune
    Within 18k forget about intel.
  11. #11
    Aug 2011
    Kolkata
    Quote Originally Posted by Alive_Hunter View Post
    Forget Intel at that price what you have quoted.
    Inactive in TDF.
  1. Replies: 3
    Last Post: 06-07-2012, 03:59 PM
  2. pls suggest best system configuration in my budget
    By always in forum PC Components / Configurations
    Last Post: 14-11-2011, 12:39 AM
  3. please Suggest budget configuration for pc
    By harshitbansal in forum PC Components / Configurations
    Last Post: 19-07-2011, 02:58 AM
  4. Replies: 4
    Last Post: 31-10-2008, 09:09 AM
  5. Suggest Gaming PC configuration budget 75k
    By MaxBombay in forum PC Components / Configurations
    Last Post: 31-01-2007, 03:15 AM
