Results 1 to 7 of 7
  1. #1
    Aug 2011
    Default Extreme Budget Gaming Build?
    I'm from the US, but I heard that this forum is one of the best places to get advice on builds, especially budget builds. If possible, talking of prices in terms of US dollars would be helpful to me. Thanks in advance
    1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
    A: Gaming- HoN, Dota2, some SC2, maybe some RPGs if any good ones come out. Not a big FPS guy anymore
    -school (word processing stuff, GIS mapping software, SPSS statistical software--nothing TOO intensive)
    -internet browsing, watching movies, music (I have a 500 GB 7200 external hard drive NTFS formatted with a few hundred gig of music)
    2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
    A:
    Yes
    3. What is your MAX budget?
    A:
    $500 USD. But the less the better
    4. Planning to overclock?
    A:
    I don't THINK so, but I'm really open to options. I live in a house in the southern US with no AC, so I'm worried about heat problems.
    A:
    Probably windows 7 64 bit. But honestly, I'd rather run Linux if possible
    A:
    As little as possible. My external is enough space for me--I don't download movies.
    7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
    A:
    Not sure yet
    A:
    2. I just started researching buying a new computer yesterday. I've shopped for and built my own computers in the past, but it's been almost a decade.
    A:
    I'll do it. I had a computer that I tinkered with a lot--started from the parts I had laying around and upgraded it every 6-12 months for 5+ years.
    A:
    Within the next 2-3 months
    A:
    I don't think it's reasonable to expect a computer in my budget range to be very upgradable. It'd be nice if at least the case was expandable.
    A:
    I'll need everything
    A:
    I'm in Virginia, in the US
    A:
  2. #2
    MV VIP to the MAX SlashDK's Avatar
    May 2010
    Delhi
    Default Re: Extreme Budget Gaming Build?
    Here's my suggestion. I'm unsure about a few things in the us so they're upto you to decide.
    Found this:
    Newegg.com - Computer Parts, PC Components, Laptop Computers, LED LCD TV, Digital Cameras and more!
    Battlelog : DK-xxx-
    Steam : $/@$]-[ DK
  3. #3
    Scene Addict mitraark's Avatar
    Nov 2010
    Kolkata / Durgapur
    Am i the only one who feels the Thread title is a bit misleading ?
    The street prices and NewEgg prices are same ?? Anyways 500$ should be enough for a decent Entry level PC.
    i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz || XFX ATI HD5670 1GB
    WD 2TB + Seagate 2 TB x2 + Seagate 1 TB + Seagate Freeagent 1 TB + Buffalo USB3.0 1 TB
    Corsair CX400 || Zebronics Bijli || Samsung P2350 || Altec Lansing VS2621
    My Speedtest :D || LG Optimus L9 P765
  4. #4
    Aug 2011
    I was under the impression that $500 was about as cheap as I could go. Can I go cheaper?
  5. #5
    Human Spambot MegaMind's Avatar
    Nov 2010
    Perambalur, TN
    Quote Originally Posted by 6Eleven View Post
    A:
    AMD's Bulldozer series CPU will be out by then..
    i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
  6. #6
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Quote Originally Posted by MegaMind View Post
    But that doesn't have any effect on his rig, as his budget is $500 only.
    Inactive in TDF.
  7. #7
    Aug 2011
    I revised my budget down to $300. Thanks for the idea!
    I'm going to buy all these components from newegg/superbizz before I go to bed tonight. Decided for a 'ultracheap good enough to run HoN/DOta1, will buy a new pc in 1-2 years' build
    I'm a bit worried about the OS and the PSU in the budget case/PSU combo. THe GPU is really cheap too
    Case/PSU: iMicro CA-IM1202P 400W 20+4pin Mini ATX Mini Tower Case (Black), S25
    MOBO:ASRock A770DE+ Socket AM3/AM2+/AM2/ AMD 770/ DDR2/ CrossFireX/ A&GbE/ ATX Motherboard $52
    CPU: AMD Athlon II X2 260 Regor 3.2GHz Socket AM3 65W Dual-Core Desktop Processor ADX260OCGMBOX $65
    RAM: CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model TW3X4G1333C9A G $31
    HDD: Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive $42
    GPU: MSI R5450-MD1GD3H/LP Radeon HD 5450 1GB 64-bit DDR3 PCI Express 2.0 x16 HDCP Ready Low Profile Video Card $40
    total with shipping+50 foot ethernet cable+4 GB USB flash is around S280
    I'm planning on using Kubunto for my OS
  1. Build a good budget gaming pc
    By geek@aragorn in forum PC Components / Configurations
    Last Post: 19-08-2012, 07:41 PM
  2. budget gaming pc build urgent!!!! buying in two days!!! Need Advise pls!!
    By akshayp in forum PC Components / Configurations
    Last Post: 28-12-2011, 10:02 AM
  3. (Budget) SSD and Non-SLI gaming build
    By LemonNCheese in forum PC Components / Configurations
    Last Post: 17-10-2011, 02:23 AM
  4. suggestions for budget gaming build
    By darksider in forum PC Components / Configurations
    Last Post: 05-09-2011, 11:38 PM
  5. Budget 35000 Gaming Build
    By Devil Hunter 47 in forum PC Components / Configurations
    Last Post: 02-04-2011, 08:21 PM
