Results 1 to 23 of 23
  1. #1
    Aug 2011
    Durgapur
    Default Gaming pc for 45k....
    Guys i am building a PC with a budget of 45k.
    The components that i have selected are....
    AMD Phenom II X4 955 BE 3.20 Ghz
    2X2 GB Gskill Ripjaws
    500 GB WD cavair Blue
    GTX 560/GTX 460/HD 6850???
    Benq V2210 21.5 inc full hd
    Cooler Master Elite 430
    *Guys, please suggest me a good Mother board and a PSU.
    *What graphics card should i take out of the three(which gets me the best bang for the buck)/or should i wait for HD 6950 price to drop???
    *Do i need a cooling kit for this configuration???
    *Also if you have any other recommendations you are welcome(but i have a very tight budget,may be i can stretch it by 1-2k).
  2. #2
    Aug 2007
    Chinchwad Pune
    Default Re: Gaming pc for 45k....
    If You could have filled the Template it would be better but anyways..
    1. 955 BE is No probs but if you can wait a month then BD will be out.
    2. Ram is Fine
    3. Get 1 TB Price difference is too less to ignore
    4. Out of those I say HD6850
    5. Monitor is OK afaik
    6. Case is OK
    Motherboard: Gigabyte GA 880G - USB 3 - 4.8K
    HD6850 is sufficient for HD gaming.
    If you plan to Overclock then yes else NOT.
    Now My Recommended Config:
    Intel Core i5 2400- 9300
    Intel DH67VR - 4500
    Gskill Ripjaws X F3-12800CL9S-4GBXL-1600
    MSI R6850 Twin Frozr - 9800
    HDD Seagate 500GB -1900
    LG 22X SATA DVD- 900
    Corsair GS600 - 4000
    CM Elite 430 - 2500
    Benq G2220HD - 7000
    Total 41500
    800 VA Ups to get it to 45K and ready to rumble
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  3. #3
    Gadget Freak Tenida's Avatar
    Aug 2008
    Calcutta
    Here's my suggestion-
    Intel Core i5 2500-9.8K
    Intel DH67BL-5.3K
    Gskill Ripjaws X F3-12800CL9S-4GBXL-1.6K
    MSI R6850 Cyclone 1GD5 Power Edition-9.35K
    Corsair GS600-3.8K
    Seagate 500GB 7200 RPM-1.7K
    CM elite 430-2.4K
    BenQ G2220HD-7K
    Total-40.95K
    My Gizmos O_O
    ||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
    ||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
  4. #4
    Human Spambot MegaMind's Avatar
    Nov 2010
    Perambalur, TN
    Better to go for GTX 560ti HAWK - 14K..
    i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
  5. #5
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Quote Originally Posted by MegaMind View Post
    +1 for it regarding quality.
    Inactive in TDF.
  6. #6
    Nov 2010
    Perambalur, TN
    Here's my suggestion,
    @OP, If the price is high get HD6870 - 11.5K, to reduce the total to 44.1K
  7. #7
    Aug 2008
    Calcutta
    Quote Originally Posted by d6bmg View Post
    Higher price doesn't always means good quality.MSI R6850 Cyclone Power Edition has great build quality you can say best HD6850 card out there.
    Intel Core i5 2500 will be better with Gtx 560Ti.
    My Gizmos O_O
  8. #8
    Nov 2010
    Perambalur, TN
    Quote Originally Posted by Tenida View Post
    i5 2500 is jus 100MHz faster than 2400.. I dont think its worth 600 or 800 bucks over the i5 2400..
  9. #9
    Aug 2008
    Calcutta
    Yes 2400 is good enough.@OP Look at this for further info.
    My Gizmos O_O
  10. #10
    make.believe Ayuclack's Avatar
    Jul 2011
    Ahmedabad
    If You are not over clocking then go for 2400 else 2500k is best....Go for Tenida Config..
  11. #11
    Aug 2008
    Calcutta
    @Megamind look a this config
    I think as Smcinternational is giving big discount on HD6950TFIII so its best bet go with that GFX.
    Intel Core i5 2400-9.3K
    MSI H67MA-E35-4.6K
    2XCorsair value 2GB DDR3 1333MHz-1.5K
    MSI R6950 Twin Frozr III Power Edition/OC-15.3K
    Corsair Gs 600-3.7K
    Seagate 500GB 7200Rpm-1.7K
    Cm elite 430-2.4K
    BenQ G2220HD-7K
    Total-45.5K
    My Gizmos O_O
  12. #12
    keen to learn..
    Mar 2010
    Amritsar
    What is the performance diff between MSI 6850 cyclone PE vs Ati 6870 ?
  13. #13
    Nov 2010
    Perambalur, TN
    Quote Originally Posted by a2mn2002 View Post
    6850 vs 6870
  14. #14
    Aug 2011
    Durgapur
    I saw in a graphics card round up that GTX 560(not Ti) is great value for money card and that it performs almost at par with 6950,and with extreme physx and tessellation(which are important for up coming games) thrown in it managed to outperform HD 6950.
  15. #15
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    You are wrong buddy, the 560 Non Ti performs just slightly higher than HD 6870. Even its bigger brother 560 Ti is little short from HD 6950. Also GTX 560 has hughe power consumption compared to the performance it offers.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  16. #16
    . Jaskanwar Singh's Avatar
    Feb 2010
    Amritsar
    Quote Originally Posted by monsursound View Post
    you read this in chip mag?
    UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
    Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
    HP Pavilion G6 2005AX - Genuine Windows 8 Pro, Samsung Galaxy Y Duos
  17. #17
    keen to learn..
    Mar 2010
    Amritsar
    when 560 ti / 6950 1GB get price drop ?
  18. #18
    Aug 2008
    Calcutta
    When hd7000 or nvidia gtx 600 series will be launched
    My Gizmos O_O
  19. #19
    Super Moderator Skud's Avatar
    Jun 2004
    10 light years away
    They are already at 12-13k level. Next drop will be only after the launch of next gen cards. As Kepler would be delayed compared to HD7000, expect to see the drop in nVIDIA cards first.
    Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
    HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
    Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
    Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
    Android: Galaxy R | Galaxy Y
  20. #20
    Aug 2011
    Durgapur
    @jaskanwar
    yes i read that in chip mag july 2011.
    Ok,thanks guys for your replies,But you will have to help me once more.For a gaming machine it is advisable not to spend too much money on processor(those on a budget) ,instead invest the saved money on a graphics and a monitor for a better eye candy.So ,as my budget was not big i had to look for processor in the range of 5-6k.So intel i3 and phenom II X4s were my only options.I previously chose phenom II X4 955 BE blindly because of 4 cores.But i searched and found out that the i3 beats the phenom most of the times.Also very few titles like crysis,BFBC ..etc uses 4 cores.So now i am really in a fix whether i should pick i3 or phenom II X4.because i cant ignore the fact that future games may be optimized to use all the 4 cores and Intel i5 is really out of my budget.
  21. #21
    Mar 2009
    Kolkata
    Ya, you are sure about the gaming performance...i3 2100 performs better than 955 in most of the cases. But still Phenom II X4 955 is a vaiable option because:-
    1. In multi-threaded applications, Phenom II X4 955 performs better than i3 2100 because of its 4 Physical cores compared to the 4 logical cores of i3 2100.
    2. Since Phenom II X4 955 is a Black Edition processor, it can be overclocked very easily to gain some more performance, both in gaming and applications, a feature missing in i3 2100. Even with the stock cooler, 955 can reach upto 3.6 GHz and euqal the gaming performance
    3. Now you have mentioned that in games like crysis2, Battle Field Bad Company etc. 955 performs better. The reason being is all the current latest games are getting highly multi-core optimized and 955 gets an advantage because of its 4 cores. Expect all the upcoming games to be highly optimized for multi-core processors and Phenom II X4 has a slight benefit over i3 2100 over there.
  22. #22
    Aug 2011
    Kolkata
    Quote Originally Posted by Skud View Post
    I think that delay is a bit intentional.
    Inactive in TDF.
  23. #23
    Feb 2010
    Amritsar
    @jaskanwar
    arrey those idiots dont know even the simple fact that amd cards are not made to render physx code. they use physx as a test. dont know why. maybe they are biased
    now you saw conclusion. but if you go through fps part there is a different story. lets make this transparent
    now you need to understand the fact that amd has designed the tessalator in their HD69** series keeping in mind normal tessellation.
    you can read about this at anandtech article when 69** were launched.
    but yeah nvidia needs to be given credit for their work on tessellation part (polymorph engines in fermi)
    now 560 is more or less a 6870.
    Now see this -
    <30 FPS
    very limited gameplay
    30-40 FPS
    average yet very playable
    40-60 FPS
    good gameplay
    >60 FPS
    best possible gameplay
    So if a graphics card barely manages less than 30 FPS, then the game is not very playable, we want to avoid that at all cost.
    With 30 FPS up-to roughly 40 FPS you'll be very able to play the game with perhaps a tiny stutter at certain graphically intensive parts. Overall a very enjoyable experience. Match the best possible resolution to this result and you'll have the best possible rendering quality versus resolution, hey you want both of them to be as high as possible.
    When a graphics card is doing 60 FPS on average or higher then you can rest assured that the game will likely play extremely smoothly at every point in the game, turn on every possible in-game IQ setting.
    Over 100 FPS? You either have a MONSTER graphics card or a very old game.
    MSI R6950 Twin Frozr III Power Edition OC review
    you will see that extreme tessellation renders fps that are just average. normal tessellation does the job.
  1. To get Logitech G15 Gaming Keyboard and MX518 Gaming Mouse
    By debasis_7012005 in forum Hardware Q&A
    Last Post: 10-09-2007, 02:37 PM
  2. Replies: 2
    Last Post: 12-08-2006, 12:03 PM
  3. Can small gaming companies suceed in todays gaming market
    By Charley in forum Technology News
    Last Post: 03-03-2005, 10:56 PM
