Results 1 to 6 of 6
Thread: Suggestions for Config.
05-08-2011, 01:05 PM #1
Hi Guys,
i came up with these 2 config.
AMD Phenom x6 1090T 3.2GHZ Processor
ASRock/Asus 890GX Extreme3 Mother Board
( AMD Radeon HD 4290 Graphics 512MB )
( 128MB DDR3 1333MHz SidePort Memory )
( Multi VGA Output To D-Sub, DVI-D and HDMI )
( 7.1 Channel HD Audio With Bluray Support )
RAM 2x2GB CORSAIR DDR3 2000
Hard Drive 1TB Western Digital
Cooler Cooler Master HAF 922
Cabinet
2nd Configuration for PC
CPU: Phenom II X6 1090T (Thuban, 6 cores/6 threads, 3.2 GHz, 6 MBL3);
Mainboard: ASUS Crosshair IV Formula (Socket AM3, AMD 890FX);
Memory: 2 x 2 GB, DDR3-2000 SDRAM, Patriot Viper II Sector 5 PC3-16000
(PVV34G2000LLKB);
Graphics card: ATI Radeon HD 5870;(Optional)
HDD: Western Digital 1TB;
CPU cooler: Thermalright Ultra-120 eXtreme with Enermax Everest fan;
PSU: Tagan TG880-U33II (880 W);
If you see i still don't have any idea for monitor and cabinet.
in short i still need a good config. so help me.
1. What is the purpose of the computer?
A: Video Editing Mainly. Burning Lots of DVD's, Wedding Video Editing.
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: Yes.
3. What is your MAX budget?
A: Not sure Yet but around 30k-40k
4. Planning to overclock?
A: No.
A: Windows 7
A: 1TB
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A: 21" is ideal. but i don't want this kind of monitor. i noticed images on this kind of monitor is really tough to edit. after finishing editing when i copy it to 2nd pc with CRT monitor results are funny LOL. so don't want this kind of monitor. http://www.techshout.com/images/lg-w...cd-monitor.jpg
A: 8
A: Yes
A: 2-3 Days
A: No.
A: no.
A: Gujarat
A: Nothing.
Thanks.Twitter Handle : /TheHumanBot
05-08-2011, 01:41 PM #2
Re: Suggestions for Config.
For 40k this is the best rig-
Follow me on Twitter: http://twitter.com/wuodland
Have a look at my Photography page: http://bit.ly/N2aMTi
05-08-2011, 02:05 PM #3
yes. I think a core i5 2400 does much better for AV editing. Replace HD6850 in thetechfreak's config with one of these:
ATI FirePro V4800
NVIDIA Quadro FX 380Samsung Galaxy S3 running cm10.1 nightly, Samsung Omnia W, Thinkpad T430 (Core i5, 8GB RAM, 160GB SSD, 14" 1600x900,9cell battery). Desktop: AMD Athlon X2 7750 BE, 4GB DDR2, 1TB HDD, 2600XT, 19" LCD
05-08-2011, 04:53 PM #4
desiibond, for video editing I don't think workstation cards are required, I think they are required for Rendering related work like working in 3D studio max, Maya etc.
A standard gaming card will be sufficent for standard video editing. I will suggest a GTX 460 1 GB card as CUDA is little matured over AMD APP.AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
06-08-2011, 12:32 PM #5
I need 1TB which i mentioned.
anyway i will update that.
Thanks everyone for replying and made it easy for me.
Thank you.Twitter Handle : /TheHumanBot
06-08-2011, 02:24 PM #6Wise Old Owl
- Join Date
- Aug 2007
- Location
- Chinchwad Pune
- Posts
- 1,461
Yeah Go with i5 if your budget is 40K. No Point going AMD in that Budget.
Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
i7 and i5 config suggestions
By sreedharvenugopal in forum CPU / MotherboardsReplies: 2Last Post: 14-12-2011, 02:32 AM -
Game Suggestions for my config
By mehra.rakesh in forum GamerzReplies: 0Last Post: 11-12-2009, 12:49 PM -
Suggestions for a desktop config
By nilesh82 in forum PC Components / ConfigurationsReplies: 1Last Post: 24-02-2008, 11:01 PM -
My HTPC config - Your Suggestions
By blacklight in forum PC Components / ConfigurationsReplies: 9Last Post: 31-05-2007, 09:25 PM -
my new to be amd pc config. good? ur suggestions pls...
By bibinpauljohn in forum CPU / MotherboardsReplies: 16Last Post: 14-04-2005, 08:28 PM
LinkBack URL
About LinkBacks
