Results 1 to 19 of 19
Thread: Gaming\Dev Build around 40k ?
04-08-2011, 01:58 PM #1Apprentice
- Join Date
- Aug 2011
- Posts
- 52
Below is the configuration i have come up with
Motherboard:ASRock Z68 EXTREME4
RAM:Gskill 4GB RAM
Powersupply:CORSAIR 600CX builder series v2
Cabinet:CoolerMaster 912 HAF Advanced
Process: i5 2500k
DVD Drive: Asus
HDD: WD CAVIAR Black 500GB
Graphics Card: Open for discussion., planning to buy it later.
Let me know what you think? Should go for this config ?Last edited by gamekraze; 05-08-2011 at 12:57 AM.
04-08-2011, 03:34 PM #2
Re: Gaming\Dev Build around 40k ?
Can you fill this up please so we can get idea of what you may want what what you dont want
http://www.thinkdigit.com/forum/pc-c...-template.htmlFollow me on Twitter: http://twitter.com/wuodland
04-08-2011, 04:04 PM #3Apprentice
- Join Date
- Aug 2011
- Posts
- 52
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:For software development, gaming, animation(not hardcore)
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:
3. What is your MAX budget?
A:50k
4. Planning to overclock?
A:Maybe
A:Windows xp sp2 or Windows 7
A:500GB
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A:23inch 1074x768 or the resolution which looks best in 23inch monitor.
A:6
A:assembler
A:Aug 2011
A:Yes
A:Graphics card but open to discussion so that i can later when i can buy it.,monitor,keyboard ,mouse,ups,speakers\headset
A:chennai
A:Last edited by gamekraze; 06-08-2011 at 12:27 AM.
05-08-2011, 12:03 PM #4Apprentice
- Join Date
- Aug 2011
- Posts
- 52
A:development, gaming, animation(not hardcore)
A:yea
A:50k
A:yea in future
A:windows xp sp3 or windows 7
A:500gb
A:1074 x 768 or the resolution which looks good in px2370 monitor
A:6
A:assembler
A:this month
A:yes
A:liquid cooling,special leds, graphics card (open to discussion, as i will buy it later), monitor, keyboard ,mouse,ups,speakers\headset
A:chennai
05-08-2011, 12:50 PM #5
Buddy, rather than posting multiple posts, you can just edit the 1st post if you missed something in the post. And answer the question properly.
What does it mean? Are you already having the PX2370 display or you are planning to buy. pX2370 offers resolution upto 1920X1080. If you already having the Monitor, then you should mention it in the question7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A:1074 x 768 or the resolution which looks good in px2370 monitorSimilarly if you are not going for a dedicated GPU, gaming is not possible with the IGP.12. Are there going to be any components that you don't want to include in this new rig? If yes, do mention.AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
05-08-2011, 02:37 PM #6Apprentice
- Join Date
- Aug 2011
- Posts
- 52
well my post was not seen so that i thought there was some problem so i re-posted.
I'm not planning to buy the monitor n the graphics card as of now due to budget constraints well i will buy them later. I do have my old graphics card nvidia 8500 GT which is a low end outdated graphics card.
05-08-2011, 04:56 PM #7
^^ 50K is a good budget and My suggestion is go for good display for now which is highly possible within 50K
05-08-2011, 06:02 PM #8Apprentice
- Join Date
- Aug 2011
- Posts
- 52
@Cilus cool if it can be done within 50k i shall go for px2370.
How about the other hardware mentioned above?
Is the mobo available in india? AsRock z68 extreme 4. Can i get this in chennai?
How about the power supply is it good? Or is there any other psu which is equally good but at a lower price?
05-08-2011, 09:15 PM #9
AsRock z68 extreme 4 is not available in India As far as I know
Here is my suggestion:-
Intel Core i5 2500 @ 10.3K
Intel DH67VR-B3 @ 4.5K
Gskill DDR3-1333 (PC3 10666) F3-10600CL9S-4GBNT 4 GB Ram @ 1.5K
Seagate 7200.12 500 GB SATA @ 1.8K
LG 22X SATA DVD R/W @ 0.8K
Corsair GS600W 80+ PSU @ 3.8K
NZXT Gamma Cabinet @ 2K
MSI GTX 560 Ti Hawk @ 14K
BenQ G2220HD @ 7.2K
Logitech Z313 @ 1.5K
Logitech MX-518 @ 1.3K
Keyboard Logitech KB @ 0.4K
Intex 1 KVA UPS @ 2K
Total 51.1KAMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
06-08-2011, 10:43 AM #10Apprentice
- Join Date
- Aug 2011
- Posts
- 52
i5 2500k - 10950
Gigabyte P67A-UD3R-B3 - 9800
Gskill DDR3-1333 (PC3 10666) F3-10600CL9S-2GBXL x2 - 2000
Corsair GS600W 80 plus -3800
CM 912 HAF - 6000
WD CAVIAR Black 500gb - 3000
LG/Asus Drive -1200
PX 2370 -11000
Total: 47750
I don't need mouse,keyboard,UPS, and i will buy the graphics card later.
I can go for a good and cheap z68 board which asrock z68 extreme 4 was perfect.
Should i go for CM HAF 912 advanced or 690 II advanced? Is the cooling system the only difference between 912 n 690 coz 690 has more fans? I think hAF 912 advanced looks gr8.
Sources tell me that asrock z68 extreme 4 might be available in the 1st week of sept.Last edited by gamekraze; 06-08-2011 at 11:27 AM.
08-08-2011, 01:58 PM #11Apprentice
- Join Date
- Aug 2011
- Posts
- 52
If i were to buy MSI NGTX 560 Ti Hawk graphic card, What should be the min wattage for the PSU?
Is 600GS Corsair good for this card or should i go for 700GS?
08-08-2011, 02:24 PM #12
08-08-2011, 03:03 PM #13Apprentice
- Join Date
- Aug 2011
- Posts
- 52
Samsung PX2370 is this fastest selling monitor or does it have some problems? Coz retailers have removed this model from their price list.
08-08-2011, 06:03 PM #14
i will suggest you to go eyes closed with what cilus suggested. bang for buck!
UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
HP Pavilion G6 2005AX - Genuine Windows 8 Pro, Samsung Galaxy Y Duos
08-08-2011, 09:18 PM #15
09-08-2011, 11:33 AM #16Apprentice
- Join Date
- Aug 2011
- Posts
- 52
@d6bmg
Why do you think asrock z68 extreme4 mobo sucks, coz i have read reviews about it and they say its good, and performance is close to asus z68 pro-v.Last edited by gamekraze; 09-08-2011 at 12:10 PM.
09-08-2011, 12:06 PM #17
Asrock Z68 Extreme 4 is a very good mobo but I don't think it is available in India.
09-08-2011, 12:41 PM #18
Yeah, I agree, AsRock manufactures very solid mobos at good prices, particularly for OCing. But getting one in India is next to impossible.
Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
Android: Galaxy R | Galaxy Y
10-08-2011, 07:59 AM #19Apprentice
- Join Date
- Aug 2011
- Posts
- 52
I have asked the distributors of asrock for india, they said it will available in the 1st week of sept. Lets see if they are right.
Guess what AMD had started manufacturing RAMs
but their max mem size 2GB with different speeds. AMD Radeon™ Memory for Systems They cost about 10$.
need to build a gaming pc under 50,000 rs
By sarveshrokz in forum PC Components / ConfigurationsReplies: 32Last Post: 19-07-2012, 10:21 PM -
Rs 50K Gaming Build !!!
By tnranganathan in forum PC Components / ConfigurationsReplies: 9Last Post: 10-06-2012, 09:35 AM -
Help me to build a new gaming rig under 70k/75k
By devx in forum PC Components / ConfigurationsReplies: 83Last Post: 10-01-2012, 12:37 AM -
need help to build up a gaming rig @ 70k
By Arnab boss in forum Hardware Q&AReplies: 142Last Post: 25-06-2009, 07:55 AM -
build a gaming rig
By FLAWLESS VICTORY in forum Hardware Q&AReplies: 11Last Post: 11-07-2008, 07:38 AM
LinkBack URL
About LinkBacks
