Results 1 to 9 of 9
Thread: Best configuration under 13k-14k
08-05-2011, 01:34 PM #1Right Off the Assembly Line
- Join Date
- May 2011
- Posts
- 3
Hi experts, i am new here in this forum. Please suggest me best configuration for Processor + Motherboard(onboard video) + Ram + Hard disk(minimum storage capacity) within the budget of 13k to 14k. I prefer Intel but Athlon is also acceptable. Actually Previously i used an athlon CPU and i was not satisfied with the performance so i am thinking of intel. Anyway suggest me the best. Thanks in advance.
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: Photoshop, downloading images from memory card, digicam, HD video playback and other normal daily multitasking.
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:Yes always welcome
3. What is your MAX budget?
A:14K
4. Planning to overclock?
A:yes if possible for faster performance
A:W7 home premium 64bit and XP pro 32bit.
A:160GB is more than enough for me.
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A:24" Full HD
A:5
A:I have done more than ten times.
A:tomorrow
A:Yes. As i am going to install genuine windows OEM version.
A: Graphics card as i want onboard graphics.
A:Kolkata
A: Only MOBO+PROC+RAM+HDD configuration is needed.Last edited by sajal2004; 08-05-2011 at 01:57 PM.
08-05-2011, 03:10 PM #2
Re: Best configuration under 13k-14k
Processor-Intel core i5 2300 -Rs 9000
Motherboard - Intel DH61WW- Rs 3350
Hard Disk- Seagate 250 GB Rs- 1650
RAM- Corsair Value RAM 2GB Rs- 1000
Total= Rs 15000
This provides extremely good performance for your budget and will run anything seamlessly for atleast 3-4 years. Add another 2gb of RAM when you have the cash.Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
08-05-2011, 03:15 PM #3
At this budget, nothing beats AthlonII.
Go for this:
* CPU: AthlonII X4 640 -- 4.5k
* MoBo: GA-MA880GM-UD2H -- 4.2k
* RAM: Corsair 4GB DDR3 -- 2.2k
* HDD: Seagate 7200.12 1TB -- 2.6k
Total ---- 13.5k
Its AthlonII Proccy and is much better than any intel counterpart at this budget. You get a REAL QUAD CORE unlike intel.
GeekyBoy,
do you think it makes sense to go for 250GB HDD at 1.65k when a new 500GB HDD is available for 1.7k.
Yes, the intel i5 rig is better rig. And OP should go for it if he extends his budget by 1.5k.
08-05-2011, 03:22 PM #4
Not necessarily. The core i5 (which is obviously quad core )is much much more future proof than the athlon.
The problem is, athlon II x4 will run out of steam in 1-1.5 years, while core i5 will go on upto atleast 3 years. In 1.5 yrs time the OP will need to upgrade again.(requiring a truckload of cash again..)
Core i5 may have a high initial buying cost, but pays you off in the long run.
So Core i5, I think is the better option.
@saswat23, deltapage lists a 500gb at 1.9k...where did you get that 1.7 quote?Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
08-05-2011, 03:28 PM #5
Thats what i said GeekyBoy. At this budget only intel i5 can be considered, not i3 as AthlonII X4 is better than i3.
And about the HDD, thats probably an old pricelist of DeltaPage. A new one costs not more than 1.7k and a 250GB is very very rare to find now a days.
08-05-2011, 03:34 PM #6
08-05-2011, 06:38 PM #7Right Off the Assembly Line
- Join Date
- May 2011
- Posts
- 3
I convinced and will go for i5. Now if i increase my budget to 16K can have any better motherboard. Actually i am in photography business and microsoft caught me with 5 pirated copies of OS on 5 of my machines. Now i have to go for the original and i decided to replace all my dual core CPUs. As the quantity is 5 i dont want to increase the budget. But i want a better motherboard. I want at least 2 pci slot on one of these motherboard as i have to install two special firewire card on one of them. onboard firewire port will not work for me. Please help me. Thank you.
08-05-2011, 10:50 PM #8
09-05-2011, 09:33 AM #9Right Off the Assembly Line
- Join Date
- May 2011
- Posts
- 3
I already have PSU, Cabinet, Monitor and optical drive. So i only want to buy Processor, Motherboard, Ram and HDD and now the budget for these componets is around 16 to 16.5k
New pc configuration and selling off the present cpu configuration
By sabyasachi in forum CPU / MotherboardsReplies: 4Last Post: 05-08-2011, 04:01 PM -
configuration
By vibhor in forum PC Components / ConfigurationsReplies: 5Last Post: 27-06-2011, 08:03 PM -
Configuration for 40k.
By lingo in forum PC Components / ConfigurationsReplies: 7Last Post: 23-04-2010, 07:59 PM -
help with a pc configuration....
By digitizen in forum PC Components / ConfigurationsReplies: 9Last Post: 13-06-2009, 07:08 PM -
HElp me please with ma configuration
By josethomasmuricken in forum PC Components / ConfigurationsReplies: 4Last Post: 02-12-2006, 02:06 PM
LinkBack URL
About LinkBacks
