Results 1 to 19 of 19
08-05-2011, 12:12 AM #1Right Off the Assembly Line
- Join Date
- May 2011
- Posts
- 7
required PC configuration for 35K
PC Build Request Template
Fill up the following in your OWN configuration THREAD on the first post itself using the questions exactly as below: this will save both the requestor as well as the advisor a lot of time, effort and heartburn. Keep an open mind when someone suggests an alternate brand as they are more aware of the current performers than you are. Being a fanboy will end up wasting money.
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: Home use; watching movies, occasional gaming and net surfing et al. I use Acad some times for CAD drafting.
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:yes
3. What is your MAX budget?
A:Rs. 35000
4. Planning to overclock?
A: no
A:Windows 7
A: 1TB
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A: Would like minium 22''. i would prefer to have a monitor where i can connect Dish tv set top box directly to monitor to watch TV if required w/o TV tuner card in PC
A: 3
A: No. will be done by assembler
A: in a week
A: yes around 3 years before i switch
A: UPS, printer
A: Thane near Mumbai
A:
08-05-2011, 04:28 PM #2
Re: required PC configuration for 35K
and if you want Intel based,
Graphic card-
If you can spend extra money on Intel, well worth it.Last edited by thetechfreak; 08-05-2011 at 05:29 PM. Reason: Added 22 inch monitor and other info
08-05-2011, 05:11 PM #3Broken In
- Join Date
- Aug 2010
- Location
- The God's Own Country
- Posts
- 115
The suggested monitor has a number of connectivity options and also has built in speakers so that you can connect it to your set top box directly. The MSI motherboard lacks USB 3/SATA 6Gbps, but has DVI-D, HDMI, VGA connectivity.
Another AMD Based option is :
The rest are same. Thus gives total = Rs.34200.
Else you can opt for a normal 22" monitor and use a tv tuner card for watching tv.AMD Athlon II X4 635 || Asus M4A78LT-MLE || Kingston 2X2GB 1333MHz DDR3 || WDC Green 500GB || CM Elite 310 || Dell E2010H
08-05-2011, 05:18 PM #4
Its really not worth spending almost half the money of budget on monitor only.
Btw, op doesnt need a 23 inch panel. He wrote 22 inch. So lets reccomend a monitor that leaves head room for other components.
No GPU? Sorry but I dont like the idea of spending money on a huge monitor and use no GPU.
08-05-2011, 06:30 PM #5Broken In
- Join Date
- Aug 2010
- Location
- Posts
- 115
^ He wrote minium 22. Also he want the monitor to be connected with STB. I know, spending too much on a monitor is not good unless very necessary.
Also a GPU is not necessary for the op's normal uses.
Lets wait for the op to comment.AMD Athlon II X4 635 || Asus M4A78LT-MLE || Kingston 2X2GB 1333MHz DDR3 || WDC Green 500GB || CM Elite 310 || Dell E2010H
09-05-2011, 08:36 AM #6Right Off the Assembly Line
- Join Date
- May 2011
- Posts
- 7
Thanks guys for your recommendations. I have a few questions
1) What are other benefits of using samsung P2370MS over other monitor, except that it is 1" bigger screen.
2) Is there a equivalent cost effective monitor( direct connection to settop) in 22"
3) Is AMD Athlon II x4 640 performance adequate for my application w/o a graphics card.
3) Can you give names/ numbers of some assemblers in thane/mumbai region where I can get machine with above configuration. How much should I consider as charges for assembly
4) are the indicative prices including taxes and duties? Since I need a VAT invoice for the machine.
09-05-2011, 10:51 AM #7
Its got a couple extra couple ports, better screen. But I think its best to spend extra money on a Graphics Card
Originally Posted by sabmayahai
The Benq G2220 HD as I have posted is one of the best 22" monitors at that price.
Originally Posted by samayahai
Its always good to get a GPU when you use a PC for CAD. But for movies it should be, but I reccomend you to get GPU.
If you spend a little extra on the Intel config, its way better and a bit more future proof.
Go to Lamington Road, Mumbai. There will be loads of shops there. Considered Hardware heaven of India.
09-05-2011, 10:57 AM #8
Conflicting!!!!
You just forgot that settop thing. Just get a VFM 22" monitor, get a decent GPU like 5770 for 7.5k. CAD sure needs a GPU, dedicated. Onboard will screw things up in such scenario.
Take manju's config, change the monitor to "Benq G2220Hd @ 7300" and invest rest in Sapphire 5770 @ 7.5kE7400 | 4GB | HD4670 | AOC T2442we | Logitech Z103 2.1 | Pantech Burst Black running ICS| HP ProBook 4530s
----Pantech Burst - Quick Review----
----LG L9 Review----
Steam ID : furious_gamer2012
09-05-2011, 11:27 AM #9Right Off the Assembly Line
- Join Date
- May 2011
- Posts
- 7
Thanks to Techfreak , manu and Furious gamer for your inputs
I was just comparing the two monitors BenQ and Samsung. Barring the size only diff i could see that P2730 has built in TV tuner , remote and few other connectors i could not understand. The comparison is attached.
Does this mean in need a TV tuner card with BenQ monitor? or does the settop box eliminate need for TV tuner card?
09-05-2011, 11:30 AM #10E7400 | 4GB | HD4670 | AOC T2442we | Logitech Z103 2.1 | Pantech Burst Black running ICS| HP ProBook 4530s
09-05-2011, 11:37 AM #11Right Off the Assembly Line
- Join Date
- May 2011
- Posts
- 7
for academic interest, when is the tuner card required? when I am connecting the cable TV (non-DTH) W/o Set-top box ?
Also to which port is the PC connected and to which is the STB connected ?
09-05-2011, 11:50 AM #12
Exactly.
It will help you, i guess
Connecting Set Top Box to PC - AfterDawn: Forums
Set Top Box to PC Connection - Cable ForumE7400 | 4GB | HD4670 | AOC T2442we | Logitech Z103 2.1 | Pantech Burst Black running ICS| HP ProBook 4530s
09-05-2011, 12:10 PM #13Right Off the Assembly Line
- Join Date
- May 2011
- Posts
- 7
I just realised that G2220HD and E2220HD are different monitors with feature differences (E2220 has HDMI port and Speakers which G2220HD lacks) . Is E2220HD available in india? if yes what is the price.
09-05-2011, 12:18 PM #14
Theitdepot - BenQ 21.5inch Widescreen Full HD LCD Monitor (E2220HD)
Street price will be bit cheaper.E7400 | 4GB | HD4670 | AOC T2442we | Logitech Z103 2.1 | Pantech Burst Black running ICS| HP ProBook 4530s
09-05-2011, 06:26 PM #15Broken In
- Join Date
- Aug 2010
- Location
- Posts
- 115
Okey, here i edited the config.
09-05-2011, 06:27 PM #16E7400 | 4GB | HD4670 | AOC T2442we | Logitech Z103 2.1 | Pantech Burst Black running ICS| HP ProBook 4530s
09-05-2011, 07:54 PM #17Right Off the Assembly Line
- Join Date
- May 2011
- Posts
- 7
what is the kind of margins/charges that assemblers keep? I am not getting quotes in the vicinity of those figures. they are atleast 5-7K higher.
12-05-2011, 05:43 PM #18Right Off the Assembly Line
- Join Date
- May 2011
- Posts
- 7
Intel Core i5 2400
Intel DH61WW
Benq E2220HD
G.Skill F3-10666CL9S-4 GBNQ
Seagate ITB 7200.12
LG 22X SATA DVD
Logitech KB-200
Logitech 3 Button Scroll
FSP Saga II 500W + CM Elite 310
1 GB HD5700 series graphics card
I am buying this config at 37.5 K.
Is the above separate graphics card useful with with I5-2400 which has onboard graphics ?
12-05-2011, 05:47 PM #19
When you add a dedicated Graphics card, the onboard graphics of the Sandy bridge processors gets disabled with H61 chipset based mobos.
AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
Urgent PC configuration required
By abhi01786 in forum PC Components / ConfigurationsReplies: 6Last Post: 07-09-2011, 09:47 PM -
HTPC Configuration required
By sydbarett in forum PC Components / ConfigurationsReplies: 2Last Post: 09-08-2011, 07:08 PM -
New Pc configuration suggestions required
By rohit18rs in forum PC Components / ConfigurationsReplies: 8Last Post: 02-05-2011, 12:23 PM -
System Configuration Help Required!
By cyberdragon007 in forum PC Components / ConfigurationsReplies: 18Last Post: 06-04-2010, 06:42 PM -
Configuration Help Required - Gaming Rig
By premsharma in forum PC Components / ConfigurationsReplies: 24Last Post: 18-01-2007, 12:59 AM
LinkBack URL
About LinkBacks
