Results 1 to 17 of 17
  1. #1
    May 2011
    Question Build a PC (~30k)
    1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
    A: I'm planning to use this PC as a home server. It will run day and night. Also, i'm planning to use it mainly for programming (will run VMs and do heavy database scripting)
    2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
    A: Yes, ofcourse
    3. What is your MAX budget?
    A: 30k
    4. Planning to overclock?
    A: Maybe
    A: Ubuntu (Linux)
    A: 1 TB
    7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
    A: I want atmost 20 inches screen with highest possible resolution
    A: 5
    A: Assembler
    A: Within a week or two
    A: Yes
    A: N.A.
    A: New Delhi, will buy most probably from wazirpur market (delhi)
    I am confused between AMD and intel. Never used an AMD before. But it offers 6 cores. Is 6 core (with low clock rate) better than 4 core (with high clock rate) ? Also intel provides hyperthreading, is it equivalent to having extra real cores ?
  2. #2
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    Default Re: Build a PC (~30k)
    OPTIONAL UPGRADES-
  3. #3
    Human Spambot MegaMind's Avatar
    Nov 2010
    Perambalur, TN
    For Linux based OS, stay away from ATI...
    i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
  4. #4
    May 2011
    India
    @theTechFreak
    Dude this rig is not for gaming.So 5770 is OverKill
    Logitech Z313 is Rs 1800 and not Rs 1000.OP wants 1TB not 500GB HDD
    Intel i5 2300 - Rs 9300
    MSI H61M-e23 [B3 Revision] - Rs 3600
    G-Skill Rip Jaws 4GB DDR3 - Rs 2300
    Corsair CX 400W PSu - Rs 2800
    Seagate Barricuda 1TB HDD Sats 3Gb/s - Rs 2800
    Cooler Master Elite 430 - Rs 2450
    Ben Q 22inch Full HD - Rs 7250
    Logitech Media Keyboard - Rs 500
    Logitech Mouse M115 - Rs 450
    Logitech Speakers - Rs 500
    Total 33000
  5. #5
    Nov 2008
    Guwahati
    Quote Originally Posted by Siva Lord
    Please be precise with model name/ number
    Its Benq G2220 HD @ Rs.7300
    BTW, OP posted he wants 20 inch max not 22 inch
    EDIT: the config I posted has been edited. GPU removed and 1 tb HDD added
    EDIT: Graphic Card made optional
  6. #6
    May 2011
    Thanks a lot guys for the suggestions.
    Just wondering whether AMD Phenom II x6 1055t (2.8GHz) better than a 4 core >3.0GHz CPU ?
    And i think i would at least require a 4 gigs RAM.
    Also can you suggest any low price VFM Nvidia card ? (<5k)
  7. #7
    Nov 2008
    Guwahati
    Quote Originally Posted by free2talk.183
    No good Nvidia card in that range
    But you will get Gts 240.
    Old card no dx11 suport
    core >3.0GHz CPU ?
    Yeah it is. But its costly and we wont be able to accomodate quality products.
    in 30k rig if 9k is spent in proccy, then its difficult to accomodate in your budget.
    p.s- added 4 gb ram to the config
  8. #8
    May 2011
    India
    GT 440
    Supports Direct X 11
    Price:Rs 4300
    GT 430
    Price:Rs 3999
  9. #9
    Right Off the Assembly Line Razor 1911's Avatar
    May 2011
    Soul Society
    AMD Phenom 2 1055T - Rs7800
    GigaByte Ga880GM - Rs 4200
    Corsair 4GB DDR3 - Rs 2500
    Seagate 1TB HDD - Rs 2700
    Corsair CX 400W Psu - Rs 2800
    Dell In2020M - Rs 6500
    LogiTech Media KeyBoard - Rs 500
    Logitech Multimedia Speakers - Rs 300
    Numeric 800VA Ups - Rs 2500
    Total:Rs 30700
  10. #10
    May 2011
    Thank you so much
    I am planning to get 1055t only, so i think config suggested by @Razor is the best bet for me. But i am confused for the graphics card, is GT 440 worth the price ?
    Note : I am not into gaming so i don't need a high performance card
  11. #11
    Jul 2008
    Kolkata
    1055T is a dead end. Go for the Sandy Bridge instead of AM3 cpus. Here is my 2 cents :
    Intel i5 2500 - Rs 10300
    Corsair Value 4GB DDR3 - Rs 2100
    Corsair CX 400W PSu - Rs 2500
    Seagate Barracuda 1TB HDD Sats 3Gb/s - Rs 2700
    Zebronics Bijli - Rs 1200
    BenQ G2220HD - Rs 7300
    TVSE Champ Keyboard - Rs 250
    Total 30900
    Also if you go for the K version of the cpu you will get better graphics equivalent to 5450 graphics. It will cost you another 700-800 bucks more.
  12. #12
    May 2011
    Quote Originally Posted by ssengupta View Post
    I know that there will be no options for upgrade on AM3 mobo but i need a VFM CPU+mobo, so i think AM3 mobo + 1055t will be best? (Most probably, i'll be using this PC for not more than 2 years ) Also AM3+ motherboards are costly and there is no BD CPU out there yet...
    Btw, thanks for your advice
  13. #13
    May 2011
    Soul Society
    @ssengupta
    His 1055T is not a dead end.All Gigabyte Motherboards recently had a Bios update to support AM3+ and an AM3+ Cpu will fit in his Motherboard perfectly.
  14. #14
    Nov 2010
    Perambalur, TN
    I recommend this Rig,
  15. #15
    Jul 2008
    Kolkata
    Quote Originally Posted by Razor 1911 View Post
    @ssengupta
    But AM3+ boards are not available in India yet.
  16. #16
    May 2011
    Is this motherboard AM3+ or will there be any BIOS update to support AM3+ processors?
    Btw, thanks for a great response.
  17. #17
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    The mentioned Gibabyte board is an AM3 board, not an AM3+ one. But with a BIOS update it will support upcoming AM3+ processors. But even Biased towards AMD, I would recommend you to go with a new sandy bridge processor.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  1. new build in 40-45K
    By truegenius in forum PC Components / Configurations
    Last Post: 18-06-2012, 01:43 PM
  2. cpu build
    By karthik subbaraman in forum PC Components / Configurations
    Last Post: 01-08-2011, 08:26 PM
  3. Build my PC
    By smash555 in forum PC Components / Configurations
    Last Post: 05-07-2011, 10:24 PM
  4. Want a build pc under 12k
    By bhushan2k in forum Hardware Q&A
    Last Post: 02-11-2007, 12:48 PM
