Results 1 to 14 of 14
  1. #1
    Always on net Symbianlover's Avatar
    Dec 2009
    kolkata
    Question queary about psu
    Is corsair vx 450 is enaugh for ati radeon hd6870.
    If i will buy hd6950 then what about the psu?
    If its not sufficient then plz mention(only corsair)
    Computer Entusiast//Pc software lover/Pc game lover/Windows 7 Ultimate 64 bit/Intel core i3/WD 500Gb Hdd /2 Gb DDR3 RAM /SAMSUNG 22'' FULL HD /Android 2.2/Symbian 3rd eddition
  2. #2
    Tensor Gaurav Bhattacharjee's Avatar
    Feb 2010
    Guwahati
    Default Re: queary about psu
    Get Corsair VX550 @4.5k and have no more worries in life!!
    But if you stick to 6870 then VX450 is fine.
    Athlon II X2 260 | Gigabyte GA-78LMT-S2P | HIS IceQ Radeon HD5670 1GB GDDR5 | Corsair Value 1x4GB 1333MHz | Cooler Master Elite 311 | Corsair CX430V2 | WD Caviar Blue 160GB | Viewsonic VA503m | Logitech Z110 | Sony DVD-RW AD-7240S | Generic Keyboard & Mouse | Zebronics 700VA
    SteamID
  3. #3
    Human Spambot MegaMind's Avatar
    Nov 2010
    Perambalur, TN
    @OP Post ur full PC specs..
    i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
  4. #4
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    I think VX-450 can handle 6950 easily.
    Check here
    My Blog :D
  5. #5
    Dec 2009
    kolkata
    thanks bro for help.
    My pc config is-
    proce-core i5 2500k
    mobo-msi p67A GD55
    RAM-G.SKILL RIPJAWS F3 12800CL9D-4GBRL
    GPU-RADEON HD6870
    HDD-SEAGATE 1TB
    DVD-2*1 LG 22X SATA
    CASE-CM ELITE 430
    PSU-CORSAIR VX450
    MONITOR-BENQ G2220HD
    IS THE CONFIG IS SUFFICIENT WITH VX450?
    I am a big game lover so want to play game in hd ?
    Whats ur openion?
  6. #6
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    Yeah, its enough. But you cant crossfire with this PSU.
    Hd gaming on most games can be done.
  7. #7
    Human Spambot The Sorcerer's Avatar
    May 2008
    Stick to VX550. Newer VX series arent as good as they used to be.
  8. #8
    Gadget Freak Tenida's Avatar
    Aug 2008
    Calcutta
    You can find Corsair Vx 550 at Vedant/MD computers.Go for VX 550 for future upgrading.
    My Gizmos O_O
    ||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
    ||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
  9. #9
    d3p
    d3p is offline
    PowerHouse d3p's Avatar
    Jan 2010
    Bangalore
    Quote Originally Posted by Symbianlover View Post
    My pc config is-
    proce-core i5 2500k
    mobo-msi p67A GD55
    GPU-RADEON HD6870
    HDD-SEAGATE 1TB
    DVD-2*1 LG 22X SATA
    CASE-CM ELITE 430
    PSU-CORSAIR VX450
    Whats ur openion?
    Check the specs of VX450 & check whats the Max Power output. I think its 500+ [520 or 550 not sure of the exact value].
    & the following PSU can handle without any problem, but no CF can be achieved with it.
    2600k|Maximus IV Ex-Z|Venomous X RT CM R4's Push Pull|RipjawX 16GB|Sapphire HD7970 CF [1250MHz]|OCZ Vertex 3 120GB|WD Black Raid 0|AX850w|Asus Xonar DX|Dell U2412M x 3 Eyefinity|HAF 932 Advanced|Sentry II| Logitech G27, G15, Attack II, C310 HD|Razer DeathAdder, Megalodon|Steelseries Ikari Optical|
    My Game Collection & Sapphire HD 7970 Unboxing
  10. #10
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Even it recommended to have a 500W PSU for HD 6870 and it is mentioned in AMD's site. Apart from that your system is a powerful one and for keeping room for future upgrades, get a good PSU of minimum 500W.
    if you are in tight budget then have look at Corsair GS 600W @ 3.8K or Tagan Stonerock 600W 80+ bronze @ 4K (may be less street price). But VX 550 is the best choice here.
    AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
  11. #11
    Dec 2009
    kolkata
    thanks but what is the price of vx 550.
    About crossfire,
    is my mobo able for crossfire.
  12. #12
    Feb 2010
    Guwahati
    About crossfire,
    1. VX550 should be around 4.5k.
    2. Yes, your mobo has multi-GPU support.
    SteamID
  13. #13
    Pirate Slayer Cool Comps's Avatar
    Jan 2011
    Guys i bought cooler master gx650 psu. None of the shops had vx550. Thats the reason.
    So is GX650 a good psu??
  14. #14
    Aug 2008
    Calcutta
    ^^Corsair VX550 is better than CM GX650.
    My Gizmos O_O
  1. All Mobile Related Queary Here
    By Riteshonline in forum Mobiles and Tablets
    Last Post: 03-08-2009, 11:45 PM
