Results 1 to 30 of 55
Thread: gaming rig under 65k
26-04-2011, 09:56 PM #1Right Off the Assembly Line
- Join Date
- Apr 2011
- Posts
- 47
gaming rig under 60k with i5 and ati 6970
want an i5 rig
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:just gaming
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:yeah
3. What is your MAX budget?
A:60-63k
4. Planning to overclock?
A:maybe
A:win 7
A:1 tb
7. What resolution will the screen run at & whats the size of the screen you want? If you already want have one and want to use it, mention its resolution and size.
A:1920 x 1080
A:7
A:by an assembler
A:maybe in 1 week
A
ffcourse
A:speakers
A:ludhiana punjab
A:i called the assembler and he told me the following configuration
i5 kit =18300
corsair 4gb ram 1600mhz =3600
1tb hd =2700
sapphire 6970 =21300
psu coolermaster 600w=3500
i ball case =1500
dvd drive = 900
lg 2240 montor =8800
wirless keyboard and mouse =2000
total 62600Last edited by jassgrewal; 26-04-2011 at 09:43 PM.
27-04-2011, 10:10 AM #2
Re: gaming rig under 65k
UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
HP Pavilion G6 2005AX - Genuine Windows 8 Pro, Samsung Galaxy Y Duos
27-04-2011, 10:15 AM #3
@jassgrewal
2nd rig is a better one to go for
27-04-2011, 12:42 PM #4In The Zone
- Join Date
- Mar 2011
- Location
- Mumbai
- Posts
- 186
hey better get 1600MHz ram.1333 is a bit more slower
27-04-2011, 01:00 PM #5
Didn't we just have a thread for a 65K rig a few days ago? And Jas created a comprehensive guide for almost all price ranges.
anyways, this is just my suggestion and I know there will be people who will jump on me for this, but I don't think that for casual gamers, spending so much on a gaming keyboard/mouse makes sense. Unless you're the kind who frags at LAN parties or take part in tourneys regularly, you won't notice the difference between a 300 Rupee and a 3000 Rupee keyboard.
I am not talking about aesthetics, because I am color blind when it comes to value lol
So if you skimp out on that and opt for a regular mouse/keyboard combo, you will be able to use that money to either get yourself a CPU Cooler or upgrade the hard drive to 1TB.
The 2500K is an awesome CPU that is wasted if not Overclocked. And to ensure stable OCing, you need to replace the standard Intel fans . Just my two paises worth.
Plus, you have to factor in the price of a genuine Windows Disk, which will easily raise the overall cost by 5-10%.Core i5 2400|| Gigabyte ph67 B3|| 8GB DDR3 1333|| 1TB WDC Black|| CM 690II Nvidia Edition|| CM 850W Silent Pro|| Samsung 2333T|| Gigabyte Geforce 670 2GB (Windforce 3x)|| Logitech G35 Headset
27-04-2011, 06:24 PM #6
^what??
you want to say TVS Champ and Razer Arctosa have no difference except aesthetics??i5 2500K|P8Z68 V PRO|560Ti Hawk|G Skill 8GB 1600MHz|SG 500 GB|WD Passport 1TB|TX850V2|690II Advanced|BenQ G2420HD|Razer Cyclosa Bundle|Razer Goliathus|APC 1.1 KVA|TP LINK WR841N WiFi Router|Windows 7 X64|XBOX 360 wireless controller
Samsung Galaxy Note
Steam: masterkdxp
27-04-2011, 06:49 PM #7Right Off the Assembly Line
- Join Date
- Apr 2011
- Posts
- 47
is it important to have a good case?
plz suggest me some good coolermaster psu
is my lg monitor is ideal for gaming
27-04-2011, 07:00 PM #8
you have been recommended a Seasonic S12II 620w Bronze PSU by Jaskanwar.
Good PSUs and Cooler Master - these two words don't go hand in hand. (except Real Power and Silent Pro series)AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
27-04-2011, 07:07 PM #9
case is the house of your components..if you feel you need a good house to live then the components need a good case for them too!!
if you wanna spent 8.8k for screen why lg2240 get dell st2220L
corsair/seasonic psu is better than CM..if you prefer CM only for psu get CM real power/silent poweri5 2500K|P8Z68 V PRO|560Ti Hawk|G Skill 8GB 1600MHz|SG 500 GB|WD Passport 1TB|TX850V2|690II Advanced|BenQ G2420HD|Razer Cyclosa Bundle|Razer Goliathus|APC 1.1 KVA|TP LINK WR841N WiFi Router|Windows 7 X64|XBOX 360 wireless controller
Samsung Galaxy Note
Steam: masterkdxp
27-04-2011, 08:30 PM #10Right Off the Assembly Line
- Join Date
- Apr 2011
- Posts
- 47
is it a good deal to buy ati 6970 or should i buy 6950 and oc it
can 6970 also oc
27-04-2011, 08:56 PM #11
yes of course you can oc both. but 6970 better deal.
27-04-2011, 09:08 PM #12Right Off the Assembly Line
- Join Date
- Apr 2011
- Posts
- 47
thnks guys !
jas i had checked ur review on dell st 2220l 21.5 and i think i should go for it ?
how much will it cost to me
27-04-2011, 09:11 PM #13
^its a good monitor. available at 8.7k.
27-04-2011, 09:55 PM #14
my suggestion
any reason of preferring ATI card over NVIDIA, and do u need a UPS or no plz mentiondell inspiron 15r turbo
nikon D5100, nikkor 70-300mm vr, 18-55 kit lens, 50mm 1.8G
flickr--> http://www.flickr.com/photos/94910990@N04/
27-04-2011, 10:21 PM #15Right Off the Assembly Line
- Join Date
- Apr 2011
- Posts
- 47
the reason is that in range of 20k the competitor of ati 6970 is gtx 570 and 570 slight slow than 6970 and the gtx 580 is out of my budget
27-04-2011, 10:32 PM #16
@ jaskanwar just curious
im not a geek still learning abt stuff from u guys
@ jassgrewal do u need a UPSdell inspiron 15r turbo
27-04-2011, 10:37 PM #17UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
27-04-2011, 10:41 PM #18Right Off the Assembly Line
- Join Date
- Apr 2011
- Posts
- 47
yeah i need a ups 800w
27-04-2011, 11:05 PM #19
nah.. Get a 1KVA UPS from APC.. they will cost more but are worth the money.. can't tell you the exact model..
27-04-2011, 11:10 PM #20
28-04-2011, 10:30 AM #21Right Off the Assembly Line
- Join Date
- Apr 2011
- Posts
- 47
i hav checked out cm eXtreme Power Plus 600W psu is it good for my cofiguration?
28-04-2011, 10:41 AM #22
28-04-2011, 01:39 PM #23Right Off the Assembly Line
- Join Date
- Apr 2011
- Posts
- 47
SeaSonic S12II 620 is not available in mine area but i m able to get cm elite 430.plz suggest
any other alternative for psu
28-04-2011, 01:46 PM #24
Try ordering from here: Seasonic S12II 620w Brone @ TheITWares
Reliable website. You can go for Corsait TX650v2 if you are able to find it.
And please don't go for Cooler Master at any cost. You have been warned regarding this.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
28-04-2011, 02:28 PM #25Right Off the Assembly Line
- Join Date
- Apr 2011
- Posts
- 47
thks ico for ur advice im not going for cm psu but plz tell me price of Corsait TX650v2
28-04-2011, 02:43 PM #26
around 5.8k to 6.2k depending upon places
28-04-2011, 04:56 PM #27
price for tx650v2 is 5500 rs
28-04-2011, 07:16 PM #28
29-04-2011, 08:04 PM #29Right Off the Assembly Line
- Join Date
- Apr 2011
- Posts
- 47
i think CM Elite 430 is better for me than 690 and its price is also less
29-04-2011, 08:54 PM #30
^^yup it's good case...check the Review
Sony Xperia P Review - my first droid | Nokia Lumia 620 Review
Facebook | Google+ | Twitter
Intel Core i5 2400 | Asus P8H61-M Plus 2 | Corsair 4GB XMS3 1600 (2X2GB kit) | FSP Saga II 500w | NZXT Gamma | Seagate 500 GB Sata | Asus 24x DVD RW Sata
To get Logitech G15 Gaming Keyboard and MX518 Gaming Mouse
By debasis_7012005 in forum Hardware Q&AReplies: 24Last Post: 10-09-2007, 02:37 PM -
what's the difference btwn Online gaming & Internet gaming
By singh in forum GamerzReplies: 2Last Post: 12-08-2006, 12:03 PM -
Can small gaming companies suceed in todays gaming market
By Charley in forum Technology NewsReplies: 16Last Post: 03-03-2005, 10:56 PM
LinkBack URL
About LinkBacks
