Results 1 to 17 of 17
Thread: Which Power Supply to buy?
17-04-2011, 05:09 PM #1Right Off the Assembly Line
- Join Date
- Apr 2011
- Location
- Hyderabad
- Posts
- 45
Which PSU should be ok for the following config?
My usecase is such, that the system is Always On(24*7).
And i plan to OC a little..
The following are my options:
Seasonic S12II-520 -Rs 3600 (my first choice)
Corsair 600GS -Rs 4000
Corsair 550VX -Rs 4900 (I wanna avoid this as it wud be a blow to budget)
The purpose of the thread:
--> Is it ok if i stick with seasonic S12II-520?
--> If not, im even ok with Corsair 600GS.
--> But if 600GS is not good enough ill have to shift to 550VX. So is 600GS good enough?
17-04-2011, 05:14 PM #2
17-04-2011, 05:17 PM #3
Re: Which Power Supply to buy?
^^ Ya avoid Corsair GS series....
Get TacensSupero 600W if u can find one....
Else get Seasonic S12II-520...
@OP, By the way u havnt stated ur budget?i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
17-04-2011, 05:25 PM #4Right Off the Assembly Line
- Join Date
- Apr 2011
- Location
- Hyderabad
- Posts
- 45
With Seasonic S12II-520 i think il be cutting it too close. As my power consumption comes to around 500W.
And My budget is: 4000k But i also want a great power supply. I blew out my previous computer(very powerful,..very sad) because of cheap PSU.
@saswat
I havnt read much about TacensSupero 600W for 3.5k. Ill research now though. But isnt going with corsair or seasonic, best..
17-04-2011, 05:45 PM #5
17-04-2011, 05:46 PM #6
Cheap PSU's are cheap because they are bad and they do not provide the amount of power that they are rated to give and that's why your previous system blew up. If you buy a real PSU then rest assured it will provide more power than it is rated for.
Your rig will be easily handled by Seasonic S12II 520. You will not cut it close.
SeaSonic S12II 520 costs 4.1k not 3.5k.Athlon II X2 260 | Gigabyte GA-78LMT-S2P | HIS IceQ Radeon HD5670 1GB GDDR5 | Corsair Value 1x4GB 1333MHz | Cooler Master Elite 311 | Corsair CX430V2 | WD Caviar Blue 160GB | Viewsonic VA503m | Logitech Z110 | Sony DVD-RW AD-7240S | Generic Keyboard & Mouse | Zebronics 700VA
SteamID
17-04-2011, 05:57 PM #7
17-04-2011, 06:02 PM #8
SteamID
17-04-2011, 06:07 PM #9
^^Shipping cost extra...
17-04-2011, 06:10 PM #10Athlon II X2 260 | Gigabyte GA-78LMT-S2P | HIS IceQ Radeon HD5670 1GB GDDR5 | Corsair Value 1x4GB 1333MHz | Cooler Master Elite 311 | Corsair CX430V2 | WD Caviar Blue 160GB | Viewsonic VA503m | Logitech Z110 | Sony DVD-RW AD-7240S | Generic Keyboard & Mouse | Zebronics 700VA
SteamID
17-04-2011, 06:14 PM #11
In local market u can get it for 3.5K, or even less...
17-04-2011, 07:18 PM #12Right Off the Assembly Line
- Join Date
- Apr 2011
- Location
- Hyderabad
- Posts
- 45
Even i used to think 520 Seasonic would be enough. But then i used this(n few others) Power calculators:
http://extreme.outervision.com/psucalculatorlite.jsp
It turns out my consumption would be 518W and Recommended one is 550W
I guess i have no option but to go with Corsair 550VX.
Expensive but great reviews.Last edited by DirtDiver; 17-04-2011 at 07:20 PM. Reason: more info
17-04-2011, 08:08 PM #13
Get Tacens Supero 600W if u can find one...
17-04-2011, 08:21 PM #14Right Off the Assembly Line
- Join Date
- Apr 2011
- Location
- Hyderabad
- Posts
- 45
17-04-2011, 08:36 PM #15
17-04-2011, 09:02 PM #16Right Off the Assembly Line
- Join Date
- Apr 2011
- Location
- Hyderabad
- Posts
- 45
17-04-2011, 09:15 PM #17
Your wish...
power supply for 2k
By sukesh1090 in forum Hardware Q&AReplies: 7Last Post: 12-05-2011, 03:17 AM -
which power supply ?
By ankit0_0 in forum PC Components / ConfigurationsReplies: 6Last Post: 07-03-2011, 05:17 PM -
Power supply
By kumarn_2004 in forum Hardware Q&AReplies: 1Last Post: 24-12-2006, 08:43 AM -
Getting the right Power Supply
By gxsaurav in forum QnA (read only)Replies: 29Last Post: 09-10-2005, 02:18 PM -
AMD 64 Power supply
By impetus in forum CPU / MotherboardsReplies: 4Last Post: 18-01-2005, 11:59 AM
LinkBack URL
About LinkBacks
