Results 1 to 10 of 10
  1. #1
    Human Spambot clmlbx's Avatar
    Aug 2006
    Indore
    Default need some suggestions for portable Hard-disk
    As title says I want to buy External Hard-disk.. I believe Western Digital is better..But any Particular model or features I should look for .. Well I am looking for 500 GB to 1 TB Hard-disk.. budget around 3K, can add little....if any other brand is better pls feel free to suggest I am open minded nothing decided yet..
    Athlon II X4 635 @ 2.9Ghz Gigabyte GA-MA785GMT-US2H Kingston 2x2 Gb 1333Mhz DDR3 WDC 500Gb Green Palit GTS 250 512mb Tagan 500W Samsung B2030 Lg DVD Writer
  2. #2
    I am the night...I am... vickybat's Avatar
    Aug 2009
    Gotham City
    Default Re: need some suggestions for portable Hard-disk
    Go for wd passport essentials or seagate freeagent go-flex. You can't go wrong with either.
    Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
  3. #3
    Make Way the LORD is Here ssk_the_gr8's Avatar
    Dec 2005
    Old Trafford - The Theatre of Dreams
    i'd say WD passport
    (Gen.1:26-27) New Testament
    Proper Thread Title is a must otherwise you'll get banned
    FORUM RULES - Updated
    Don't Buy from Sulekha
  4. #4
    laborare est orare Cilus's Avatar
    Mar 2009
    Kolkata
    Seagate Go flex 500 GB is available @ 2.7-2.8K. 1 TB is out of your budget, its 5K minimum.
    AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
  5. #5
    Aug 2006
    Indore
    I saw few on primeabgb which is usb 3 and have compatibility with usb 2 too.. I am looking forward too it.. I also saw an option that says no esata.. as I know it is better then usb .any wd available wih both esata and usb too as many pc does not have esata.....
  6. #6
  7. #7
    Alpha Geek mohityadavx's Avatar
    Nov 2010
    Gurgaon (Delhi NCR)
    Thumbs up Re: need some suggestions for portable Hard-disk
    hey man 1tb is definitely in his budget. I bought a 1tb external hard disk frm ebay six months back which was seagate freeagent for 4100 (current price 3800) so he can stretch a budget little or move to some cheaper brand.
    Also go 4 seagate as they provide 5 years warranty instead of 3 year WD warranty and u must b knowing that big sized hard disk r not stable and tend to get corrupt or damaged.
  8. #8
    Nov 2010
    Gurgaon (Delhi NCR)
    Quote Originally Posted by Cilus View Post
    read my comment above.
  9. #9
    Broken In somulesnar's Avatar
    Jan 2011
    Alexandria, Minnesota
    @clmlbx
    If u are aiming for a extra portable hard drive i.e. widout power cable. Then u wud better go for seagate go flex 500GB for 2.8k.
    The other better option which i wud like to suggest is the WD my book 1 tb which needs a power cable but has a high transfer rate. This HD comes in a range of 3.5 to 4k.
    Go through this LINK u wud better get to know abt wd my book.
    Make ur decisions caredully after going through the link stated above.
    Core i7 930 ,msi x58-pro, 2x2gb ddr3 corsair xms, msi gtx 570,corsair hx 620, Wd 1tb blue , cm 690 , samsung 2233 ,apc 800va , altec lansing vs2621, hp probook core i5 450+4gb ram+320gbhdd
  10. #10
    Aug 2006
    Indore
    No for wd book as it needs extra power cable and it comes in 3.5 and isn't western digital passport good if not better then seagate flex. Or is it seagate better
  1. Portable Hard Disk
    By udbhavdwivedi in forum Hardware Q&A
    Last Post: 06-07-2010, 11:08 AM
  2. Replies: 12
    Last Post: 18-06-2009, 07:02 PM
  3. Portable Hard Disk Suggestion
    By prasanna7287 in forum QnA (read only)
    Last Post: 01-11-2007, 10:56 PM
  4. Portable hard disk,20GB
    By ThinkFree in forum Hardware Q&A
    Last Post: 22-04-2007, 10:29 PM
  5. Portable hard disk
    By Angad singh in forum Hardware Q&A
    Last Post: 28-11-2006, 09:32 PM
